I have my reservoir in the trunk and the car builds boost so fast that to be honest I have mine at about 6-7ish since in the split second it takes the pump to engage and build pressure to spray, I'm probably at 10 anyway. However I am only boosting to 19psi so you might be fine at 10. I think tho that since your boost is pretty high, you might be better having it come on full at 22psi or something. I played with mine for a while before I found the sweet spot. Just be careful the little switch is a bit easy to push inside the unit. Had to open mine more than once.
__________________
Power FC | Defi Boost & Oil & AEM Wideband | DNP Manifold | Invidia02, Down & Test Pipe | HKS CatBack | Blitz BOV | Samco Intake | AMS LICP | Perrin I'cooler | AEM Meth Inj. | 255Walbro | Greddy 720s | Ralliart Wires | B&M Shifter | Poly Bushings | 17X9 Advan Rims | JDM Coilovers | APR, Cusco Carbon Braces & H Brace | AGP F. Mount | KSport 8pot 13" Brake Kit | Greddy Cam Gears | HKS 264/272ex Cams | MBC21psi | JVTR Radiator | ACT Clutch & Flywheel
