Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 22, 2009, 06:14 PM   #1
Personal Sales Rating: (1)
Drives: Evo 6 TME
Intake temperatures and pre turbo injection
How many people out there are using pre turbo water/meth injection and what sort of intake temperatures to you get?
I've just installed my kit with small injector pre turbo and larger injector 12" back from throttle body and have been recording temperatures at the throttle body.
So far with 11psi boost without water/meth temperatures are hitting 190+ deg Celsius
With water/meth the temperatures are about 170 deg C.
I should also mention I removed the intercooler with the hope of getting similar effectiveness from the pre turbo injection. Unfortunately I didn't measure the temp at throttle body before I removed it so will probably refit it for further testing.
Offline
Old Jul 22, 2009, 08:27 PM   #2
Personal Sales Rating: (6)
scheides's Avatar
Drives: 05 Evo8 SSL
Do it and post the results! I've jokingly told others to do this, would be great to see some solid numbers!
Offline
Old Jul 23, 2009, 01:37 AM   #3
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
Quote:
Here are some charts you might like to see for pre-turbo injection and others.
http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=559
Didn't mean to hijack but within context.
__________________
richard@aquamist.co.uk
Offline
Old Jul 23, 2009, 03:04 AM   #4
Drives: Evo 6 TME
Thanks for that....they definitely add merit to the discussion.
If I'm reading the article right the guy had 30 deg temps at the throttle body with no WI and when he did inject it got hotter???
Next week I'll change the pre turbo injector to a bigger one and see what happens.
If anyone has any other results then please reply!!!
Cheers
Offline
Old Jul 23, 2009, 11:57 AM   #5
Silver Sponsor
I am not sure why, perhaps there are other factors. I have not looked into in detail.
__________________
Offline
Old Aug 1, 2009, 04:34 AM   #6
Drives: Evo 6 TME
Bit of an update.....
Put biggest injector nozzle I have in before the turbo and a matching one a foot before the throttle but measured air temps are still in excess of 170 deg Celsius without water/meth.
I got a new piece of hardware to specifically record temperatures on my laptop but the response time is too slow to be of any use so temps are only being logged via the "mate" system strapped to the passengers seat
Put intercooler back on (no small feat) and did a few tests today. Temperatures seem a lot more stable, they fluctuated rapidly with no cooler but now they are smooth changes.
Testing out high loads I got 170 deg Celsius @29psi of boost with the cooler on and no water/meth. This is the same temperature I got with no cooler @ 11psi with water/meth.
More testing to come tomorrow....
Offline
Old Aug 10, 2009, 03:48 PM   #7
Personal Sales Rating: (0)
Drives: Evo7 GSR
I'm interested in pre turbo injection. Is this safe with 50/50 meth water?
MB
__________________
3 inch TBE, 255 Walbro, Hi Flow sports cat, drop in JR panel, air box mod, ECUplus, ECUflash.
Offline
Old Aug 10, 2009, 04:51 PM   #8
Personal Sales Rating: (9)
Drives: 06 IX
From what I have read, it is safer to inject 100% meth pre-turbo, versus 50/50 or 100% H2o because the specific gravity of pure methanol is .792 @ 68° F compared to water which is 1.00 @ 64° F.
__________________
For Sale...
Stock Fuel Pump
Stock underpanel
stock cams
stock springs+retainers
(all parts have 3,000 miles and in excellent shape)
http://forums.evolutionm.net/sale-engine-drivetrain-power/300701-stock-ix-parts-sale.html
Offline
Old Aug 10, 2009, 08:17 PM   #9
Drives: Daihatsu Move
So you are only seeing a 20C drop with spray? What % and how much are you spraying? Progressive controller, settings etc. Have you tried with just the preturbo nozzle?
Another longer one to read is this one
http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=267
Remember that water will not reduce your intake temps, it's for the CC, meth is for the pipes. The IM on mine was much cooler at 50% meth than it was at 25%, and 12% didn't do anything to the IM.
Offline
Old Aug 21, 2009, 04:23 PM   #10
Personal Sales Rating: (8)
Drives: goggles and a speedo
Quote:
Maybe the sensor heat soaked quicker from the moisture for the duration of the run. Or maybe the cooler became saturated and lost it's effect. Who knows, but the pre-turbo method was implemented years ago in turbo buick days as a method to go without intercooling
I will be trying a very small nozzle spraying right into the compressor wheel, an on/off rig with a seperate pump, it's ground will just go over a hobbs switch for now. The orignal pre-TB system will still be in place and running.
Just avoid any possible puddling conditions which will eat the compressor wheel ends. And the more you spray, the more O2 will be displaced, but this can be overcome with denser charge. Just need to find the sweet spot
Offline
Tags
cooler, inj, injection, injector, intake, meth, pre, preturbo, temperatures, temps, throttle, tune, turbo, water, watermeth
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
