Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 16, 2009, 08:45 PM   #1
Personal Sales Rating: (4)
K Scorcz's Avatar
Drives: Evo IX, S13 Coupe
Send a message via AIM to K Scorcz
Aquamist HFS6 Must Read
Greetings everyone,
I was just finishing up the install on my new Aquamist HFS6 kit when I ran into a snag. A leak formed at one of the push fittings that could not be stopped. I chalked it off to being a defective fitting as the other one did not leak.
I e-mailed Richard from Aquamist who stated that I had installed the fittings wrong. I assured him I followed the directions and the diagram exactly and was certain it was a defective fitting.
After speaking to Richard over the phone he investigated the incident and discovered that the diagram that comes with the HFS6 kit is wrong. The old diagram shows the push fitting installed below the accumulator on the 5 way brass fitting. This is incorrect as it is the high pressure side of the pump. Richard further related that the metal screw type fittings should be installed below the accumulator as they are much more secure and made to withstand the high pressure .
A note to everyone who has or will install this kit. The plastic elbow fittings do not go on the pressurized side of the pump as they are not meant for high pressure and will leak.
A big thanks to Richard for taking the time and getting to the bottom of this problem. A+ customer service.
Below is the updated diagram.
Offline
Old May 16, 2009, 09:49 PM   #2
Personal Sales Rating: (0)
Drives: Evolution VI
lucky me I was too dumb to follow the manual correctly and actually have it right
Offline
Old May 17, 2009, 03:26 AM   #3
Silver Sponsor
Drives: Citreon Xsara
Thanks for posting this, we apologised for not making it clear. I would also like to add another oversight of the RJ plugs. Not all harnesses have this defect. Please clear the overhang with a small knife or return the harness to us.
__________________
richard@aquamist.co.uk
Offline
Old May 17, 2009, 09:04 AM   #4
Silver Sponsor
This recommendation would not apply if the water filter is installed in the horizontal orientation.
If the inline disc is installed in a vertical position, it would be advatagous for inlet to be located at the bottom and water exit at the top. This will avoid debris from settling on the filter mesh and cause premature clogging.
__________________
Offline
Old May 17, 2009, 09:05 AM   #5
Silver Sponsor
If wire leading the the FCM (flow control module) is at a higher level then the module, it would be advisable to create a small downward loop to allow any water trickling along the line working its way into the FCM.
__________________
Offline
Tags
aquamist, diagram, fcm, hfs6, manual
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
