Sep 23, 2009, 05:07 PM
Personal Sales Rating: ( 6)
Drives: 2006 GG IX MR
Aquamist - Choosing a restrictor size
If i am running the .8mm & .9mm jets with my HFS-6, do i use a restrictor? if so, what size should i put in?
Online
Sep 23, 2009, 05:31 PM
Silver Sponsor
Personal Sales Rating: ( 5)
Drives: Citreon Xsara
Leave the restrictor out. You need to oversize it so if there is a leak, the failsafe will detect it.
__________________
richard@aquamist.co.uk
Offline
Sep 23, 2009, 05:36 PM
Will do. Thanks Richard
Online
Sep 23, 2009, 08:42 PM
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
So should the restrictor size be based on your jet size - or your flow size?
for example if I need to flow 500cc/min, but I have decided to use 3x 1.0mm jets (so I _could_ flow 1500+ cc/min) do I choose the 0.7mm restrictor (0-680cc/min) OR no restrictor?
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Sep 24, 2009, 05:55 PM
Silver Sponsor
Restrictor is based on flow.
Add up your jets and pick the nearest restrictor above. Do not go lower otherwise the failsafe will not be able to detect a leak or cut hose.
for 500cc/min go for a 0.7mm restrictor. If you go for 3x 1mm (1500+ cc/min), then no restrictor.
__________________
Offline
Sep 24, 2009, 06:40 PM
Drives: WW EvoX GSR
But is it based on actual flow? OR max possible flow?
In my exact case:
I only _need_ 1x 0.8mm jet. However I have opted for 2x 0.8mm jets.
Do you see my qandry?
I will ACTUALLY be flowing about 450cc/min. So do I choose 0.7mm restrictor?
OR
Because I have the capability to flow ~900cc/min do I go with 0.9mm restrictor?
__________________
Offline
Sep 25, 2009, 01:58 AM
Silver Sponsor
Yes, the restrictor is based on maximum flow.
In your case:
1x 0.8mm use 0.7mm restrictor
2x 0.8mm use 0.9mm restrictor
It is quite easy to change restrictors. The jet adaptor comes with a banking plug. If you are using one 0.8mm jet, just plug one up.
We are going to reduce the flow capacity of ther inline valve to ~1200 cc/min in the next few months. At present, we don't have any one using more than 2x 1mm jet. This will simplify the restrictor selection.
__________________
Offline
Sep 25, 2009, 02:05 AM
Drives: WW EvoX GSR
awesome thx!
burnzy will be sending me his spare 0.5mm jet, so I think in the end I will just go for a 0.8 + 0.5, so still require a 0.9mm restrictor (723cc/min max from 0.5+0.8)
__________________
Offline
Sep 26, 2009, 02:26 AM
Silver Sponsor
Now, you now the set up to run W100%. W50/M50 and M100%. All you need is fitting three maps into your patch
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
