Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Advanced > Water/Alcohol Injection
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Dec 27, 2007, 05:15 PM   #1
Personal Sales Rating: (5)
05evoGSR's Avatar
Drives: Supercharged 87 5.0 Mustang GT (sold); 2005 Black Evo GSR and a 2007 Suzuki GSX-R 600
Send a message via AIM to 05evoGSR
dealer filled my meth tank with washerfluid...
so yea, as the title reads the dealer filled my meth tank with washerfluid. I am using my stock washer tank as my reservoir and didnt realize they mixed it after my free service. The other night i was getting on it and everything was going fine then at the top end of 5th gear the car stumbled for a second and i got off of it, then realized i had about a half tank of 100% meth and half a tank of i guess 50/50 blue washer fluid. The car seems fine but im wondering if there was some damage done that i havent noticed yet? Yes first thing tomorrow i am going to drain the tank and refill with straight meth but am a lil worried i sprayed that mix into my engine through 4th and 5th gear. Let me know, thanks guys.
__________________
- Buschur catless TBE
- Injen intake w/upper IC pipe
- AMS lower IC pipe
- Ebay FMIC
- 255lph fuel pump
- Hallman MBC
- Greddy Type-S BOV
- GSC S1 cams
- Snow Perforamce meth kit
- Custom TT tune @ 28psi 100% meth
2005 GSR 382.5WHP 407.5TQ Dynojet
12.044 @114mph 1.67 60ft
http://www.myspace.com/05evolution
Offline
Old Dec 27, 2007, 05:21 PM   #2
Former Vendor
Personal Sales Rating: (107)
Curt@MrLed's Avatar
Drives: www.
prob. a little knock.
if it didnt blow up when you were on it, then your fine. check your plugs for signs of detonation or peices of motor.
you have that much power and no wideband?
Offline
Old Dec 27, 2007, 05:23 PM   #3
Personal Sales Rating: (4)
Tarmacisback69's Avatar
Drives: 2006 Evo Ix Mr
Send a message via AIM to Tarmacisback69
there should be no worrys, i actually heard of people using washer fluid because it contains alcohol in it. your car should be fine. but dont take the ****. drain it and put meth back in it.
__________________
Pecision Psi
Glen burnie, maryland
Offline
Old Dec 27, 2007, 05:25 PM   #4
SlowCar's Avatar
Drives: a drunken IX
how big is your meth nozzle?
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Dec 27, 2007, 05:49 PM   #5
05evoGSR's Avatar
the car is running fine but ill go over a few things tomorrow to make sure like coolant level is where it should be and the plugs are ok. No CEL light came on either. Im going to pump the tank out from the hose that connects to the sprayers on the hood and then disconnect the line from the meth nozzle and flush that out to make sure all the washerfluid is out.
I am using the biggest nozzle that comes with the snow kit i got from Dan at UCC.
And no i dont have a wideband, i should get one but havent got around to it yet. Im stock ECU, turbo and engine and never mess with anything so not really needed in my opinion. If i was messing with boost levels and tuning then i would def have one.
__________________
- AMS lower IC pipe
- Ebay FMIC
- 255lph fuel pump
- Hallman MBC
- Greddy Type-S BOV
- GSC S1 cams
Offline
Old Dec 27, 2007, 05:52 PM   #6
05evoGSR's Avatar
main thing i was worried about was i am not sure what else is in normal off the shelf washerfluid. Im sure they have cleaners, dyes, and who knows what else and not sure if that would F anything up in the engine besides causing some knock.
__________________
- AMS lower IC pipe
- Ebay FMIC
- 255lph fuel pump
- Hallman MBC
- Greddy Type-S BOV
- GSC S1 cams
Offline
Old Dec 27, 2007, 06:00 PM   #7
SlowCar's Avatar
it will just color your intake blue thats about it...
when you got tuned...do you know what your AFR was at?
