Labonte Meth Kit Help
Normally the meth gauge sits at 000 until it's spraying under WOT and my green LED lights up. Last night rolling into WOT in 2nd gear the green light lit up for a second, then the red lit up for a second and I came out of it thinking something was wrong. I looked at the gauge and it's now flickering between 002 and 003 while not at WOT and when I do go into WOT my green LED doesn't light up (nor do the yellow or red). Car does seem to be running about .8 leaner (per wideband) as if something isn't working properly.
I've checked all the hardware as far as loose connections go (grounds, fittings, etc) and everything still seems to be snug and intact. I do have meth in the tank and the cap does have a small breather hole. I'm not sure how or what to test next. Perhaps someone has had this issue before? Or could advise what I should be looking into?
Thanks.
Labonte Hardware:
IFG-20, ISG-13, VC-25D, FLS-10, IFS-10
__________________
^5
