Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Water/Alcohol Injection
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Aug 18, 2008, 02:47 PM   #1
Personal Sales Rating: (17)
johnjonfenomeno's Avatar
Drives: 03 Lancer Evo-8, 01 Toyota Highlander, 08 Jetta 2.0T
Life span of alky pump?
Ok I have had my meth kit for over 2.5 years now. It's an smc trunk mount kit and I can tell it still works because when I prime it, I see the afr's drop.. but I dont see the yellow light saying it's spraying until like .5 seconds after.. I know this light is pressure triggered meaning it will light up once the pump builds a certain pressure. Reason Im concerned is I use this signal to control my ebcs and switch maps on my aem. So is the problem the pump?
Offline
Old Aug 19, 2008, 09:41 AM   #2
Personal Sales Rating: (0)
Drives: 72 Cutlass
Most all pumps being used the amount of time they are used "only under boost" should outlast the car. I have pumps here that are 3 years old that have been ran 24-7 30mins on 15mins off. Smc does use a differnt pump design but you should get similar lifespan.
Offline
Old Aug 25, 2008, 09:41 AM   #3
Personal Sales Rating: (8)
2003 Mitsubishi Lancer Evolution
cfdfireman1's Avatar
Drives: EVO IX
On a trunk mount you have to charge a lot of line before pressure is built up.
Offline
Old Aug 25, 2008, 01:23 PM   #4
Yah but my interior cabin after sitting a while has a strong smell of alky.. Seals may be going?
Offline
Old Sep 18, 2008, 04:40 PM   #5
Personal Sales Rating: (36)
Evoryder's Avatar
Drives: EVO METH MACHINE
3.5 Year old shurflo pump 100% Meth break down - BIG pix
My pump after a 3 years...100% meth all the way
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Old Sep 18, 2008, 10:51 PM   #6
Drives: Daihatsu Move
Are you running a check valve or solenoid? IF you smell alky then something is releasing it into the cabin
Offline
Old Sep 18, 2008, 10:55 PM   #7
Its a trunk mount kit... I tested it and the problem is coming from the seals. I contacted Steve at SMC and I sent it in he replaced the seals.. problem solved
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
