Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 26, 2009, 10:34 AM   #1
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
HFS-6 Wiring Question
Quick question about the wiring diagram for the HFS-6. I know that it creates its own switched power and that's why it now requires positive and negative beyond just injector positive and negative.
If you look in the diagram I attached I am just wonerding if I can source power for the Unit as a hole, and power for the injector signal from the same place?
This is how I did it on the DDS3 v8 and just wanted to make sure that would still work with the HFS-6
Take a look at my diagram and see if it makes sense.
The two wires coming out of the plug going to the ECU are for Injector + and Injector -
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jun 27, 2009, 01:36 AM   #2
Silver Vendor
Vendor Sales Rating: (4)
Drives: Citreon Xsara
The proposed +12V supply wires (red) to the HFS-6 will work. I believe this location can supply more than 3A of current. YOuare correct, the HFS-6 creates its own fused switched 12V supply internally.
Red wire #1 (from yellow harness):
- Poweres up an internal "power-in" relay, draws about 30mA. This wire should only be connected to a known switched +12V at key position #2.
Beware! The evo uses inline resistor pack to the fuel injector+, do not connect this wire to the fuel injector+ directly.
Red wire #2 (4-pin plug):
- Main +12V supply to the HFS-6, draws ~2-3A of current maximum. This wire can be connected to any +12V supply such as - battery+, Ignition switched etc. As long as it can sustain 3A of continuous current.
Don't forget to wire the "white" wire (signal ground) of the 4-way connector to the chassis or ground.
__________________
richard@aquamist.co.uk
Offline
Old Jun 27, 2009, 06:17 PM   #3
dudical26's Avatar
Drives: IX GSR
thanks for the info Richard.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
