Snow Meth Injection Install pics.
Refills are not bad.
Takes 1 minute to do with "long funnel"
I've had to refill it twice in the past 2 weeks, which is less than I have to fill up on gas.
I have it set to come on at 8 psi and full spray at 15.
The 2.5 gal would be nice, but it's just too big for my needs, and space.
Final tuning is done on the Alcohol injection kit.
455 awhp / 400 awtq
Picked up 100whp from before install.
Turn on @ 5psi and Full Spray @ 12psi
625 ml nozzle
100% Denatured Alcohol
28 psi
11.8-11.9 afrs
Here is a short video of the last run, and FLAMES at the end of the run,lol...
EVO FLAMES
Thanks Dan
455 awhp / 400 awtq
625 ml nozzle
28 psi
11.8-11.9 afrs
EVO FLAMES
Thanks Dan
We did the final tuning runs last night.
Got this Short,Grainy video of the run and the flames at the end.
Ended up with 455 awhp.
Still a little rich, just to be safe. 11.8-11.9's
EVO FLAMES
EVO FLAMES
-there is no inline solenoid valve to immediately "cut off" ths injection of injectant at the end of a boost event OR
-the boost restricting pill is not removed causing a delay in the shut off...
says me who has run one in that area of an evo for 2 years and customers who have done so for even longer...the amount of water that actually hits the pump is minimal...the big concern is the wires going into the pump but thats why I said one should check it regularly...
