Mar 24, 2009, 08:13 AM
Personal Sales Rating: ( 1)
Drives: 02 WRX(sold) 2006 GG EVO IX, NA6(8)C Miata, 2000 CBR600 F4
half gallon leaked strain into UICP pipe over night! Help!
hello everyone. I having a tough time here. my car managed to leak about half a gallon of meth passed the check valve into the upper intercooler pipe. I took the IC off and drained whatever I could. hooked up some air to it to try and dry it out. car will barely run/idle right now. could methanol have gotten into the actual motor? similar to a hydro lock situation? any help or suggestions how to remedy this would be greatly appreciated. thanks guys.
__________________
06 Graphite Grey EVO IX.
Bushur Racing Cone Filter/TTP 02 Housing/Turbo XS TBE(race pipe)/Forge MBC, Walbro 255/ETS 3.5in FMIC/GSC S1 Cams/Defi Link II & BF series boost gauge/4WS Tuned
ROBISPEC///
TEIN Flex with Pillow Mounts & EDFC/Rear Trailing Arm Bushings/Rear Bump Steer Kit/Front Roll Center Kit/Rear Sway Bar
Offline
Mar 24, 2009, 08:57 AM
cmon no one:?
__________________
ROBISPEC///
Offline
Mar 24, 2009, 10:01 AM
Drives: 2004 Mistubishi Lancer Evolution VIII,1993 Mitsubishi Eclipse GSX
was it all pooled in the bottom of the uicp? or was the methanol all the way up to the throttle body? methanol instantly evaporates if you can expose it to air. what kind of kit do you have?
__________________
Al Spec Custom Built motor
Dynoflash Tune
Buschur FMIC
6262
Devil's Own Methanol injection
Exedy Triple Plate Clutch
Hi I'm Dustin, and my car is an alcoholic
Offline
Mar 24, 2009, 10:28 AM
labonte kit. it did not go up to the throttle body. it went downstream. into the BOV a little bit and pooled up in the bottom of the intercooler it self. this happened about 10 days ago. I went on vacation and came back to the same problems. pulled the IC pipes again and its all dry. swapped out my fouled plugs and it has a hard time starting and idling, BUT it idles fine once you get it to start and when you hold it at about 1000rpms. I did get a P0113 code for the first bank 02 sensor.
__________________
ROBISPEC///
Offline
Mar 24, 2009, 09:51 PM
probably with all the residual left in the fmic and in the system its probably still running a tad rich. i bet after changing the spark plugs and running it for a while will probably fix your problems. just the afr being rich could throw your cel, but it could just be time to change that o2 sensor. good luck with it man,
__________________
Dynoflash Tune
Buschur FMIC
6262
Offline
Mar 25, 2009, 07:57 AM
after all the fluid was was drained and the car finally started It idled like hell. well, I reflashed the car with the map and it fixed my problem. I guess the ECU adpated the idle to a very rich condition. once driving aroudn a little bit it burned up the rest of it and drove fine again. problem fixed! thanks everyone
__________________
ROBISPEC///
Offline
Mar 30, 2009, 12:13 PM
Personal Sales Rating: ( 13)
Drives: 06 E. Blue Evo IX
how did the methanol get passed the check valve?I am just trying to prevent this problem from happening to my newly installed Labonte kit...
__________________
AMS HTA3076r, Exedy twin hd, 880cc inj.AMS fuel rail,Walbro 255lph fp kit, AMS TBE,AMS front mount intercooler,AMS LICP,HKS 272 Ex. cam,arp head studs, AMS front motor mount, Labonte motorsports methanol injection, stance gr + pro coilovers ,Stoptech 332mm big brake kit
93oct + methanol tune by "Kuniiizzzeee dial in!"
Offline
Mar 30, 2009, 12:18 PM
Personal Sales Rating: ( 12)
Drives: '04 White EVO VIII RS
Glad you got it working!!
__________________
Jun 272's ETS 6262 Wilson V2 Stock ecu All The Fixings on E85 Selftune!!
Offline
Mar 30, 2009, 01:47 PM
I was retarded and took the check valve out and ran without it to test. And after the car was turned off it siphoned it out.
__________________
ROBISPEC///
Offline
Apr 1, 2009, 02:32 PM
Personal Sales Rating: ( 45)
Drives: evo 8
i thought the check valve was there to stop boost from getting in the meth lines?!
Offline
Apr 1, 2009, 02:55 PM
it is...and it works fine, but during my testing I removed it to see if that was causing my problem...well I never put it back in and it gravity fed right into the IC. all is well now though. drained the lot of it, burned off the rest reflashed the ECU so it would unlearn the lousy idle it had to compensate the overly rich condition. that all works ok now.
__________________
ROBISPEC///
Offline
Apr 1, 2009, 04:42 PM
Silver Sponsor
Personal Sales Rating: ( 6)
Drives: Drag Evo 8, DG built Evo X, 05 Cadillac Escalade, 07 Ninja zx6r
Just some food for thought, Make sure your alky tank is mounted lower then where you put your nozzle in your uicp. Even with a check valve, it may be possible for gravity to suck some fluid through.
__________________
DG Motors
In-house DYNO DYNAMICS
Tuning specials for evo 8's 9's and X's
Ecuflash Specialists/Aem Certified Tuners
WWW.DGMotorsNY.COM
1-631-957-8464 -Ask for Pete
Internet Flash Packages!
Tuner Of Worlds Highest Whp "Stock Ecu"Stock Block Evo X 629whp!
Tuner Of Worlds Highest Whp Evo X On 93 Octane 629whp!
DG Drag Evo 8: 9.06 @ 164mph!
DG Drag Evo 8 In Action: http://www.youtube.com/watch?v=ASZIiklA0Ow
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
