Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > WORKS Brain Flash
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Oct 16, 2006, 08:36 PM   #1
Personal Sales Rating: (11)
FastAzzEvo's Avatar
Drives: 2006 Evo IX GSR/SSL
p2e flash TO custom flash
Sorry of the title, I fat fingered it..
I am planning a custom tune locally to upgrade my p2e w/boost tube.
Is it going to be an issue since boost is controlled by the cpu or when I get a custom tune is it going to defeat the purpose of a mail in tune?
I bought the p2e because I can get a custom tune locally that does ecuteck flashes.
Just wondering. Any info is appreciated.
Offline
Old Oct 17, 2006, 05:29 PM   #2
Personal Sales Rating: (6)
urBan_dK's Avatar
Drives: S2000, Mille 1000R, SV650s
Send a message via AIM to urBan_dK
Sure you can change the tune, but the tuner may not want to mess with the boost tables since now they will be set in a fashion that will control the WORKS proprietary boost hose.
__________________
Current
2005 Honda S2000 in Suzuka Blue
2001 Suzuki SV650s in Candy Grand Blue
2000 Aprilia RSV Mille 1000R in Black
Past
2006 Mitsubishi Lancer Evolution IX in Electric Blue {RIP}
2004 Kawasaki Ninja 250R in Nocturne Blue {RIP}
1987 Nissan 300zx in Burgundy {SOLD}
Buy my stuff:
http://forums.evolutionm.net/northwe...clean-out.html
Offline
Old Oct 17, 2006, 07:23 PM   #3
FastAzzEvo's Avatar
Quote:
Thats what I mean. The boost hose is exactly the same as the factory hose with the exception is it does not have those little metal pills in it.......
So with just the works hose and no flash the car would boost really high.
With the works flash and factory hose you will only get about 14psi.
So they tables are set lower.
My question is I know I can have a tuner adjust a/f and what not, but can a local tuner not "works" be able to change my boost through the cpu to say 22psi instead of the 20?
Offline
Old Oct 19, 2006, 12:06 PM   #4
Personal Sales Rating: (10)
Jamie@WORKS's Avatar
Drives: Part-Time Test Mule
Send a message via AIM to Jamie@WORKS
The EcuTek allows your local tuner to load their maps onto the ECU, which will overwrite all WORKS Brain Flash software and replace it with their own. Because of this, we would highly recommend removing the WORKS Boost Hose assembly and reinstalling the OEM one. Otherwise, boost levels will increase beyond the realm of safety. The WORKS Brain Flash P2 and hose assembly were designed in conjunction with one another and were never intended to be used separately.
Offline
Old Oct 19, 2006, 12:14 PM   #5
FastAzzEvo's Avatar
Quote:
Okay, so getting custom tune having the Brain Flash would not be a smart thing to do and would basically be throwing away money.
I was under the impression that since I have the p2e that a tuner that tunes with ecutek would be able to change some parts of the brain flash in order to gain me more power. lean out some, raise boost a psi or 2, or change some of the timing.
I guess I need to jump on a dyno and see where I am at before I make any concrete decisions.
Offline
Old Oct 19, 2006, 07:22 PM   #6
EcuTek doesn't give this feature away as it would allow one EcuTek dealer to see what others are doing. It does allow different dealers to load their own maps without consuming an additional license.
Offline
Old Oct 19, 2006, 10:33 PM   #7
Personal Sales Rating: (0)
Drives: Mitsu. Evolution IX MR
just wondering, i thought the works ecu controlled boost electronically, i mean, the hoses of which you seem to be talking about, do they feed to a sensor of some sort? if so, how do the hoses affect boost?
john
Offline
Old Oct 20, 2006, 08:49 AM   #8
FastAzzEvo's Avatar
Quote:
john
There is little metal pill like things in the factory hose. I guess these allows only a certain only a certain amount of vacuum to the solenoid thus decreasing the boost to a factory level.
The works hose doesn't have this.
Maybe Jamie can tell you better than me.
From my understanding a stock ecu with boost hose would cause you to have too much boost that isnt' safe. with the works flash and factory hose you will have about 12-14psi and with the works brain flash and their boost tube you will have a 20psi across the powerband.
Offline
Old Oct 20, 2006, 11:18 AM   #9
The WORKS Boost Hose assembly feeds the same sensor as the original. It's internals allow it to function differently, which gives the Brain Flash software the ability to reach and hold higher boost levels and avoid the taper that is present to begin with. The WORKS Engineers have gone about this with an OEM-style approach and have done it right. There's no absence of one or both pills nor is there any unregulated bleeder design (both practices are substandard and do not allow for sufficient control). In the end you have an effective electronic boost control system that is controlled via the WORKS Brain Flashed ECU.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
