Jun 20, 2009, 07:27 PM
Personal Sales Rating: ( 1)
New to Meth, Best Kit to Start With?
Hey, a lot of tuners have suggested going with meth injection so I'm almost sold on the idea, I understand how it works but would like to know what's a good choice for a kit. I've only really heard of Snow, Aquamist and AEM's kit. What's the best choice as far as reliability, power, and tuning options?
Offline
Jun 21, 2009, 01:17 PM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: Citreon Xsara
Can you describe your set up, stock or heavily modified?
__________________
richard@aquamist.co.uk
Offline
Jun 21, 2009, 01:31 PM
Personal Sales Rating: ( 24)
Drives: evo 9
aquamist ftw
__________________
Newbie D40
some guy "Man i heard your mitec kick in"
me "no, you heard my o2 dump open"
HAHAHA
Be creative and have your own style, NOW STOP JOCKING ME!
R.I.P DJ Keewie.
Buschur Racing 35r..=) and meth
Offline
Jun 21, 2009, 03:12 PM
Quote:
I have Greddy TBE and O2 Housing, Injen Intake and Intercooler Piping, Hallman MBC, Walboro 255lph fuel pump, and I plan on doing cams, valvetrain, and a bigger front mount.
Offline
Jun 21, 2009, 04:02 PM
Silver Sponsor
I believe you still use the stock turbo, just ramping up the rev band with all the mods. I think you can go for most makes of WAI.
Your set up will demand a large amount of methanol at mid range so I guess a single point injection system such as the HFS-1 will work well. Until you are pushing for a bigger turbo, it may not be necessary to go for a IDC based system such as HFS-6.
Someone may charm in and help me with this...
__________________
Offline
Jun 21, 2009, 04:09 PM
I've been doing a lot of research on this the past couple of nights and I think as of right now I would go with the HFS-1. Just need to save for a little while as it's one of the more expensive kits I've looked into. But from what I hear it's worth it so rather do it right the first time.
Offline
Jun 21, 2009, 04:17 PM
And yes I'm still running the stock turbo.
Offline
Jun 21, 2009, 05:00 PM
Silver Sponsor
The Shurflo pump based HFS-1 has been changed to the Aquatec pump as from June 10 this year. As used on the HFS-6.
__________________
Offline
Jun 21, 2009, 06:20 PM
What's the difference between the two?
Offline
Jun 21, 2009, 08:10 PM
Personal Sales Rating: ( 7)
Drives: '05 AS Evo VIII (96940011)
I love Aquamist with its spiffy Gauge. I have the HSF-1
__________________
MODS
- CBRD BBK Full
- FIC 1050cc
- KELFORD 272 CAMS
- BC SPRINGS & Ti. RET.
- GATES
- AQUAMIST HSF-1
- SPEC Super Twin P-Trim
- INJEN A/I SYS w/Amsoil filter
- TIAL Q 50mm BOV
- 3" TURBO XS CATBACK
- eBay 3" TESTPIPE
- 3" MR DN PIPE
- MR HEADER
- ETS LICP
- ETS 3.5" FMIC
- EVODAVE HEADLIGHTS
- EVO 7 TAILS
- TEIN-S
- 255 F.PUMP
- Amsoil ATM 10w30
____________________________________________
4WSTuned! R.I.P. Westley Hess (12/30/2008)
North West Evolution!!
Offline
Aug 8, 2009, 02:25 AM
Personal Sales Rating: ( 0)
Drives: Lancer Evo IX SE
aqua mist kit over any other
Offline
Aug 8, 2009, 04:24 AM
Personal Sales Rating: ( 23)
Drives: 06 Evo MR
I have the AEM kit with an extra failsafe. So far it has worked flawlessly and I couldn't be happier.
Offline
Aug 8, 2009, 05:14 AM
Drives: 2006 EVO IXMR
You honestly don't need an $$$$$ setup like aquamist now that there are tons of safety featurs that people have figured out with the stock ECU. Auquamist is a great kit don't get me wrong. You should look into getting a cheaper kit like AEM and making it just as safe as Auquamist for hundreds cheaper. Talk to your tuner about the new Tephra mods for the stock ECU and ECU controlled boost with the AEM boost solenoid. Here is what I did with my kit.
AEM kit comes with 125cc 300cc 550cc meth jets (400.00)
Buy the failsafe from SnowPerformane (60.00)
Buy an M15 (1500cc meth jet) good for 425-475hp (15.00)
400hp switch from M05 to M10 Meth Jet with dyno This is my post about me switching to the M10 jet and I just recently switched to the M15 jet and pick up more hp because I could run more timing in higher RPMs. I just didn't make a post about the M15 jet.
__________________
Mikey's 2006 EVO IX MR: ER VIII 5speed, Magnus v5, 3.8" Garrett FMIC, ETS Short Route UICP, TurboSmart RacePort BOV, RC 880cc Injectors, Perrin Fuel Rail, Walbro 255, ARP Head Studs, HKS 272/280, HKS EBC, R/TErnie Ported Exhaust Manifold, R/TErnie Full 3" V-Band External Dump O2 housing, R/TErnie Modified Perrin 3" V-Band Downpipe, Nesei LICP, FP 25psi Wastegate, Apexi N1 Test-Back, AEM Meth kit (M15), Exedy Twin Plate, FP Red+30lbs+ER Tune = 520hp/406tq
http://www.myspace.com/blkcarbonevo
Offline
Aug 8, 2009, 05:50 AM
Silver Sponsor
I agree with everyone want to save $$$$. Only if the systems are comparable. The AEM is a PPS (progressive) system. The HFS-1 is a single stage (on/off) system and the HFS-6 is PWM valve system. Both comes with a 52mm dash gauge, display in real time, 3 failsafe output options - even in the event of a power supply failure. There are a few failsafe systems (no gauge) out there, sending out a active voltage upon activation. What "if" there is a power supply failure?
So the saving $$$$ comparison is not exactly accurate.
By the time you add a dash gauge system on those alternative systems, it will probably cost the same. In the event of a system incompatiblity issues who do you contact first?
__________________
Offline
Aug 8, 2009, 05:59 AM
Richard,
I am not knocking aquamist. You have the best kit on the market, period. I'm just trying to say that you can for less money make a kit that works and is just as safe as the aquamist. Yes, you will not have all the bells and flashy lights and dash candy but other kits work and work well. With the ability to safe gaurd your motor with the stock ECU and/or the AEM EMS, it honestly wouldn't matter if your pump quits in WOT. The stock ecu can add timing and/or bleed out the boost instantly with ecu controlled boost. That is if the fail safes don't work in the first place. TTP believes that running meth is now just as safe as running pump gas on a well setup car and with the new tephra mods.
There is not a question about who has the best kit on the Market. It is aquamist and I'm just being honest with what you can now do with the stock ECU. A few years ago I would have went with an aquamist kit too. Added reliability and security!
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
