Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Sep 24, 2009, 06:04 PM   #1
Personal Sales Rating: (0)
alex750803's Avatar
Drives: Evolution VI (CP9A)
Cool Using Meth with C16
Hello, Can I run a Meth/Water Injection Kit with C16 race Gas? I would normally be using 95 Octane pump gas during the week and would like to use C16 on the weekends Can this be done utilizing a Meth kit or should I just turn off the Meth kit when running the C16 and turn it back on for the Pump Gas? Thanks
1999 Lancer Evolution VI - AMS VSR Intake Manifold, AMS UICP/LICP, AMS FMIC, Fuelab Pump, Snow Performance Stage 3 Meth Kit, 10AN Feed - 8AN Return fuel lines, Apexi PowerFC D-Jetro ECU, OKADA Plasma Direct Ignition, Stock Evo 8 Turbo, 560cc Injectors... and some more bits and bites
Offline
Old Sep 24, 2009, 11:19 PM   #2
Personal Sales Rating: (8)
esevo's Avatar
Drives: WW IX RS
Send a message via AIM to esevo
If the meth kit is used primarily for cooling the charged air, then yes. You will see power from denser air.(Just like a bigger ic) If using meth just for octane (like most do) then no it wont be a big help. Add 50% water in there and turn the timing up and lean it out to 12.0-12.5 afrs and you will see great results. You have the coil packs for it!
Good Luck
Evan Smith
__________________
Full build in the making!!!
MANY PARTS FOR SALE:
http://forums.evolutionm.net/sale-pa...ml#post6471348
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
