limp mode when meth/water injection - Audi s3 8L
Old Aug 27, 2017, 03:18 AM
Mudgelator's Avatar
Hi, just thought I'd ask, my audi goes into limp mode using, code: "system too rich on bank 1" without it's fine. Their maybe more than one combined reasons for the problem, ie leaky injectors?
One problem suggested was that I was adding wm too early causing the iat sensor (1psi, silly i know) to overcool causing a rich mixture (confusing the computer to run choke) to trigger the fault code. However now its 5psi starting point and still occurs.
I find I can avoid limp mode by keeping the revs up, stayin on throttle.
Any suggestions?
Old Aug 27, 2017, 09:26 AM
RazorLab's Avatar
Received 1,038 Likes on 760 Posts
Pretty sure you are on the wrong forum.
Old Aug 27, 2017, 11:15 PM
RightSaid fred's Avatar
You don't need methanol, only water.
That'll fix it.
meat_EVO
Apr 21, 2010 04:25 PM
Lancematic
Sep 25, 2006 02:09 PM
Blitzbaster02
Oct 3, 2004 10:38 PM
ruthless evo 8
52
Sep 14, 2004 07:27 AM
Quick Reply: limp mode when meth/water injection - Audi s3 8L
