Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 19, 2009, 04:58 PM   #31
Personal Sales Rating: (36)
Evoryder's Avatar
Drives: EVO METH MACHINE
For example on tuning. My setup in Rpm increments:
3000 a/f = 12.5 -12.8
3500 a/f = 12.0-12.5(between)
4000 a/f = 12.0 Peak boost 29psi (This is also where my meth comes on approx 300 load)
4500 a/f = 12.0 (conservative timing)
5000 a/f = 12.0 (conservative timing)
5500 a/f = 12.0 (conservative timing)
6000 a/f = 12.0 Boost begins to Taper(More aggressive timing from 6k to redline+)
6500 a/f = 11.8 Approx 26psi
7000 a/f = 11.8 boost @redline 24psi
I have leanspool disabled so my a/f curve is pretty straight. Now this is for my setup @ 29psi with cams, 2 nozzles, ported manifold, 10.5hotside, o2 dump etc...I haven't really gone super aggressive on my current tune, however, the car moves as is.
Advance Timing really depends on the car and mods, so comparing to others for timing doesn't always work.
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Old May 19, 2009, 10:50 PM   #32
Personal Sales Rating: (5)
raasfaas's Avatar
Drives: 06' IX MR GG
Quote:
Originally Posted by GRNCT9A View Post
You can probably advance more timing at redline. Especially with water/meth. How does your Mivec look? Try putting zeros at redline. I'm sure you've read the mivec overlapping theory with to much timing in the mivec maps.
I have been playing around a bit with my tune seeing if my car responds better to lean afr/low timing vs. richer afr/high timing and it seems to respond better to the higher timing. I've tried a couple different mivec maps from fellow evoM members and the one I'm currently on is a hybrid map that mrfred had posted a while back that cij did some altering to...but it basically follows the theory, 0* at redline. I guess I just need some time to tune and try different settings to see which one responds better, I just wanted to get an idea of what other members have tried.
__________________
AEM cone filter | Forge DV/BPV | DC dp w/ cat delete | HKS Hi-Power Exhaust | Ebay O2 housing | Walbro 255lph pump | AEM tru-boost EBC | ETS LICP | ETS FMIC | AEM Meth 75/25 | ARP Headstuds | ACT HDSS | Tephrav5.10 w/JT Map Switch | everything else stock
Self Tuned
ET11.71@117.8mph
MGW & Lueboyz Racing to di werl!!!
Offline
Old May 20, 2009, 12:01 AM   #33
raasfaas's Avatar
Hey thanks for the info, very informative breakdown. You're running leaner than I am, but then again with 2 nozzles I'm pretty sure you're spraying much more meth than I am also. Quick question though, and I don't mean for this to turn into leanspool thread, but there has been so much theories behind whether to disable or not, currently I have it enabled, but have also tried disabled...how does you're spool up feel with it disabled? Did you do it the old way (setting your start/stop to the same rpm) or the periphery bits way (totally disabling it with ecu periphery 1)
My last question, sorry for so many, how is your meth activated? I noticed you said that at 4k rpm, peak boost 29psi which is also where your meth comes on at approx 300 load, seems like you start spraying pretty late, my AEM is set to start spraying at 11psi which is the highest it can start.
__________________
Self Tuned
ET11.71@117.8mph
Offline
Old May 20, 2009, 11:39 AM   #34
Evoryder's Avatar
Quote:
My 2 nozzles combined I'm spraying 1,255ml/min
I disabled Lean spool with the periphery bits, it actually has nothing to do with your spool, tuning does.
I have it on and off, non progressive. My meth is 100% activate 10psi and above, anything below and it's off. So it's actually spraying earlier but it atomizes fully around 4000rpm, that's where the real dip in logs for me is.
(My answers are in red)
__________________
TEMEVO
MACHINES GONE WILD
Offline
Tags
evo, evolution, fm, hks, map, meth, timing, tune, water
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
