Mar 30, 2009, 12:29 PM
Personal Sales Rating: ( 1)
Drives: 04 Evo
show me your meth kit setup!!
I am about to install my labonte meth kit and have an idea on where I am going to put everything I made brackets on the back of trunk so the tank and the pump will go on but wondering where everyone else is putting theirs. Another question is: Where can I find installation steps plus photos on how to install the labonte meth kit or any meth kit?
__________________
HKS ssqv BOV
HKS Turbo Timer
HKS 30th Anniversay Hi-Power Exhaust
Injen Intake & Full Intercooler Piping Kit
SEibon TS-II Carbon Fiber Hood
WALBRO 255 LPH Fuel Pump
Competition Clutch Stage 4
Snow Performance Stage 2
Offline
Mar 30, 2009, 01:12 PM
Silver Sponsor
Personal Sales Rating: ( 6)
Drives: Drag Evo 8, DG built Evo X, 05 Cadillac Escalade, 07 Ninja zx6r
Meth kit installation.
Here is a coolingmist installation I have done a long time ago. This seems to be one of the easiest ways. There are a few other ways to do it but here ya go:
link: snow performance install with pictures.
__________________
DG Motors
In-house DYNO DYNAMICS
Tuning specials for evo 8's 9's and X's
Ecuflash Specialists/Aem Certified Tuners
WWW.DGMotorsNY.COM
1-631-957-8464 -Ask for Pete
Internet Flash Packages!
Tuner Of Worlds Highest Whp "Stock Ecu"Stock Block Evo X 629whp!
Tuner Of Worlds Highest Whp Evo X On 93 Octane 629whp!
DG Drag Evo 8: 9.06 @ 164mph!
DG Drag Evo 8 In Action: http://www.youtube.com/watch?v=ASZIiklA0Ow
Offline
Mar 30, 2009, 01:13 PM
Silver Sponsor
If you have any questions about any part of the kit in regards to line routing, tank mounting, etc..feel free to shoot me a p.m.
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Mar 30, 2009, 08:23 PM
Drives: 04 Evo
thanks for the input.... when I am half way through I'll post some pics I like how you put the line between the brake lines... did you drill any wholes from the bottom because I plan on going through the inside.. do you think thats safe??? or am I going the wrong way?
__________________
HKS ssqv BOV
HKS Turbo Timer
Offline
Mar 30, 2009, 08:25 PM
Drives: 04 Evo
anyone has write ups.......
__________________
HKS ssqv BOV
HKS Turbo Timer
Offline
Mar 31, 2009, 01:31 PM
Silver Sponsor
A very easy solution is to mount the tank/pump inside the trunk on the left hand side. Next step would be to mount it. After the tank and pump is mounted, ground the pump with the black wire to a good clean spot on the chassis. Next you will snake the alky line and power line for the pump through the trunk under neath the driver rear seat. From there you can pull up the floor board covers and run the lines under them up to the dash board under your clutch/brake/gas pedal. Directly above your pedals, you will see a grommet where your throttle line goes through. Now you will have to drill a hole to the left of that grommet and run your alky and power line through. After that you attach your power line to the positive terminal on the battery. You then need to drill your upper IC pipe right before the throttle body about an inch back from the coupler that connect the IC pipe to your throttle body. I believe the drill and tap is 1/8 npt. I may be wrong so check your directions. After that is all said and done, you should only have a few more wires to wire up and you are set to go! That is how i do a majority of my alcohol installations now.
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Mar 31, 2009, 09:50 PM
Drives: 04 Evo
thanks a lot for the info dg motors
+1 for DG Motors
__________________
HKS ssqv BOV
HKS Turbo Timer
Offline
Apr 1, 2009, 12:13 PM
Silver Sponsor
Quote:
+1 for DG Motors
Glad I could help, If you run into a snag, just shoot me a p.m!
__________________
DG Motors
WWW.DGMotorsNY.COM
Offline
Apr 5, 2009, 10:14 AM
Personal Sales Rating: ( 10)
Drives: 06 EVO IX MR
pcamara you got it installed? How you end up routing?
__________________
06 EVO IX- MR; 96 cobra; 92 f150, 69 stang 5.0/aod swap; 86 18g turbo 4runner.
"I am not slacker I am a delegator."
Online
Apr 6, 2009, 11:43 AM
Drives: 04 Evo
the only thing I got installed was the placement of the tank and pump.... then I had a awful problem when I checked on my car a few days latter.... and found out my transfer case was cracked.... thank god I got a warrenty on it... Once I get that fixed I'll post up pictures of the way I set it up...
__________________
HKS ssqv BOV
HKS Turbo Timer
Offline
Apr 6, 2009, 11:45 AM
Personal Sales Rating: ( 4)
Drives: 06 evo sold, 00 dakota r/t, 04 R1 2006 SRT-8 JEEP
Damn the dealer is fixing that? suprise suprise..
__________________
Stock = turbo, Cams, block, head 93+50/50 meth-water
11.81@119mph 1.9 60ft
Tuned by Kreionic
CBRD
TRADED IN FOR SRT-8 JEEP GRAND CHEROKEE!!
Offline
Apr 6, 2009, 09:39 PM
Drives: 04 Evo
well not the factory warranty when I bought the car used from a toyota dealership I got their warranty that they gave me..... It cost me 2000 for 4 year/50,000....the good thing is that they will let me bring my car to a mitsh dealership
__________________
HKS ssqv BOV
HKS Turbo Timer
Offline
Apr 8, 2009, 01:33 PM
Personal Sales Rating: ( 3)
Drives: GG Evo IX, 2001 jeep XJ
I take it ur putting ur car back to stock for the dealership?
__________________
Stockish?
Offline
Apr 8, 2009, 01:37 PM
^ lol plus 1
__________________
Tuned by Kreionic
CBRD
Offline
Apr 8, 2009, 05:37 PM
Drives: 2006 Evo 9 GSR
where did you mount your pump and tank and how? I am doing mine tom.
Casper.
__________________
06 Mitsubishi Evo 9 Wicked White GSR
MBC, TBE, EPM 02 dump, EPM LICP, 255 Walbro, Forge WGA, ETS Intake, Built Buschur 2.0, ARP Headstuds, Tial 50mm, ACT HD 6 Puck, Precision 1000's, e85 fuel
Tuned by Diiirk 388 whp/415 wtq
AWD Motorsports built (Best in the Business)
Offline
Tags
baltimore, bung, buy, dsm, evo, intercooler, kit, meth, nozzle, pipe, placement, setup, spring, tap, trunk, weld  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
