Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old May 6, 2009, 08:04 PM   #16
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
haha sounds good.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old May 9, 2009, 07:49 AM   #17
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
Quote:
Originally Posted by kkarim View Post
I did check that. Pins look perfectly fine, and there are no debris what so ever.
Kit has been working for 2 days that way, but i am somewhat sure that it will stop again once i move it wires. I will have the fiddle around again to make it work.
Oh and i'm currently not using any failsafe. Didn't make up my mind yet. I'm gonna be using either alt-map, or a 3-port solenoid in parallel with my mbc.
I took sometime examining a batch of RJ connectors and found one with a rough edge, possibly damaged by the crimp tool. (slight mis-alignment during crimping).
The flared edges may cause contact mis-alignment and hence bad connection.
I managed to take some close-up pictures, with arrows. Ignore the cable colours - not from a HFS-6.
__________________
richard@aquamist.co.uk
Offline
Old May 25, 2009, 05:05 AM   #18
Silver Sponsor
Jamal from HBspeed has posted his install of the HFS6 system on our forum, I "copy and paste" it here as a reference although it is not an EVO but useful to know how he tackle the install and skillfully fabricated the tank bracket....
I'm almost done with my first HFS-6 install, which is going in an 08 STi.
Here's the car:
Here's the fancy new HFS-6 control board, which goes in the glove box:
I suppose I will wrap that wiring up a bit. Moving rearward to the hatch we have this mess going on:
If I could tig weld this would be done already. Here's the tank and partially completed mounting frame:
Yeah, it's 4 gallons. Or 15l for you metric system using people.
Moving all that water/meth is the new 160psi pump featuring compression fittings:
The line and wiring harness to the rear are tucked under the passenger floor along with the fuel lines. There are even convenient extra tabs to mount the line:
From there the wiring harness travels into the glove box and the pump power wire and tubing go through the main harness grommet into the engine bay with the flow control unit harness. The flow control unit is mounted to the firewall. A 90 degree fitting for the inlet would make this work a lot better.
Here's the engine bay and ATP 3076 turbo:
Okay well that's all for now. Once the bracketry is welded up I can get the hatch finished and the car will be tuned tomorrow.
Well, the car is finished and here are the pictures I took today. I'll start with the pump.
Mounting bracket and pump location:
And yes, I tapped some M5x0.9 holes so I could just bolt it right down.
Then I got a little crazy with the split loom and spiral wrap to protect the meth line and clean up the wiring:
Jon welded up the rest of my bracketry so all I had to do was paint it, bolt it in place, strap down the tank, and make the floor fit around it:
After testing for leaks, we filled the tank with a 50/50 mix and it went on the dyno:
Previously the car made 361 whp on 91 octane with 21 pounds of boost. Now with 21 psi it makes 390whp. Going farther on the stock map sensor means there is no boost cut, so we left it there for now. Later on I'm sure we'll put in a new MAP sensor and see what it will really do. This is a stock engine, though, so we're reluctant to push too far. Stupid stock pistons.
Impressions:
I like the HFS-6. A lot.
Wiring up the HFS-5 board never bothered me, and in fact I liked doing it because each installation was custom and all the wires were exactly the right length. With the HFS-6, I have to say the RJ connectors for everything is very nice. Having most of the harnesses pre-set in length worried me a bit, but I ended up with very little extra wiring to deal with. Most of the extra on the trunk harness, and it's just zip-tied together and tucked under the tank. Aside from the tank fabrication, the installation was quick and easy. The fact that I've installed plenty of aquamist kits helped, but I am really impressed to have had no issues whatsoever with the installation of ths brand new product. This one came out of the group buy and must be one of the first to be installed and tuned. I've previously had some issues with the HFS-5, like getting the boost cut to work without throwing a CEL, systems that reset when the lights were turned on, and had a trip-adj pot reversed. All I have to say is this is a really, really great kit. Thanks Richard.
