Sep 2, 2009, 08:57 PM
Personal Sales Rating: ( 2)
Drives: 04' GSR
Toulene and you!
Have any of you tried adding toulene to your gas?
If so what % did you mix and what were the results?
__________________
04' GSR intake, 3" TBE, BOV, 9 turbo, MBC, ECUflash&EVOscan (most fun to drive)
91' Eclipse GSX 4G64 MasterPower T64
00' Turbo stang 10.xx's (scariest to drive)
92' Suzuki Swift GTi NX direct port kit on slicks!!!! 12.70's
93' VR4 stock turbos exteme weight reduction 11.xx's
00' Camaro SS Heads/cam 12bolt on Boggarts 10.xx's
82' Firebird back half race car 400ci turbo God in the works!!! I can't wait!!
Offline
Sep 4, 2009, 02:45 PM
Personal Sales Rating: ( 8)
Drives: goggles and a speedo
Toluene or xylene will eat rubber fuel system components fairly quick at concentrations that make a difference in octane
Offline
Sep 19, 2009, 09:00 PM
Drives: 04' GSR
I disagree since they are the main ingriedents to race gas and I run race gas all the time....
Anyone??
__________________
Offline
Sep 19, 2009, 09:01 PM
Personal Sales Rating: ( 0)
Drives: 2006 Evo IX SE TB
Toluene is very carcinogenic.
Offline
Sep 19, 2009, 09:03 PM
Drives: 04' GSR
Soooo whats your point..... if you race anything then you are exposed to carcinogens like mad who cares buy a Prius.
__________________
Offline
Sep 19, 2009, 09:14 PM
Drives: 06 IX GSR GG / 06 IX SE TB
Are you talking about injecting toulene with an injection kit? or adding ti right to the gas? If your talking about adding it to the gas tank this you prob get better results posting in the Alternative Fuel section
__________________
IX - Dejontool 3" Intake, Dejontool MAFT UICP, AMS LICP, AMS FMIC, 3" GM MAF, GEN 2 Trans, AEM wideband, PTE 880's, Walbro 255, Tial BOV, HKS Downpipe, test pipe, Greddy Ti C Catback, Hallman MBC, SNOW Stage 2 Meth Kit, JIC Magic FLT-TAR Hard setup, Nitto NT01's 235-45-17, Batt in da trunk, C-west front, JDM Rear, Carbon Hood / trunk, and Gauges N' S$%#
Offline
Sep 19, 2009, 09:35 PM
Personal Sales Rating: ( 12)
Drives: '04 'mac black EVO8, '04 black onyx IS300, 1998 eclipse gst(R.I.P.), 1993 Honda Accord A.E., 1990 Ford Mustang-built 302(sold), 1971 Chevy Elco built 307
i have. i have tried using 1 gallon with 10 gallons of 91oct. the best performance i gained was with 1/2 gallon with 10 gallons 91oct fuel. you will LOSE performance if you use too much octane and dont up the boost or tune for it. i added it for knock prevention. i noticed it up top in the rpm range..it ran smoother and pulled smoother as well. im running 21psi on FP white rabbit/6.5TME hybrid.
__________________
Helix intercooler pipes,Helix 3" DP,Helix 3" exhaust,Invidia o2,Helix DNA coilovers, WORKS filter,3" WORKS HFC,Greddy Type S,FPWR Turbo w/Ti internals,10.5 Hotside,Works p2 flash w/boost control, Works 269 cams,Revolver valvesprings/retainers,ARP headstuds,Walbro 255,6000k HID upgrade,DoLuck CF lip,Omori multicolor electronic 60mm gauges,B&M short shifter,Pocketlogger,HKS type 1 TT,custom grounding kit,voltage stabilizer,Axas shift indicator light
Offline
Sep 19, 2009, 11:02 PM
Drives: EVO8
Quote:
I disagree..
In very high concentrations yes it does eat rubber components.
For 3 years I used a mix of 6l Toluene and 6l Xylene to a tankful of gas. in my WRX. No issues with rubber lines etc.
When I first got my Evo, I also used the same mix and my wife drove the WRX with the same mix.
Recently I have changed both cars over to a E50 mix,. The ethanol here in SA is not available at the petrol stations, so we buy it from chemical companies.
Using ethanol and with a retune, I have been able to gain 30wkw with the WRX and close to 50 wkw, largely from upping the boost and running more timing, which wasn't possible with the old tol/xyl mix.
Bottom line is, ethanol is cheaper, you can get more power from using it, less of a ball ache to mix.
Ethanol ftw.
Offline
Sep 21, 2009, 02:03 PM
Drives: 04' GSR
Doesn't ethanol require 30% more fuel to create the same power though
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
