Jun 26, 2009, 07:45 AM
Personal Sales Rating: ( 17)
Drives: 97 850R, 03 EVO8, 09 Fit sport
Top mount manifold
I've been making this for my track car... uses TiAl V-Band exhaust housings (have both GT30 & GT35 for this car)... still have to do wastegate and downpipe...
material is .065 321 stainless with mixture of 3" CLR and 4" CLR tubing and all runners lengths are within 1/8".
-franz
__________________
. AimSports . Autronic . Aquamist . MoTeC . Formula Ikeya . GEMS . HJS . Pectel . RallyTech Composites . SPA Fire Systems . Vi-PEC .
Offline
Jun 26, 2009, 07:55 AM
Personal Sales Rating: ( 11)
Drives: 03'Evo8, 93' RX-7, 95' TSI, 92'TSI, 91'TSI x2, 92'GSX, 97'Civic EX, 08' GSX-R, 03' ZX6R 636, 03' Chevy Express van
That looks really nice.
Aaron
Offline
Jun 26, 2009, 09:48 AM
Personal Sales Rating: ( 0)
Drives: 2006 IX WW
how do you predict those long runners are going to effect spool up? regardless of how it performs it certaily looks cool!
__________________
IVEYTUNED
Offline
Jun 26, 2009, 10:35 AM
I am looking more for a particular powerband and a less drastic "spool"
__________________
Offline
Jun 26, 2009, 01:03 PM
Drives: K20 EJ1 68mm turbo, 03 EVO8
Looks like a good 6-10k rpm power band on that 30r. Nice burns collector, you goin to brace the manifold at all? Especially since yours will be under constant heat and weight.
Offline
Jun 26, 2009, 08:36 PM
Drives: WWevo9rs
Looks very nice man.
__________________
2006 Evo9 RS
Stock Engine/head/ecu/maf
Magnus v5, Shep racing, QM clutch, FP cams, Fatfab 35r turbo kit, BFF Racing, Snake Tunning, and CORN Fed
Best times to date.
6.757/10.362
108.55/136.94
http://www.youtube.com/watch?v=0qh0DPNNlJw
Offline
Jun 26, 2009, 09:42 PM
a few other pictures from some other projects...
charge pipes
shift cable extension and support
switch box
chassis harness (Deutsch AS connectors, SPEC55 wire, DR25 heatshrink, Hellerman boots and all potted/sealed with RT125)
roll cage (also machined shift knob and hub extension)
close-up of hub extension
inlet tube that i use on engine dyno for turbo inlet pressure (i made these in various sizes)
EVO compressor cover modified for turbo speed sensor and post restrictor pressure port for engine dyno development
-franz
__________________
Offline
Jun 28, 2009, 08:14 AM
Is that 14ga wire in your chassis harness?
Offline
Jun 29, 2009, 05:50 AM
no
22, 20, 16 and 22 twisted/shielded pair
__________________
Offline
Jun 29, 2009, 07:39 PM
Personal Sales Rating: ( 12)
With all those added sensors, I'm guessing you will be utilizing a more "complex" ECU like Motec or Pectel.
Car looks to have some good money invested into it. Nice work!
__________________
2005 Evolution MR- WW
Offline
Jun 29, 2009, 11:07 PM
Personal Sales Rating: ( 2)
Drives: TB Evo IX
nuts setup
__________________
11.1@129mph - 521whp via Dynojet
Offline
Jun 30, 2009, 11:38 AM
motec m800 (drive by wire, lambda, adv functions), pdm16 x2, mdc, sdl (with pro logging)... all vehicle functions operated by steering wheel mounted switches and all ecus communicate on dedicated CANBUS
i had a SQ6, but i ended up selling it... I built another car over the winter with multiple MoTeC units on a CANBUS and once i saw what i could do (with ease) with functionality I decided to swap out the SQ6 for the M800... it makes turn signals, emergency startup, autostartup, being able to turnoff functions when racing or in transit very straight forward...
-franz
__________________
Offline
Jul 30, 2009, 04:43 AM
Personal Sales Rating: ( 5)
Drives: Yard truck
Wow dude you do some really good work. Props.
Offline
Aug 10, 2009, 10:03 AM
Drives: EVO V
wow! real nice work!
Offline
Aug 10, 2009, 02:28 PM
Personal Sales Rating: ( 4)
Drives: 2003 Evolution
Man. I can get somebody to suck your dick for some parts if you want. I love the manifold and the shifter relocated back. Being a tall guy I have thought about fabricating something like that to where it sits about 6-8" back.
__________________
Aron aka JK
Active duty Navy, H60 Structural Mechanic
03 Murdered out GSR TTP tuned
97 GST SAFC 351whp corrected 10:1 AFR
XBOX live: Jks97DSM
Offline
Tags
05, brace, dc, evo, evo8, fabricating, forum, manifold, manifolds, mount, performs, spool, sports, top, topmount  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