Also, I suppose I could post this up on some Subaru forums.
__________________
Offline
Old May 30, 2009, 06:24 PM   #19
Personal Sales Rating: (2)
Zodiac13's Avatar
Drives: 2005 EVO VIII GSR
grats with the install. by the way im trying to get around to getting mine installed and tuned. i went to just have the gauge setup with my sterring colom mount so i can have it ready since im moving my boost gauge their aa well but it wont fit. did you have a similer problem cause i thought it was supposed to be 52mm not larger.
__________________
Installed
Buschur Racing 3" Turbo-Back, A'pexi Power Intake
ETS 3.5" FMIC w/ Upper/Lower Pipes, EPM O2 Dump Housing
GSC S1 Cams, Walbro 255lph fuel pump, Hallman MBC
ARP head studs, HFS6-osa w/ 75/25 mix
Reese Tuning
Future Install
Ported Intake, Exhaust, and Throttle Body
FP Red Turbo
344 WHP 354 WTQ
Offline
Old May 30, 2009, 07:40 PM   #20
kkarim's Avatar
Drives: 2006 RR Evolution IX
@Zodiac, didn't have any problems with the gauge... I used an stri 52mm pod iirc, installed it on my steering column, towards the left.
will have pics and vids of the whole setup up soon..
__________________
Newton turns in his grave every time an Evo is started.
Offline
Old Jun 21, 2009, 08:20 PM   #21
Personal Sales Rating: (7)
Boricua_Evo's Avatar
Drives: '05 AS Evo VIII (96940011)
Send a message via Yahoo to Boricua_Evo
Umm... HFS-7? Wireless?
I have the HSF-1 I feel so inferior!!! LOL I WANT THE LATEST AND GREATEST!!!
__________________
MODS
- CBRD BBK Full
- FIC 1050cc
- KELFORD 272 CAMS
- BC SPRINGS & Ti. RET.
- GATES
- AQUAMIST HSF-1
- SPEC Super Twin P-Trim
- INJEN A/I SYS w/Amsoil filter
- TIAL Q 50mm BOV
- 3" TURBO XS CATBACK
- eBay 3" TESTPIPE
- 3" MR DN PIPE
- MR HEADER
- ETS LICP
- ETS 3.5" FMIC
- EVODAVE HEADLIGHTS
- EVO 7 TAILS
- TEIN-S
- 255 F.PUMP
- Amsoil ATM 10w30
____________________________________________
4WSTuned!
R.I.P. Westley Hess (12/30/2008)
North West Evolution!!
Offline
Old Jul 29, 2009, 10:37 AM   #22
Personal Sales Rating: (3)
Drives: 06 evoIX SE
the kit looks sick, specially for "installation"
__________________
mah EvoIx pix
Tuned by:
AWD Motorsports
4WD Tuning
Offline
Old Jul 29, 2009, 10:52 AM   #23
Personal Sales Rating: (6)
ChuckP's Avatar
Drives: 2006 GG IX MR
Send a message via AIM to ChuckP
Thanks for sharing the install pics Richard.
Question if you got a minute. For an evo on a stock IX turbo w/ stock injectors, what nozzle(s) do you recommend? Also, where is the best place to tap the UICP for them? thanks. Cant wait 'till this weekend to install the HFS-6.
Offline
Old Jul 30, 2009, 10:12 AM   #24
Drives: 06 evoIX SE
not to take this offtopic... but i installed mine on my stock UICP right before the rubber-like extension that connects to the intakemani, on the underneath, not visible unless removed... i also went with one 1mm... i belive the closest to the mani you get the better tho, so aftermarket piping might be a better set up then stock
__________________
mah EvoIx pix
Tuned by:
AWD Motorsports
4WD Tuning
Offline
Tags
aquamist, evo, evom, gauge, hfs, hfs6, install, installed, osa, pictures, pump, results, sti, subaru, time
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
