Jul 5, 2008, 04:19 PM
Personal Sales Rating: ( 77)
2003 Mitsubishi Lancer Evolution
Drives: A Fuel Slut of the 8th kind
what devices can be used to switch between maps?
i am debating on getting a meth kit, but i will mostly run pump gas. what can i use to easily swap betwewn the two?
Offline
Jul 5, 2008, 04:25 PM
Personal Sales Rating: ( 12)
Drives: TTP Built 06 Silver IX SE
Quote:
Maf Translator pro.
TTP Project IX MR SE 429whp/469tq MD, stock turbo!
__________________
Apex Silver IX SE Built and Tuned by TTP Body by Kami Speed 550WHP 537WTQ
542WHP 523WTQ (street)
TTP Built 2.0L+FP RED+METH Mustang Dyno
Offline
Jul 5, 2008, 04:26 PM
Personal Sales Rating: ( 6)
Drives: GG Evo IX
nm I misread it. reading drunk ftw.
__________________
CBRD Speedfactory Tuned
Injen | HKS | Buschur | Walbro | Greddy | XS | EPM | AEM | TTP | TXS | Ichiba | APS | Blox | Mynes
Offline
Jul 5, 2008, 04:39 PM
Quote:
Originally Posted by Tryx
You don't use one or the other. Or maybe your talking about switching between a pump gas only map, and a pump gas while spraying meth map? If it's the latter, then just do a search on tephra and you will find the information you seek.
correct thats what i want pump gas on one setting and pump plus meth on the other with the flick of a switch
Offline
Jul 5, 2008, 04:46 PM
Personal Sales Rating: ( 91)
Drives: ix mr
there is more to it than that...not only do you need your meth set up on a switch but you need to be able to control your boost and ecu settings also
unless you have a wastegate solenoid trigger to cut boost to wastegate pressure when your meth kit is off and just have your car be slower than a mini van
Offline
Jul 5, 2008, 04:53 PM
just to clarify, as of now i have zeitronics . i want to buy a met kit but not have to have meth on hand at all times. i need a safe way to run meth but also be on just pump when i need
Offline
Jul 5, 2008, 06:17 PM
Drives: GG Evo IX
I just noticed you live in central FL. Maybe try contacting TTP? They have been doing the "kill switch" thing for awhile now with good success. Just a flip of a switch and you switch between a non meth map that also cuts power to the meth pump, and your meth map and powered meth pump. Good luck!
__________________
Offline
Jul 5, 2008, 06:48 PM
yea, ttp does most of my work. i just wasnt sure if i had to invest in another $400 to 500 gizmo
Offline
Jul 5, 2008, 07:01 PM
Personal Sales Rating: ( 3)
Drives: 06 evoIX SE
with the GM BCS you can run boost aound ~21psi on wastegate, Jackoftrades has developed a wire harness for map switching, and with the help of Tephra's ALTMAP you can set the meth kit to run how you want it... heres a vid of tephra+GM+Aquamist meth kit:
Aquamist HFS-1, GM BCS, and Tephra v5: together at last!
__________________
mah EvoIx pix
Tuned by:
AWD Motorsports
4WD Tuning
Offline
Jul 5, 2008, 07:11 PM
excellent, thanks
Offline
Jul 13, 2008, 07:38 AM
any opinions on the turbo xs utec?
Offline
Jul 13, 2008, 08:11 PM
Personal Sales Rating: ( 1)
Drives: no more Evo
Waste of money and the tune isnt as solid as using the stock ecu.
Offline
Jul 20, 2008, 01:05 PM
Personal Sales Rating: ( 16)
Drives: '03 evo VIII BBY(sold!), '95 Talon ESI-Turbo'd, '90 Mirage 4g63
Use the stock ECU with the map switching patch. Some meth kits can be incorporated to automatically switch to the safer maps (Aquamist,AEM and a few others so far) if there is a failsafe triggered. Also, you can incorporate your Zeitronix WB's alarm output feature to trigger the safer maps at the same time for double the safety. For pennies you can have more protection than you can imagine.
You can also have a manual bypass so you can shut off the alky kit completely and run on your "pump gas" tune only. The AEM kit uses the same bypass switch with the alt-map harness to turn on/off the alky kit while at the same time switching between the respective maps all at once. The Aquamist harness is set up so if you turn the Alky kit off with the on/off button on the monitoring gauge, it switches maps as well.
__________________
New VDR 5.71 Launched on 9/04/2009!! Now can be used for ANY vehicle, presets for all Evo 7,8,9,10 models!
CLICK HERE TO DOWNLOAD 'Virtual Dyno Room v5.71' !
'90 Mirage hatchback 4g63 and Evo8 ECU powered!
VDR 5.71 (EvoM Mode)=300whp/268wtq (thru stock 1.5" exhaust!)
'03 BBY Evo 8 (sold)
VDR 5.71 (EvoM Mode)=339whp/335wtq
Best 1/4 Mile: 12.2@113mph
'95 Eagle Talon non-turbo ATX......turbo'd
Best 1/4 Mile: 13.99@101mph
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
