Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > WORKS Brain Flash
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 17, 2007, 08:01 PM   #1
Personal Sales Rating: (11)
FastAzzEvo's Avatar
Drives: 2006 Evo IX GSR/SSL
works p2e datalog
I wanted to datalog my works flash before I add a bunch of new parts and get a custom tune. I wanted to post this because I am very happy with the tune for a mail in tune.
This is a p2e flash with just a tbe
The portion of the log I am noting is a 4th gear pull from which I wrote info on from 4000-7000rpm
Boost does hold pretty good.
The pic tells the rest.
Thanks works for a great product.
The Text on the data log pic is where the vertical line begins, in between that and the end of the 4th gear run you can see pretty much the afr in the low 11s to 11.9 or so at 7000rpm, then the boost staying at 20psi the very last been of the run where it drops to only 18.80psi
Also, I used my tactrix cable, and logged knock, not a single knock count.
Offline
Old Feb 23, 2007, 04:45 PM   #2
Personal Sales Rating: (10)
Jamie@WORKS's Avatar
Drives: Part-Time Test Mule
Send a message via AIM to Jamie@WORKS
Thanks for sharing
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
