Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jun 9, 2009, 10:40 AM   #1
Personal Sales Rating: (61)
evovin's Avatar
Drives: Evo 8
AIT ~140 Degrees....What's yours? Im thinking about putting Water Injection
My AIT is seeing from 115-140ish Degrees....(BTW that wasnt even boosting at all coz Im not tuned yet)
What's yours?
Im thinking about putting Water Injection just pass the outlet in the FMIC.
What do you guys think?
Will I benefit much?
Yes just water I just want it for cooling effect....not Octane substitue
__________________
10.90@129mph(sunnoco 116)
best trap 135mph
PT6262
Tuned by Mark @ TTR
TurboTrix Racing
http://www.turbotrix.com/wordpress/
SparkTech Ignitions
http://www.sparktechignitions.net/
Offline
Old Jun 9, 2009, 10:51 AM   #2
Personal Sales Rating: (0)
At the race track 37r@34psi on a Galant vr4
90 degree day outside
Idle beforerun AIT = 105
after 1st gear AIT = 113
after 2nd gear AIT = 122
after 3rd gear AIT = 134
after 4th gear AIT = 143
Now my intercooler sucks, and it was hot out, and I do not have a CAI on the car so it was sucking the air from right behind the radiator. Do you have an upgraded intercooler, and where is your intake pulling the air from. It sounds like it is just sucking the hot engine compartment are into your turbo. 140 degree intake temps sucks and will rob power.
Offline
Old Jun 9, 2009, 10:58 AM   #3
evovin's Avatar
Drives: Evo 8
yes. Imagine the temp if I boost...
I have 3.5 ETS fmic. My sensor is about 8 inch from BOV in ucip.
__________________
best trap 135mph
PT6262
Tuned by Mark @ TTR
TurboTrix Racing
SparkTech Ignitions
Offline
Old Jun 9, 2009, 01:12 PM   #4
Are you running an intake pipe or just leaving it open behind the radiator?
Here is my setup.
Offline
Old Jun 9, 2009, 04:26 PM   #5
evovin's Avatar
Drives: Evo 8
no. I have intake pipe w 9 inch filter
__________________
best trap 135mph
PT6262
Tuned by Mark @ TTR
TurboTrix Racing
SparkTech Ignitions
Offline
Old Jun 9, 2009, 10:05 PM   #6
Are you on an AEM EMS, or the Stock ECU with MAP? If so your AIT might not be setup correctly. I dont think it would be possible to see 140+ degree temps if you have an intake pipe. Put a new sensor in and see if that fixes the problem. Also check the settings for the sensor to make sure that the Voltage matches the air temp.
Another way to test the AIT is to pull it out of the car and data log and see what it reads. If you know the outside temp is 100 degrees and your AIT is reading 120 then there is something wrong.
Offline
Old Jun 9, 2009, 10:15 PM   #7
evovin's Avatar
Drives: Evo 8
Quote:
I have AEM EMS. Good idea I will check my sensor but I doubt its the sensor coz I always log(internal log) but the car was sitting for 2 months on the garage when I was waiting for my PT6262.
Im getting tuned in 2 weeks and Im expecting 630whp+(on race gas) and just dont want to be heat soaking thats why I thought of putting water injection maybe use M2 or M3 nozzle just for mist to make the air cooler.
__________________
best trap 135mph
PT6262
Tuned by Mark @ TTR
TurboTrix Racing
SparkTech Ignitions
Offline
Old Jun 10, 2009, 07:41 AM   #8
Personal Sales Rating: (3)
2003 Mitsubishi Lancer Evolution
TxEvo8's Avatar
Drives: '03 Evo 8, '02 FZ1
Yes just water I just want it for cooling effect....not Octane substitue[/quote]
It is my understanding that the most beneficial aspect of meth is it's ability to cool the air charge rather than raising the octane of the fuel. Something to consider.
__________________
Sponsored by Don Herring Mitsubishi
Sponsored, built, and tuned by KevinD at Evolution Dynamics
100K+mile track beast @ 375hp
Offline
Old Jun 10, 2009, 02:07 PM   #9
Personal Sales Rating: (7)
Drives: 03 Evo
Do you have an intercooler sprayer? You could try making or getting a cold air intake made. Putting the filter out of the engine bay, sucking in ambient air. Don't see TOO many evo guys doing that, but DSM guys do it constantly. It helps quite a bit. Or possibly a shield around the filter to box it away from the radiant heat in the engine bay.
__________________
03 WW Evo - Tial 35r, 950's, EMS, 272's, AMS VSR, TAB-FAB v-band manifold, etc.
www.tab-fabrication.com
Offline
Old Jun 13, 2009, 11:44 AM   #10
evovin's Avatar
Drives: Evo 8
I pulled my IC sprayer long time ago.
__________________
best trap 135mph
PT6262
Tuned by Mark @ TTR
TurboTrix Racing
SparkTech Ignitions
Offline
Old Jun 16, 2009, 01:23 AM   #11
Personal Sales Rating: (4)
kjewer1's Avatar
Drives: 2005 EVO RS
Are we talking about intake temps at the MAS (stock ECU) or charge temps at the throttle body (AEM, etc)? Two completely different IAT values. I see temps in the 140s at the end of a drag run post intercooler, it's not uncommon. A better IC can keep that number a good bit lower. A cold air intake doesn't help significantly with this reading (post IC) since any drop in intake temp at the filter gets cut down by intercooler efficiency. Using typical values a 5C drop at the filter only works out to a 1C post IC.
__________________
Kevin Jewer
92 Talon RWD, compound turbos - 8.98 @ 156
Offline
Tags
140, ac, air, ait, car, deg, degree, degrees, domestic, filter, injection, mist, pipe, putting, temps, tuned, water
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
