Dec 18, 2005, 08:39 PM
Personal Sales Rating: ( 4)
Drives: 04 Evolution
Factory Warrenty?
If i where to get this flash, would the Mitsu tech be able to tell any difference when scanning for trouble codes should i run into a warrenty issue?
Offline
Dec 18, 2005, 08:43 PM
Personal Sales Rating: ( 54)
Drives: Evo X Evo VIII (SOLD) GSX-R 600 (SOLD)
I have been told this is the only thing they can't detect as only in the 05 can they detect it
Offline
Dec 18, 2005, 09:59 PM
what would be the difference between an 04 computer and an 05....i can understand 06 being different with the mivec...
Anyone from works know?
Offline
Dec 22, 2005, 03:07 PM
Personal Sales Rating: ( 2)
Drives: RR 03 GSR
I asked Works about this. They told me the same about the '05. I didn't understand if the change was in the ecu or the obd system. Also your reflash could get erased at the dealer if there is a recall based on the ecu tuning and the dealerships are reflashing them. So make sure you are up to date on recall status.
Does anyone out there have a flash that can say for sure that the dealer cannot detect it? I am skeptical, but if true I would love to have a Works flash.
Offline
Jan 24, 2006, 07:45 PM
Personal Sales Rating: ( 11)
Drives: 2006 GG IX MR
I was about to ask the same question about the dealer detecting an ECU flash and here it is lol
i def wanna flash my 2006 MR, either vishnu/works, etc so id love to know whether or not the dealer can detect an ecu flash on the IX's
Offline
Jan 24, 2006, 08:28 PM
Personal Sales Rating: ( 0)
Drives: 04 Evo
They won't unless they hook it up to the OBD II port. Unlike European cars you we have different ECU's and they are not synched. For exmple in Volvo there is one ECU that monitors and controls all the other ecu's and every part of the car from the door locks to fuel management and they are required to have the ecu scanned to the computer whenever the car is brought in for service even to reset the oil change light. Once hooked up our ME7 ECU tells us everything we need to know including how many times the ecu has been flashed. Evo's don't adhere to that. Hope this helps
Offline
Jan 24, 2006, 08:29 PM
Drives: 04 Evo
As far as 04-05 ecu's 05's may have a new feature that does record when the Ecu was flashed and logs it
Offline
Jan 25, 2006, 07:53 PM
Drives: '05 Evolution RS WORKS TR340, EVO VI TME
The WORKS P2 for Evo's from 2003-2005 is virtually undetectable at the dealer and will not interfere w/ Mitsubishi updates.
If a savy engineer wants to spend countless hours searching for a flash they may be able to detect subtle changes to the OEM tune. Rarely if ever, does a savy engineer work at any dealer we've encountered.
Offline
Feb 12, 2006, 02:53 PM
Personal Sales Rating: ( 3)
Drives: 06 IX GSR
would this hold true for the IX's?
thanks
Offline
Mar 15, 2006, 04:45 PM
Personal Sales Rating: ( 12)
Drives: '06 Evo 9 MR, '95 4Runner
I'd like to know as well
Offline
Mar 16, 2006, 07:38 AM
I spoke to Oliver at works yesterday on the phone and plan on picking up a p2 in the next few weeks- forgot to ask him how much it costs for a reflash if I do any other mods- what do you charge?
Offline
Oct 19, 2006, 10:41 PM
Drives: Mitsu. Evolution IX MR
can it be detected.... this is about the only thing holding me back from buying it now.
john
Offline
Nov 28, 2006, 11:18 AM
Drives: EVO IX MR
I too would like to know if this still holds true for the 2006 IX.
Offline
Nov 28, 2006, 11:27 AM
Personal Sales Rating: ( 7)
Drives: 06 GG Evo IX SE, 09 Mercedes ML 350
It can be detected but they would have no reason to want to spend the extra time just to try to see if the maps are different. I work at a dealer and being on flat rate I would rather just fix the car and get paid than spend a whole lot of time trying to see if someones ecu is flashed just to void the warranty. Its not like I am the one paying for the repair. If they are just scanning for codes for a check engine light or something it wont show up. They would actually have to look deeper into it in order to find any changes. The only reason I can think of someone checking for a flash is if the tune was bad and causing other problems which they were trying to diagnose. If the engine is knocking real bad or throwing po170 codes then they might have to look at the maps to make sure thats not the cause.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
