Aquamist HFS-6's advanced algorthm explained...
Quick summary of the functions of the HFS-6's main control panel
Jumper links (default):
- System is triggered by Fuel IDC % (second from left)
- Spare jumper link is in parked position
- Water injection is enabled. Unlink for "dry-run" test
Three onboard LEDs
- Green LED: Fuel idc detection. Grows brighter as IDC increases
- Amber LED: The trigger point is reached, water injection commences
- Red LED: The water injection has almost reached its full flow.
Potentiometers to manipulate the flow curve.
(Adjustment is optional - preset at 12 o'clock)
- THRES ADJ: Set triggering point to start injection. Default: 42% IDC
- IDC TRIM: Add or subtract IDC% from the starting point. Default: IDC-in = IDC-out
- IDC gain: Alter ramp rate of the IDC-out relative to the IDC-in Default: 1:1 ratio.
- BOOST COMP: Increase the flow to offset the manifold pressure. Default: 2.5V
- FLSF SENS: Failsafe sensitivity/response to over or under flow spikes. Default: 400mS
- FLSF RST: Failsafe reset time after trigger. Default: 3 seconds
- DIM ADJ: Gauge brightness for night driving: Default: 50%
