smc kit trouble shoot please!
Old Mar 25, 2006, 02:43 PM
poohlvhun's Avatar
Guys,
I just had the kit installed, all wires hooked up...
BUT when I turned the key to 2nd position, it started spraying non-stop... I am reading about 80psi on the gauge at the nozzle.
Is it "priming"? Will it stop eventually?
What might be causing this?
Any help would be great, I am due for a custom tune by AL tomorrow.
Thanks!
Old Mar 25, 2006, 02:51 PM
GTVEVO's Avatar
Sounds like you or someone has something backwards but regardless you should just contact Steve at SMC. He will take care of you, he always does.
Old Mar 25, 2006, 03:00 PM
poohlvhun's Avatar
unfortunately, i will getting a custom tune for the alky tomorrow by Al, so this needs to be sorted out tonight ...
Old Mar 25, 2006, 03:02 PM
Ryu123's Avatar
Check that the test button is not stuck in the depressed position?
Old Mar 25, 2006, 03:43 PM
poohlvhun's Avatar
the "test" button clicks so i don't think it's stuck...
Old Mar 27, 2006, 11:34 AM
poohlvhun's Avatar
I ended up buying a second SMC kit from Dynoflash when I had the car tuned, it worked like a charm!
Steve at SMC was very helpful with the trouble shoot and will be sending out a new kit to me.
Thanks!
blueice288
Mar 14, 2017 07:58 PM
Pine_Apples
Oct 23, 2015 06:27 PM
90GSXDan
Feb 13, 2009 04:54 AM
bigvinx
13
Nov 13, 2004 01:15 AM
Deceit
Jul 9, 2004 11:21 AM
Quick Reply: smc kit trouble shoot please!