__________________
Offline
Old Dec 27, 2007, 06:04 PM   #8
05evoGSR's Avatar
dont remember what the AF was at but i know i was in 96 degree heat with zero counts of knock so it was a very conservative tune
__________________
- AMS lower IC pipe
- Ebay FMIC
- 255lph fuel pump
- Hallman MBC
- Greddy Type-S BOV
- GSC S1 cams
Offline
Old Dec 27, 2007, 06:05 PM   #9
Former Vendor
Curt@MrLed's Avatar
Drives: www.
wrong, you have a modded evo.. there are numerous things that can happen. bad 02 for example. the computer may not pick it up till its to late.. your gas milage could slowly decrease from a bad 02.. its slight so you dont notice. if you have a wideband youll see it.. if you get a boost leak, you may not know or hear it, but the o2 will see it.
if something was wrong with your meth kit, you would know it before you blew the car up, or made a thread asking if anything is wrong with my car.
Offline
Old Dec 27, 2007, 06:07 PM   #10
SlowCar's Avatar
you should be fine - check plugs like mentioned to ease your mind.
__________________
Offline
Old Dec 27, 2007, 06:14 PM   #11
05evoGSR's Avatar
im still waiting on my failsafe from Dan, and i will prob install a wideband at the same time because yes i know it is a huge safe guard against amost anything that might threaten your engine.
Thanks SlowCar, i was pretty sure there was nothing to worry about but just wanted to double check.
__________________
- AMS lower IC pipe
- Ebay FMIC
- 255lph fuel pump
- Hallman MBC
- Greddy Type-S BOV
- GSC S1 cams
Offline
Old Dec 27, 2007, 06:20 PM   #12
SlowCar's Avatar
Dan UCC? snow gets their failsafe from labonte, you can go direct to labonte, might be quicker.
i like the zeitronix zt2 for afr and boost - check them out. also i think you can log flow sensor voltage with it.
__________________
Offline
Old Dec 27, 2007, 06:27 PM   #13
Personal Sales Rating: (1)
housedj's Avatar
Drives: 03 Dandelion Yellow EVO8 (7.5), 06 Land Rover LR3 HSE,
ur sig says custom tune. sounds like "messing w/boost" to me.
i picked up a wideband b4 i even had a tune so i knew where my AFR's were prior to the tune. i'm only making 324whp/368tq w/out cams & i use a wideband + ur stock o2 is narrowband so u will also have more flexibility in ur tune which means ur sig can say the car runs 11's...
just my 2 Lincolns.
__________________
2003 Dandelion Yellow EVO8:
Go Power- Espelir, Turbo XS, ETS, Invidia, Tilton, Walbro, Perrin, Dejon Tool, Hallman, NGK Iridium, Koyo, Ralliart, Sunoco 110, Redline, Eneos, BG Synchroshift, MOTUL, Buschur Racing, Invidia
Turn Power-
Cusco, RMR, Whiteline, Perrin, Advan
Stop Power-
DBA, Goodridge, Project Mu, ATE Super Blue, Brembo
I.C.E. Power- Pioneer, Alpine, Niche Audio, Autotek, Monster Cable, Rockford Fosgate, Optima, Sony Xplod, Sony Hi-MD Japan
Sponsored By:
All The Haters
Offline
Old Dec 27, 2007, 06:28 PM   #14
housedj's Avatar
also if ur gonna go to the dealer, u might wanna label that tank to prevent this issue again
__________________
Turn Power-
Stop Power-
Sponsored By:
All The Haters
Offline
Old Jan 3, 2008, 07:44 PM   #15
Personal Sales Rating: (122)
Ultimate CC's Avatar
Drives: 1983 Chevrolet K10 Stepside Pickup
Send a message via AIM to Ultimate CC
snow doesn't get their failsafes from labonte, labonte used to make failsafes FOR snow...they are no longer one in the same, two separate companies...
Offline
Tags
meth, tank
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
