Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jul 1, 2009, 12:47 PM   #1
Personal Sales Rating: (6)
scheides's Avatar
Drives: 05 Evo8 SSL
Dyno Results! BBK on pump vs alky: Aquamist HFS-1 FTW!
Original thread posted in dyno section:
BBK / MAP Stg3 head /DB Performance tuning Dyno Results! Pump Gas & Alky!
I wanted to make special note here demonstrating the power-adding capability of solid alky injection setup. I'm running the Aquamist HFS-1 with 2 jets: 1.0mm and .9mm, for a total volume of ~950cc/min. I'm running some black-label (got it from a buddy) Methanol 50/50 with distilled water. I'm also using tephra v7t6's mapswitching functionality on the stock ECU.
Basically +50whp / +50wtq with the alky on, and tuned. Both pump gas and alky maps are fully tuned. Pump is 25psi, alky on is 30psi (peak) tapering to 25 @ 8000rpm.
Online
Old Jul 2, 2009, 11:18 AM   #2
Silver Sponsor
Personal Sales Rating: (4)
Drives: Citreon Xsara
This is the first meaningful comparison between the pump and 50:50. I wonder if running 100% will yield more power?
Thank for the post, a very good reference.
__________________
richard@aquamist.co.uk
Offline
Old Jul 2, 2009, 11:49 AM   #3
Personal Sales Rating: (50)
inco9nito99's Avatar
Drives: '06 RR IX RS / '99 Maroon GSX
Send a message via AIM to inco9nito99
Nice Chris! Definitely try 30psi and 100% meth . It'd be nice to overlay three maps to see the power potential on 93 pump & 25psi, 50/50% water/meth & 30psi and 100% meth & 30psi.
__________________
◄ ◄ K U N i i i Z Z Z E E E ► ►
"OCD isn't a disease..it's a lifestyle" -revvin9k
-||'06 RR E9 RS||-
ROBISPEC/// "...live a little!"
...powered by: żMagic?
Offline
Old Jul 2, 2009, 11:53 AM   #4
scheides's Avatar
Drives: 05 Evo8 SSL
I posted this last year:
Aquamist HFS-1, GM BCS, and Tephra v5: together at last!
That was on the IX turbo and I saw a 40whp/50wtq gain using denatured alcohol. I switched from denatured alcohol to 100% methanol, saw no discernible difference. Then went to 75/25 meth/water, and it felt the same after tuning. Now on 50/50 meth/water, I think this shows that with tuning, each is capable of nearly the same power advantage over just pump gas. I think the difference lies in the tuning, but I'm not even sure that will make a ton of difference either.
It has been said that 100% methanol tunes should target 11.0 AFR, 75/25 should target 11.3-11.4 AFR and 50/50 should target 11.8 AFR for best power results. I saw a negligible power difference going from 10.5 up to 11.8 while tuning, it was then adjusting timing that made the most difference.
Online
Old Jul 2, 2009, 12:00 PM   #5
scheides's Avatar
Drives: 05 Evo8 SSL
Quote:
Thanks! With what I said above combined with the other plusses of running 50/50 I think I'm going to be keeping it the way it is. The mixed price brings the cost/gallon down to a nice $5/gallon, the added cooling properties, and the lack of flamability all add up to a nice product that makes me happy. Plus, I'm running a 1.0 and a .9mm nozzle now, so there is still a great deal of methanol finding its way into each cylinder
Online
Old Jul 2, 2009, 12:10 PM   #6
Personal Sales Rating: (12)
DJ Brett B's Avatar
Drives: '06 Evo 9 MR, '95 4Runner
I run a BBK full with lots of bolt-ons.... I was around 320 whp max (Cobb mustang dyno, 4200 ft. elevation) on 22psi no meth (stock Evos run 200-220 max on this dyno)..... with the meth kit (AEM) on at 28.5 psi I hit 385whp/373wtq using mostly meth with a little bit of distilled water, somewhere around 80:20 or 90:10 ratio of meth/water... the little bit of water helps with cooling, but I mainly did higher meth content due to 91 octane crap is the highest pump gas available here in SLC .... saw at least a 65whp jump with meth and high boost
Offline
Old Jul 2, 2009, 12:14 PM   #7
DJ Brett B's Avatar
Quote:
Originally Posted by Richard L View Post
This is the first meanful comparison between the pump and 50:50. I wonder if running 100% will yield more power?
Also probably makes a difference if your pump gas is 91 vs. 93.... there is only so much boost you can run on 91 vs. 93 so I went higher meth content than water which meant instead of running 22psi I now run 28.5... the ratio I mentioned was recommended by the tuner @Cobb, but I am at a high altitude/91 octane, so different factors
Offline
Old Jul 2, 2009, 12:14 PM   #8
Personal Sales Rating: (18)
Cali2MDevo8's Avatar
Drives: BBK powered EVO 8
Send a message via AIM to Cali2MDevo8
Soo tempting. Gotta love the extra tq.
__________________
XBOX LIVE: PAgamer07
PSN: PA-gamer
PO172 code (not boost leak) ~~~>http://forums.evolutionm.net/evo-eng...need-help.html <~~~Please help me
Online
Old Jul 2, 2009, 12:19 PM   #9
scheides's Avatar
Drives: 05 Evo8 SSL
Quote:
Very good point! I am starting with BP93 as a base fuel. I actually tried running the car at 28psi on straight pump (peak) and it didn't really make much more torque but it was safe and didn't knock. Definitely I would go with a 75/25 mix if I wanted more octane in the mix.
Online
Old Jul 2, 2009, 11:53 PM   #10
wesside's Avatar
Drives: WW 05 Evo VIII RS
Send a message via AIM to wesside Send a message via MSN to wesside
Nice is that the bbk lite or bbk full? Wonder what the 100% would be
100% with my green tephra v5, ecu controlled boost @ 29psi tapering to 23psi and it was 398whp on a mustang dyno a few months back, now I've got buschur im & tb it could squeeze a few more hp out of it prob, I'm still on a stock fmic. If I remember right my afr was 11.3-11.7
I only run one 1.0mm jet with my hsf-1
__________________
V/// RS
Pimp Mode / Jdm ix rear / pump & 720cc/ Aquamist
Invidia / Cusco / Whiteline / Buschur Racing / Exedy
Defi / Greddy / Vishnu / Hks 272 / Fp Green /Mustang Dyno #'s 398whp 405tq :)
www.cardomain.com/id/wesside
PARTS FOR SALE!!!!
My Vboy Evo photHo Sh00t 2
Vboy photHoSh00t n Vid
http://www.myspace.com/wesside514
Offline
Old Jul 3, 2009, 09:20 AM   #11
scheides's Avatar
Drives: 05 Evo8 SSL
BBK Full.
Online
Tags
91, 93, alky, aquamist, dyno, injection, meth, pump, results, run, tuned
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
