Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Water/Alcohol Injection
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Apr 8, 2009, 01:05 PM   #1
Personal Sales Rating: (19)
goosey2099's Avatar
Drives: 2001 Galant 5SPD
Send a message via AIM to goosey2099 Send a message via MSN to goosey2099 Send a message via Yahoo to goosey2099
Meth users i need some fast help...
I have a question to all meth users. I have SMC meth kit installed (nothing in it yet). I was reading somewhere that I should make some sort of hole on top so air can get in it. Can anyone confirm this? Also if meth does evaporate is there anyway I can route the vapors outside the car so it won't be dangerous to smoke next to my trunk?
This is how it is mounted:
__________________
4G64 5 SPEED Turbo
MY 5 SPEED - MY TURBO BUILD - MY CARPUTER - MY CAR
Offline
Old Apr 8, 2009, 01:12 PM   #2
Personal Sales Rating: (9)
Drives: 06 IX
I'm not familiar with putting a hole in your meth tank to vent. You wont have to worry about the meth evaporating if the tank is sealed.
__________________
For Sale...
Stock Fuel Pump
Stock underpanel
stock cams
stock springs+retainers
(all parts have 3,000 miles and in excellent shape)
http://forums.evolutionm.net/sale-engine-drivetrain-power/300701-stock-ix-parts-sale.html
Offline
Old Apr 8, 2009, 01:13 PM   #3
Drives: 06 IX
To clarify, I nor anyone I know, ever had a vent hole in their meth tanks.
__________________
For Sale...
Stock Fuel Pump
Stock underpanel
stock cams
http://forums.evolutionm.net/showthread.php?t=300701
Offline
Old Apr 8, 2009, 06:48 PM   #4
goosey2099's Avatar
Anyone else??? If I use a vented cap the gasses would build up in my trunk right? Or is it a one way thing
__________________
4G64 5 SPEED Turbo
Offline
Old Apr 8, 2009, 06:51 PM   #5
Personal Sales Rating: (6)
Lancerguy'03's Avatar
Drives: '03 RRM Turbo Lancer gone; 2004 EVO 8 RS!
Send a message via AIM to Lancerguy'03
my meth tank doest vent...if its air tight the the meth should't evaporate. right?
__________________
FP Green (ported/coated), O2 Pipe (coated), Stock Manifold (ported/coated),HKS 272 cams,HKS RS Intake with Amsoil Filter, TurboXS FMIC, Custom UICP, APS Twin Vent BOV,AMS LICP,3in TBE (no cat),ACT HD clutch, Prolite flywheel,Shepp Stage 2 T-case, Odessey PC680 mini batt, Evolution Dynamics Mini Battery Mount, KW Variant 3, Greddy EBC, TephraMOD ECU, Aquamist HFS-5 @100% meth! @ 30psi...
BUILT & TUNED BY KEVIND @ Evolution Dynamics!
Offline
Old Apr 8, 2009, 06:51 PM   #6
Personal Sales Rating: (10)
Genesis8's Avatar
Drives: A slow Evo now.....
I had the same kit and I have never put a hole in mine before.
Offline
Old Apr 8, 2009, 10:56 PM   #7
goosey2099's Avatar
Should i atleast use a vented cap or exactly how it is now?
__________________
4G64 5 SPEED Turbo
Offline
Old Apr 9, 2009, 04:50 AM   #8
Personal Sales Rating: (2)
magyar86's Avatar
Drives: 2005 EVO 8, 2008 F150, 1967 Camaro, 2006 GSX-R 1000, 2005 GSX-R 600(wrecked and for sale)
Dont vent anything on the tank. Meth is a Hygroscopic substance, witch means it will absorb water molecules from the surrounding environment. so if you have it vented it will dilute you mixture very quickly. you want you tank to be as air tight as poss.
__________________
new setup:
motor: 8.3:1 weisco pistons, manley turbo tuff rods, arp L19 head studs, cometic head gasket
head: +1mm manley valves, supertech dual VS, full drag P&P, O-ringed, kelford 272 cams
turbo: turbonetics hurricane series, prototype 76mm t3
Offline
Old Apr 10, 2009, 06:30 AM   #9
bambooi's Avatar
Drives: Evo IX
^^ One purpose of meth bought in stores is to remove water from gas tanks.
