Apr 29, 2009, 06:15 PM
Personal Sales Rating: ( 2)
Drives: 2006 RR Evolution IX
Aquamist HFS-6 installed and running. :)
Got my kit Monday, install and testing was finished yesterday, started tuning today and I'm almost done with it.
Install is very straightforward. Only took about 3 hours for everything (wiring, hoses, tapping the uicp, installing the tank). Really easy. :P
Ran into a small issue during testing:
I put the jumper into the "TST" position to trigger the 100% duty cycle, to test the kit, and no fluid came out. I unplugged all connectors and replugged them, worked for an instant and stopped. Turns out my red plug (engine bay) doesn't conduct properly if it is pushed tightly inside the connector. I found the position to make it work, and I didn't have any issue today. Richard, any comment/help?
I will post pictures and maybe even a video tomorrow if I have time.
All in all, I am really happy with the kit so far. Only issue was the red plug thing mentioned above, which was somehow fixed.
Btw, car is an Evo IX with full bolt ons and an Fp red at about 28-29psi. Results look promising so far.
__________________
Newton turns in his grave every time an Evo is started.
Offline
Apr 29, 2009, 06:20 PM
Personal Sales Rating: ( 14)
Drives: APAT tuned 8
cant wait to see some pictures and results of this kit
__________________
cbrd bbk
Peteyturbo Tuned
krazyhousecustoms.com
infraction points:7
Offline
Apr 30, 2009, 12:54 AM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: Citreon Xsara
Kkarim,
Can you check the pins are not bent inside the red connector or some debris got trapped inside.
Which failsafe output are you using?
__________________
richard@aquamist.co.uk
Offline
Apr 30, 2009, 03:21 AM
I did check that. Pins look perfectly fine, and there are no debris what so ever.
Kit has been working for 2 days that way, but i am somewhat sure that it will stop again once i move it wires. I will have the fiddle around again to make it work.
Oh and i'm currently not using any failsafe. Didn't make up my mind yet. I'm gonna be using either alt-map, or a 3-port solenoid in parallel with my mbc.
__________________
Offline
Apr 30, 2009, 03:31 AM
Personal Sales Rating: ( 0)
Drives: 2006 Evo IX MR, 1979 Chevy C10, 2002 R6
I want to get the exact kit as well
__________________
♠I would rather be a smartass than a dumbass♠
♠Up on one♠
♠I was part of the AMS website crash of 2008♠
Offline
Apr 30, 2009, 11:04 AM
Drives: Evo X
Grats on install i would love to see some pics also. I cant wait for mine to come in. I am expecting it to arrive in the next couple of days.
__________________
2008 GG EVO X GSR
Kelford Cams 214-A
AP Dual Catback Exhaust w/ Test Pipe
AP Short Ram Intake
AP Upper IC Pipe
UR Lower IC Pipe
AP FMIC
Greddy Profec B Spec II EBC
UR Kit Walbro 255L/HR Fuel Pump & Hi Flow Filiter
Eibach Pro Kit
Exedy Twin SD
AMS Clutch Master Cylinder Reinforcement Ring
Works Short Shifter
ECUTek (Tuned by UMS)
336whp 332wtq 22psi
Offline
Apr 30, 2009, 02:09 PM
Personal Sales Rating: ( 17)
Drives: IX GSR
Good to hear reports of an easy install!
I plan on doing an HFS-6 install in the near future, I’ll be sure to document it with all my usual enthusiasm. Expect pictures and write up in the near future!!
Offline
Apr 30, 2009, 03:38 PM
Silver Sponsor
I built a unit to test all the HFS-6 controller, it has four leads, terminated with the same RJ45 connector used on the coloured harness. So far I have not experienced any suspect contacts or slightest flicker of contunuity problems.
I begin to think the problem may be originated from the bottom of the 4-ganged socket. Take a very close look on the bottom of the circuit board and let me know if all the soldering joints are sound. But then again, if thereis a probelm, it would have shown up on the final test. Please keep looking.
By the way the RJ45 only engage properly when the plug is not fully pushed in. After the click, you shoudl pull the plug out slightly to relief and re-seat the spring contact wires.
__________________
Offline
Apr 30, 2009, 03:40 PM
Silver Sponsor
I am working very hard towards building yours. I look forward to write-up.
__________________
Offline
May 1, 2009, 08:12 AM
Drives: IX GSR
Quote:
No rush, I don't want to keep you from getting any sleep
Offline
May 1, 2009, 10:29 AM
Silver Sponsor
Sleep? I do go to sleep everyday.
__________________
Offline
May 1, 2009, 01:37 PM
Drives: IX GSR
O well then, if you have time to sleep then perhaps you should do another group buy so that you have absolutely no time at all, lol.  I’m sure you’ll feel relieved once all the kits have gone out.
Offline
May 1, 2009, 05:32 PM
Silver Sponsor
This may not be a bad idea, start another GB for the HFS-7 (wireless CAN version of HFS-6) next week. HFS-6 GB shipping is almost finished. I gladly exchange my sleep for GB - very exciting exercise.
Just remembered, I hate writing manuals - I lose sleep on them. So no GB for the H7.
__________________
Offline
May 3, 2009, 08:38 PM
Drives: IX GSR
Well good think you know someone who doesn't mind proof reading the manuals
Offline
May 4, 2009, 05:02 PM
Silver Sponsor
You have been good to me. No more excuse to delay the HFS-7.
__________________
Offline
Tags
aquamist, evo, evom, gauge, hfs, hfs6, install, installed, osa, pictures, pump, results, sti, subaru, time  |
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
