Jan 4, 2008, 10:33 PM
Personal Sales Rating: ( 4)
Drives: 2005 Mitsubishi Evo 8
Differnce between M1 and M3?
could someone put some light on this? the differnce in the 2. and what one is better? is one better than the other? thanks
__________________
Frankie's 2005 EVO 8 (stock turbo),B/R STAGE 1, 2, & 3 KIT: (I do have half of 4 and half of 5)
BR TBE
BR MBC
BR AIR FILTER
BR FUEL PUMP
BR UPPER & LOWER INERCOOLER PIPE
BR RACE BATTERY
BR RACE FRONT MOUNT I/C
BR PORTED EXHUST MANIFOLD
EPM O2
HKS 272 CAMS
EXDEY TWIN DISC CLUTCH
FORGE BOV
COOLING MIST KIT
ARP HEAD STUDS
BUSHWAKER TRANNY
SHEP STAGE 2 T-CASE
93 OCT - 20/80METH
Jester Dyno Tune
1.8-60FT.- 12.1@113MPH
Offline
Jan 5, 2008, 02:55 AM
Drives: a drunken IX
stick to M1
M3 has additives added that might potentially cause issues to pump parts.
Offline
Jan 6, 2008, 01:57 AM
thanks but still would like the low down on the 2.
__________________
BR TBE
BR MBC
BR AIR FILTER
BR FUEL PUMP
BR RACE BATTERY
EPM O2
HKS 272 CAMS
FORGE BOV
COOLING MIST KIT
ARP HEAD STUDS
BUSHWAKER TRANNY
SHEP STAGE 2 T-CASE
93 OCT - 20/80METH
Jester Dyno Tune
Offline
Mar 1, 2008, 11:04 AM
Personal Sales Rating: ( 8)
2003 Mitsubishi Lancer Evolution
Drives: EVO IX
lowdown
METHANOL
M1™
M1 Racing Methanol has a 99.95% minimum purity - the highest purity available in the U.S. With M1, engines run cooler and are less subject to corrosion. VP uses only lined drums which prohibit rust, corrosion and metal deposits that can contaminate fuel delivery systems. Recommended for all methanol-legal racing applications.
M3™
Like M1, M3 starts with methanol of the highest purity, but includes lubrication and combustion additives for an extra boost. M3 offers a wider range of jetting options, making jetting easier and more consistent. For bracket racers, variations in ET from run to run will be substantially reduced. With better tuning and cleaner, more efficient combustion, M3 makes more power and yields better throttle response than any standard methanol on the market. M3's improved combustion also reduces the noxious fumes associated with methanol fuels, so it's much easier on the eyes and nose. For 60-70% of methanol applications, M3 won't require jetting or timing changes-just pour it in and get an immediate performance improvement in all areas. In the other 30-40%, M3's added vaporization may actually hurt volumetric efficiency and performance, which is what lead to the development of M5. M3 is not pure methanol and won't pass a water test.
Offline
Apr 28, 2008, 09:38 AM
Personal Sales Rating: ( 16)
I've been using M1 for years - I would stick with M1 until more research/reviews are provided on M5...
Offline
May 21, 2008, 08:44 PM
Personal Sales Rating: ( 0)
Drives: '91 Black TSI, '07 Blue STI, '05 Silver MDX, '08 Outlander
Anyone using/tried M5? I know M1 is the best #$*# out there, but I was thinking about M3/M5....
__________________
"We were only at 56psi of boost with plenty of tuning and timing left" - Shep
Offline
Jun 3, 2008, 07:06 PM
Personal Sales Rating: ( 13)
Drives: 2005 Evo
M1 Ftw
Offline
Oct 12, 2008, 07:30 PM
Personal Sales Rating: ( 2)
Drives: EVO 8
i use m1.. the m3 have oxigenation.. so i havent try it!
Offline
Oct 25, 2008, 08:22 PM
Drives: '03 Evo
Quote:
Have you come across the thread I started...good info
VP M1 vs M2 Methanol
__________________
350 AWHP 348 AWTQ @ 26 PSI
(Tuned by AMS)
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
