Where to buy METH or ALKY
Here is a list I have put together of places to buy methanol, and some of them do ship as well.
Engine Runup
Engine Runup
Thanx for sharing the info!
Engine Runup
Engine Runup
No problem at all. I am in the process of becoming a Sponsoring Vendor of this forum, so any time I can help, I will do my best.
Thanks,
Greg
Originally Posted by marks03evo
ok well I was wondering where all you guys buy/order your alcohol for your alky injection kits.
do you guys use Meth or alky?
which one is the most cost efficient and which works the best?
and most importantly where do you buy it froma nd how much do you pay?
Thanks
Thanks
Originally Posted by kmcconn9
can anyone report on the home depot denatured alcohol and its effectivness..
Go to www.vpracingfuels.com and ask where the nearest distributor of VP fuels is, and they will tell you, you can get a 55 gal drum or more CHEAP! less impurites. I get it by the 5 gallons, and it will last for a long time. Good luck.
how much does it cost in a 5 gallon drum?
The denatured alcohol from home depot is 100% denatured alcohol. I have seen many people using this same stuff.
I have no vp racing distributors in my location, that is why I went this route with the hd denatured alcohol..
thats weird because both al and dave buschur both have commented on using denatured alcohol..
meth is more combustable than denatured alcohol, but could also cause corrosion issues..
Just check some of the Buick forums, they have been running denatured alcohol for MANY years with significant success..
I am not saying that either one of them use alky in their cars, because I do not know 100%. I have read several times that Al has said that he is using alky, but that may be different than what he is actually using right now.
The alky from home depot is expensive, but if it is your only reliable source then its better than nothing...
