Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 28, 2009, 04:10 PM   #1
Personal Sales Rating: (6)
scheides's Avatar
Drives: 05 Evo8 SSL
VP M1 Color
I thought this stuff was supposed to be blue? I'm pouring it out and its definitely got a yellowish tint to it. Got it from a sealed VP M1 container. Haven't ran the car with it yet, but hoping that switching to M1 will give me a bit of an edge over my previous 'brandX' methanol.
Offline
Old Sep 28, 2009, 04:16 PM   #2
Personal Sales Rating: (18)
Drives: Evo V///, GSXR 1000
should be clear.
Offline
Old Sep 28, 2009, 05:51 PM   #3
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
Put a few drop into a clean glass of water, it is goes cloudy momentarily, it is not good.
__________________
richard@aquamist.co.uk
Offline
Old Sep 28, 2009, 08:46 PM   #4
scheides's Avatar
Drives: 05 Evo8 SSL
I mixed a bit; it did get cloudy but not until I added a fair amount, not a few drops.
I went ahead and video taped it Comments?
http://www.youtube.com/watch?v=zQQNIPtsh_I
Offline
Old Sep 28, 2009, 09:17 PM   #5
Personal Sales Rating: (0)
URBANRCR's Avatar
It should be clear most pure methanol is the only time they are blue is if has an additive or they have just added the color(red or blue are most common).As long as the container was sealed correctly it shouldn't absorb moisture lowering its purity.
__________________
-Jason
Offline
Old Sep 29, 2009, 02:04 AM   #6
Silver Sponsor
Good video, I can clerarly see the cloudyness after mixing.
Possible the next test would be pouring some onto a piece of white paper and let it dry in room temperature, if there is oil or contamination, it will be left on the paper.
This will only work if the addictive has a slightly higher boiling point than methanol.
__________________
Offline
Old Sep 29, 2009, 12:53 PM   #7
scheides's Avatar
Drives: 05 Evo8 SSL
Methanol + water = milky
It did get warm as it was mixed, so that's a good sign...it also didn't really smell sweet or anything, it pretty much didn't smell at all...I have a bad sense of smell though... but it was def not blue.
Offline
Old Sep 29, 2009, 02:32 PM   #8
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
did u get the whole sealed drum or was it siphoned out of a sealed drum?
methanol is completely miscible with water in any proportion. only when its contaminated with fuel/organics that you will form the colloid, making the cloudy/milky appearance.
a similar effect happens with absinthe(ethanol + plant extracts/organics) + water. the organics slowly come out of solution as water is added...
http://www.youtube.com/watch?v=40k7SkXi3Rc
another possibility for discolored methanol is from the metal container rusting, but that will not turn cloudy when mixed with water.
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Sep 29, 2009, 02:38 PM   #9
Personal Sales Rating: (8)
esevo's Avatar
Drives: WW IX RS
Send a message via AIM to esevo
^^^ Correct as always!
Sometimes the shops will use the same pump from Race fuels to methanols, which can be enough to contaminate a full 5 gallon tank of methanol, so be cautious to avoid that.
Good Luck!
Evan Smith
__________________
Full build in the making!!!
MANY PARTS FOR SALE:
http://forums.evolutionm.net/sale-pa...ml#post6471348
Offline
Old Sep 29, 2009, 07:35 PM   #10
scheides's Avatar
Drives: 05 Evo8 SSL
mmm...absinthe.. Yummy!
Like I said, I got this out of a SEALED container from VP.
Offline
Old Sep 30, 2009, 12:37 PM   #11
ChuckP's Avatar
Drives: 2006 GG IX MR
Send a message via AIM to ChuckP
When you mix water and methanol, i.e. a 50/50 mix. Is there any concern that they could separate in you tank and throw off your tune? I'm wondering if the water rises to the top.
__________________
GG IX MR - 353whp/347wtq Bryan@GST Tuned
Offline
Old Sep 30, 2009, 12:54 PM   #12
scheides's Avatar
Drives: 05 Evo8 SSL
^ I don't think so, they should mix together. Even if they don't, simply driving your car would stir it up
Well I mixed up a batch of 75/25 M1/water and put it in the tank with about 1/8 50/50 left in it. I did a few pulls to make sure the new mix was flowing through, and sure enough, AFR's richened up a tish (about .3-.5AFR) and the car feels like a monster, maybe a bit more than before. I threw a bit more timing at it and just like before it wants to knock on spool-up...if I start a pull at like 2000rpm and rev it out, no knock. So, I'll prolly just go back to my old tune and leave it as-is, the car feels fantastic.
Offline
Old Sep 30, 2009, 04:02 PM   #13
ChuckP's Avatar
What kit? and what size jets?
__________________
Offline
Tags
cost, ethanol, fuel, m1, vp
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
