Sep 4, 2009, 09:07 PM
Personal Sales Rating: ( 3)
Drives: WW EvoX GSR
Project X - Water/Meth Install!
Hi Guys,
Righty this will be a work log hopefully
Feel free to chime in with ideas/suggestions
Proposed Mounting position:
What are your thoughts on using some 8mm particle board (or 2 or 3mm sheet aluminum) mounted flat with bolts at the red circles?
My main concern is the amount of flex such a large space...
Cheers
D.
__________________
AUDM Black Evo IX 07 spec - writeoff thanks to someone that doesn't understand what a STOP sign is!
AUDM Yellow Evo IX - writeoff thanks to me rolling it at the Phillip Island Grand Prix Circuit :(
AUDM White Evo X - Powered by Colby@Tactrix, Richard@Aquamist
TephraMOD V7 - ECU mods AltMap, NLTS, KnockLight, Valet, Boost Mods, BIGMAP + more
yes - I have given up emptying my Inbox
Michael Jackson - RIP!
Offline
Sep 4, 2009, 09:54 PM
Personal Sales Rating: ( 0)
Drives: JDM Evo7
Any idea of the weight that will be placed on the board?
If you can get a weight figure, and approx G-forces then you can calculate the flex.
If it were me, i'd screw 2-3 thin cuts of particle board ~5cm wide, just under the width of the board onto the rear of it to give it strength.
__________________
Belting a Sooby a day keeps the doctor away! :D
WW JDM E7 - 212wkw @ 1.55bar
PFC - 8MR turbo - RM01A/Tomei Expreme TBE - Kansai box/RS intake - SBCid3 EBC
Offline
Sep 4, 2009, 09:58 PM
Personal Sales Rating: ( 7)
Drives: Tarmac Black IX SE- Blown Transfer Case
can you use strips of aluminum in a "cross" shape on the back of your sheet to re-enforce it?
Offline
Sep 4, 2009, 11:34 PM
Drives: WW EvoX GSR
weight will be:
possibly 2x 5QT tank - 12kg total
1 pump - 3kg total
So I reckon 15kg total.
Normally driving you would not exceed 1G, however in an accident you might go WAY above that.
Yeah I see what you mean, if you can have something coming up from the bottom that will help brace it
I have contacted a local aluminum fabber, i will see what he thinks too!
possibly
__________________
Offline
Sep 5, 2009, 06:05 AM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: Citreon Xsara
Using an trimmed angle iron might work.
__________________
richard@aquamist.co.uk
Offline
Sep 5, 2009, 07:27 AM
Drives: WW EvoX GSR
ahh yeah...
i was thinking something similar..
even just a thicker brace rather than angle... might see what the guy has lying around...
i was thinking some 7075 grade  hehe
__________________
Offline
Sep 5, 2009, 08:20 AM
Drives: WW EvoX GSR
actually thinking about it:
i think i will try and get the bottom edge bent towards the rear of the car... that should provide the "angle" and add a lot of strength...
__________________
Offline
Sep 5, 2009, 09:04 AM
Personal Sales Rating: ( 1)
Drives: 03 lancer evolution 8
Richard has this posted in his hfs-5 q&a post. Here is a link... Aquamist HFS-5 system: Official Q&A....
Post #32
__________________
3" tbe, GSC S1's, Aquamist hfs-1 100% meth, Greddy cam gears, Injen IC hard pipes & intake, ACT hdss clutch w/ Prolight flywheel, Walbro 255 lph, Greddy Profec B Spec 2 ebc, Fp Red 80mm, Syncronic BPV, ETS 3.5" IC
Offline
Sep 5, 2009, 07:13 PM
Drives: WW EvoX GSR
yeh but its requires a different setup on the X
__________________
Offline
Sep 7, 2009, 08:52 PM
Drives: WW EvoX GSR
ok guys I need some advice:
USP 6QT = 41 cm high
USP 5QT = 35 cm high
Vertical space in the boot is about 47cm
Concerning refills do you think going the 5QT is best? Obviously I will still need a LONG hose..
Or do you think go for 6QT given that I have to use a hose anyways..
I was going to go for 2 tanks side-by-side anyways, so its either 10QT or 12QT total...
__________________
Offline
Sep 12, 2009, 04:40 AM
Drives: WW EvoX GSR
I have decided on the 5QT... It will just be easier to deal with when refilling
Been talking to Jeff@Howerton about some extra bits'n'bobs to hook up 2 tanks... Should have that soon with some pictures
__________________
Offline
Sep 13, 2009, 04:08 AM
Drives: WW EvoX GSR
lol - I changed my mind to the 6QT... I also ordered a cheap pump to make refilling a LOT easier
ok all coming together now
BIG thanks to Jon@HBSpeed for collecting everything and shipping to me in Oz
__________________
Offline
Sep 13, 2009, 10:42 AM
Silver Sponsor
It appears that you are racing a lot, what is the average duration of each race? I was trying to estimate how long will a 12 quart supply last.
__________________
Offline
Sep 13, 2009, 04:59 PM
Drives: WW EvoX GSR
well i probably wont race this car... too expensive  lol
but if I did its about 10 mins a session...
__________________
Offline
Sep 13, 2009, 05:15 PM
Silver Sponsor
10 Mins is quite a long race.
__________________
Offline
Tags
evom, evox, howto, inject, injection, install, installation, jet, meth, pre, projek, run, turbo, water, watermeth, wideband  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
