Go Back   evolutionm.net > Miscellaneous > Welding & Fabrication
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 13, 2009, 04:06 PM   #16
Personal Sales Rating: (0)
Fathouse's Avatar
Drives: WWevo9rs
Send a message via AIM to Fathouse
Quote:
Originally Posted by R/TErnie View Post
Nice! Nice job on the fit up. I like to bevel my tubes more than what you've done, but that's my personal preference. Looks like another solid setup. Good thinking on keeping your JIG so you don't have to remake your downpipe/exhaust.
How much boost did you run on the 35R setup? (weird question... what bov? Recirc or atmo?)
Ya, some of them are beveled better than others, but it gets to be a pain in the bum bum if the bevel is to large and your trying to hold everything together by yourself. I think I used a 1/2 roll of masking tape. lol.
Most of the time the 35r was @ 34-35psi daily, e85 car. It blew up on 37-38psi. The wg was recirced back in, along with a modded stock bov recirced back in.
The new setup is a dumped tial 44, and tial bov. e85 of course, SD on the stock ecu.
Fathouse
__________________
2006 Evo9 RS
Stock Engine/head/ecu/maf
Magnus v5, Shep racing, QM clutch, FP cams, Fatfab 35r turbo kit, BFF Racing, Snake Tunning, and CORN Fed
Best times to date.
6.757/10.362
108.55/136.94
http://www.youtube.com/watch?v=0qh0DPNNlJw
Offline
Old Sep 13, 2009, 04:09 PM   #17
Fathouse's Avatar
Drives: WWevo9rs
Quote:
Originally Posted by warp9 View Post
Impressive! Is this at your house? Props for a sweet looking setup and clean welds.
Ya, I do it all at home. Basically out of a two car garage. Been so busy latley I have done a few evo clutch jobs and turbo installs in my driveway.
I need a shop!
Fathouse
__________________
2006 Evo9 RS
Best times to date.
6.757/10.362
108.55/136.94
Offline
Old Sep 20, 2009, 06:56 PM   #18
Fathouse's Avatar
Drives: WWevo9rs
Been working more, figured it was time to update my thread.
Downpipe, dump pipe, lower ic pipe, is all fabbed and welded, the manifold is 80 % welded I am just waiting on a new headflange to finish it, then drop it off at the coating place and I should be ready to go.
The engine is done, gonna run some vacume lines and wires and put oil in it.
Fathouse
__________________
2006 Evo9 RS
Best times to date.
6.757/10.362
108.55/136.94
Offline
Old Sep 21, 2009, 12:05 AM   #19
Personal Sales Rating: (2)
R/TErnie's Avatar
Drives: TB Evo IX
Send a message via AIM to R/TErnie
you're figuring it out. You just need to work on tacking pieces. You can tack SS without filler rod. They key is lifting on the pedal very quickly... it draws the metal together and forms a tack. Do it enough and you'll understand what I mean.
I see you ran out of stainless bends
Nice job rocking the pedal!
__________________
11.1@129mph - 521whp via Dynojet
Offline
Old Sep 21, 2009, 10:47 AM   #20
Personal Sales Rating: (48)
2003 Mitsubishi Lancer Evolution
jid2's Avatar
Drives: 03 EVO VIII White
So this is a basic question to R/TErnie and Fathouse.... do you guys have the welder setup in pulsed?
Currently I weld both DC stuff (stainless and mild steel), and AC stuff with pulsed settings. I found it easiest when I first started. I run the pulse at 1Hz and it helped with timing on adding filler rod - as well as not getting the material too hot. Now that I'm a little better than when I first started I wonder if that is still good practice?
__________________
jid2 Built: Now featuring E85 super fuel
2.3L - GT3076R .63A/R, ETS equal length, Kelford 272's, BC valve springs, 1mm O/S valves, FIC BM 1450's, Full-Blown dual Walbros, Buschur IC, jid2 intake, airbox, IC pipes, APS BOV, TBE, ACT HDSS, Stock ECU, 28 psi 466hp/420 ft-lb...
Build Thread
Binary Lowered Recaro Seats, Girodisc 2-Piece, brake ducting, ST43's, SS lines and ATE Superblue, KW V3's 8K/10K, jid2 flat-bottom, adjustable splitter and aero, 18x9.5 +40 NT03's 265/18/35 BFG R1's
Offline
Old Sep 21, 2009, 10:53 AM   #21
97 dsm 4g63's Avatar
Drives: 97 eclipse gst
Send a message via AIM to 97 dsm 4g63
This setup looks sick! nice work.
Offline
Old Sep 21, 2009, 01:54 PM   #22
Fathouse's Avatar
Drives: WWevo9rs
I used to use the pulser when I first started welding, but I do not anymore. I also used to try to figure out the right amps for every thickness/type of metal etc.
Now I do not pulse anything, and just set the amps up high and let my foot control the power.
IMHO, try to get good without the pluser and such, I found myself welding at a friends house with his machine that did not have a pulser, and not knowing what I am doing. Now I can weld with anybodys machine.
Fathouse
__________________
2006 Evo9 RS
Best times to date.
6.757/10.362
108.55/136.94
Offline
Old Sep 21, 2009, 04:13 PM   #23
R/TErnie's Avatar
Drives: TB Evo IX
Rock the pedal. It's a manual pulse persay... you control the heat much better. I pedal down when I'm adding and welding... lift on the pedal when I'm moving. It keeps the heat from saturating the piece.
My 200Dx dynasty doesn't have enough amperage on AC for me to use a pulser... I run it wide open
__________________
Offline
Old Sep 21, 2009, 11:07 PM   #24
Personal Sales Rating: (17)
Drives: K20 EJ1 68mm turbo, 03 EVO8
damn wish i had a dynasty...need to get rid of my house size sync and get me a little dynasty. Especially for the 115 hookups, new house doesnt have 220 and i dont feel like adding it...
Offline
Old Sep 22, 2009, 03:22 PM   #25
Personal Sales Rating: (5)
Cyloc's Avatar
Drives: 2006 Evo IX GSR
Send a message via AIM to Cyloc Send a message via MSN to Cyloc Send a message via Yahoo to Cyloc
very nice work.....look foward to see how this all turns out
Offline
Old Sep 28, 2009, 03:47 PM   #26
jid2's Avatar
updizzles...... fat-hizzle.....
__________________
Build Thread
Offline
Old Oct 1, 2009, 08:03 PM   #27
Fathouse's Avatar
Drives: WWevo9rs
Finally got some more work done, the manifold is 99.3% done. I was waiting on a SS headflange that I had made. Monday it gets dropped off to get coated, and I should be making boost again next weekend. Thats the plan anyway. The only thing left to fab is a new upper IC pipe.
New 1/2" thick stainless head flange.
Fathouse
__________________
2006 Evo9 RS
Best times to date.
6.757/10.362
108.55/136.94
Offline
Old Oct 1, 2009, 08:11 PM   #28
silver3g2000's Avatar
Drives: EVOS
How much do you think you spent on the materials for your manifold?
Offline
Old Oct 2, 2009, 09:10 AM   #29
jid2's Avatar
That collector looks friggin nice inside. Great work house-of-fattness.
__________________
Build Thread
Offline
Old Oct 2, 2009, 03:12 PM   #30
Fathouse's Avatar
Drives: WWevo9rs
Thanks man.
__________________
2006 Evo9 RS
Best times to date.
6.757/10.362
108.55/136.94
Offline
Tags
35r, building, car, clutch, fatfab, kit, made, turbo, wwwfathousenet
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