__________________
11.554 @ 122.73 (full weight minus spare tire)
Offline
Old Apr 10, 2009, 07:20 AM   #10
magyar86's Avatar
ahhh.....ok.....adding meth to gas cannot "remove" water from gas. the reason meth is added to gas is because water will not mix with gas and it will seperate. gas is lighter than water so the water will sink to the bottom and gas will float on it. meth on the other hand will mix with gas a little better. so when you add it to your tank it will soak up the water and then be able to mix with gas so instead of your fuel pump sucking up basically straight water the water will be mixxed through out the entire tank of gas so the water is burned off in small amounts.
__________________
new setup:
Offline
Old Apr 10, 2009, 07:42 AM   #11
Personal Sales Rating: (21)
05blue8's Avatar
Drives: 2005 VIII
Send a message via AIM to 05blue8 Send a message via MSN to 05blue8
I've always used a vented cap. Maybe we need an engineer to chime in here regarding the pump being able to create suction strong enough to pull meth out of a container that strong. I can tell you from experience and over 2 years of using meth that I have never had a problem with this and have always used a vented cap. With a vented cap and a 4 gallon meth container in my trunk I've never smelled meth anywhere in the car unless there was a leak. I'm very used to the smell so if a couple drops hits the carpeting in the back I can smell it in the cabin but I also check it regularly. I've always used vented caps and have never had an issue but on that same note, a full tank of meth has never lasted more than 2 weeks that I can recall. You can get vented caps very cheaply and shipped very quickly from Flambeau. http://fluids.flambeau.com/caps/caps_2none4th_inch.html
__________________
2005 EB VIII with everything except injectors and a bigger turbo!
Thanks to Evolution Dynamics for the great work!
Offline
Old Apr 10, 2009, 07:54 AM   #12
Personal Sales Rating: (15)
2003 Mitsubishi Lancer Evolution
bluebanana23's Avatar
Drives: blue shopping cart
someone had an issue with the meth tank caving in at the track because it wasn't vented??? It was a few months and I can only remember vaguely.
__________________
Power is useless without control is impossible without grip.
http://img127.imageshack.us/img127/2926/banjv4.png
Offline
Old Apr 10, 2009, 08:08 AM   #13
Personal Sales Rating: (3)
IXmr321's Avatar
Drives: in flip flops and socks
Send a message via AIM to IXmr321
no vent here either...
__________________
I heart MIVEC & TTP Engineering
TTP Engineering, Megan, HKS, GSC, Fidanza, Zeitronix,Forge, Cosworth, ARP
Quote:
Originally Posted by Asmodeus6 View Post
I like this guy. He breaks sh** like a mother f***in' professional.:D
{thumbup}
Offline
Old Apr 12, 2009, 12:39 PM   #14
Personal Sales Rating: (1)
Jersey Dino's Avatar
Drives: 02 WRX(sold) 2006 GG EVO IX, NA6(8)C Miata, 2000 CBR600 F4
Send a message via AIM to Jersey Dino
my cap has a small almost pin hole sized opening in the middle. the methanol should not evaporate through that little hole. I have left the car undriven for days and never did I observe a noticable amount of fluid loss. Besides, if your are driving it the way most are...your not going to have time to allow to evaporate
regarding the tank that imploded; that was attirubed to a strong pump sucking out the methanol and the air with it. Think of a little kid drinking a juice box through a straw trying to extract every last bit of sugary goodness. that juice box usually implodes because of how air tight things are around the straw.
__________________
06 Graphite Grey EVO IX.
Bushur Racing Cone Filter/TTP 02 Housing/Turbo XS TBE(race pipe)/Forge MBC, Walbro 255/ETS 3.5in FMIC/GSC S1 Cams/Defi Link II & BF series boost gauge/4WS Tuned
ROBISPEC///
TEIN Flex with Pillow Mounts & EDFC/Rear Trailing Arm Bushings/Rear Bump Steer Kit/Front Roll Center Kit/Rear Sway Bar
Offline
Old Apr 12, 2009, 05:00 PM   #15
Drives: Evo VIII
The tank is fine in the trunk. The meth wont evaportate fast enough to cause and harm.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
