May 19, 2009, 02:53 PM
Personal Sales Rating: ( 0)
Drives: 2003 Evolution 8
Meth nozzle and IAT sensor placement help
Im trying to find where to place the bung for my AEM IAT sensor and also where to install my meth nozzle? I am using a AMS upper intercooler pipe with tial BOV. There isnt alot of room between the Throttle body and BOV. Any ideas?
Offline
May 23, 2009, 03:50 PM
Personal Sales Rating: ( 22)
Drives: evo VIII
Which intercooler are you running (ie are your end tanks thick aluminum)? In the AEM forum, you can see some people are concerned with heat soak of the IAT sensor when mounted in the engine bay, giving a falsely high reading to the AEM ECU. I tapped my intercooler end tank since it was thick enough to get multiple threads for the sensor vs. tapping thin intercooler pipe. Regardless, you want your IAT sensor mounted before the meth nozzle, and preferably the meth nozzle after the BOV, so that when the meth comes on, it doesn't wet the IAT sensor.
Offline
May 24, 2009, 09:21 AM
I am running the AMS intercooler. I havent heard of that method before. My AMS upper intercooler pipe is super thin. If I want to mount the IAT sensor there I have to get an aluminum bung welded in. Explain this endtank mounting location a little more.
Offline
May 24, 2009, 09:51 AM
Personal Sales Rating: ( 36)
Drives: EVO METH MACHINE
just mount the IAT on the upper intercooler pipe and weld on a bung. Meth nozzle should be about 12" from TB...definitely after the bov.
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
May 25, 2009, 01:32 PM
that sounds good but my AMS upper intercooler pipe has the bov flange very close to the TB. so the nozzle will be pretty close. it will probly work tho. thanks
Offline
Jun 1, 2009, 05:16 PM
Drives: 87 Mazda RX-7 Turbo II
Don't install the AI Jet too close to the AIT sensor. That will give a false reading. You want at least 6", preferable more, between the two.
Offline
Jun 3, 2009, 09:09 AM
The best placement That I can get Is the IAT sensor will have to go in the upperintercooler pipe between the Bov and intercooler And the Meth nozzle will go a few inches before the Thorottle body. Thanks for all the input!
Offline
Jun 3, 2009, 02:48 PM
with this set up, you AIT sensor will never read your AITs after meth is sprayed...
Can you put the AI nozzle at the IC and the AIT sensor at the TB?
Offline
Jun 3, 2009, 03:08 PM
Personal Sales Rating: ( 6)
2005 Mitsubishi Lancer Evolution
Drives: 2005 Evolution RS WW
FWIW I have them all crammed between the bov and TB. Bushcur pipes, LMS meth kit, not running AEM ~ Maft PRO SD.
Meth is just at the turn in the UICP, AIT is 3" away RIGHT before the TB. Both are on the back side of the pipe facing the firewall. AIT was installed with a bung welded to the pipe. This was ground down to deshroud the element, and it definitely gets sprayed.
I haven't had a single problem in over a year. This car is d/d. Every day, rain, snow and shine. Meth is on 365 days a year and gets used every time the pedal goes down.
I don't get bad reads, or heat soak.
In fact - if anything having the AIT account for the colder air charge when the meth is spraying allows my meth tuning to be mindlessly easy. It see's it - and accounts for it. And my fuel curve stays flatter. I just end up pulling a little more fuel out, than if I hid the meth from the AIT.
Again, to each their own, but I have no problems doing it this way. So if spacing is that much of a problem, I wouldn't pull your hair out over it.
__________________
Buschur 3" TBE no cat, Buschur deluxe FMIC & piping, HAFE GT3076R turbo kit, GM BCS, HKS 272's, Tial bov & 44WG, W255, FIC 850's, MaftPro, LMS meth kit, GTWorx springs, Bilstein HD's, ES bushings, AWD MS Alu D/S, Beatrush d/s bushings, Powerflex front & rear mount, ACT 2900 /street disc, Prolite flywheel, DBA 5000/4000 brakes, Goodridge, Motul. Emissions delete, all tuned with ecuflash!
-Dustin
Just PM me!
Offline
Jun 14, 2009, 07:45 PM
Personal Sales Rating: ( 61)
Drives: Evo 8
mine is about 6-8 inches before my bov. I have BR uicp
Offline
Tags
2005, air, evo, evolution, iat, install, intercooler, mazda, meth, methanol, mount, mounting, nozzle, oxygen, placement, rx7, sensor, temperature  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
