Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 31, 2009, 02:52 PM   #1
Personal Sales Rating: (6)
ChuckP's Avatar
Drives: 2006 GG IX MR
Send a message via AIM to ChuckP
Zeitronix ZAVT, HFS-6; Use both as failsafes?
For you guys with the ZT-2 and Aquamist kits, how did you setup your failsafes?
I have the ZAVT warning box to install along with the Aquamist HFS-6 kit.
I believe the aqamist kit will trigger my alt maps in the event of low or no flow through the pink wire, when paired with the map switching harness. Can i just tap the ZAVT trigger wire into the same wire on he map switching harness?
Is this the correct map switching harness that i will need?
http://www.dsm-ezine.com/orderpage2.html
Thanks.
Offline
Old Jul 31, 2009, 03:26 PM   #2
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
Are you running 100% methanol?
__________________
richard@aquamist.co.uk
Offline
Old Jul 31, 2009, 03:28 PM   #3
ChuckP's Avatar
Quote:
No, i will be running 50/50 or 72m/25w. have not yet decided.
Offline
Old Jul 31, 2009, 06:25 PM   #4
Silver Sponsor
Will ZT2 reliably detect the diluted meth?
Meth has a stoichometric value of 6.6:1 and x3 the latent heat of Gasoline. If yopu are running 20% w/m injection to fuel, a large drop in injection flow will only register a small change on the AFR, but significant drop in in-cyclinder cooling capacity.
__________________
Offline
Old Jul 31, 2009, 07:56 PM   #5
ChuckP's Avatar
I was referring to the complex warnings they offer. For example: >70% TPS, boost >22psi, AFR >12.5, then it sets off an alarm (ZAVT) and uses the relay box to trigger map switching. Hopefully im making myself clear.
Offline
Old Aug 10, 2009, 02:42 AM   #6
Silver Sponsor
You can never have too much failsafes.
With the zeithronix, you can guard against EGT, AFR and etc. H6 will only tell you if the methanol is flowing or not.
__________________
Offline
Tags
flow, hfs6, kit, wiring, zavt, zeitronix
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
