Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 26, 2009, 03:27 PM   #1
Personal Sales Rating: (5)
Sideck's Avatar
Drives: Evo VIII
Coolingmist EVO Boost + MAF SIMPLE 2D MAP KIT
hi, i am ready to get a meth kit!! what do you think about this kit
or you can recomendme some kit at the same price or less??
thanks!!
Offline
Old Feb 27, 2009, 04:19 PM   #2
Sideck's Avatar
Drives: Evo VIII
thanks for your recomendations!!!
Offline
Old Feb 27, 2009, 08:44 PM   #3
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
dont know if its too late...for the amount of $$$ you want to spend, why not add $50 and get yourself a real injection kit:
http://www.aquamist.co.uk/phpBB2/viewtopic.php?t=1600
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Feb 27, 2009, 10:39 PM   #4
Sideck's Avatar
Drives: Evo VIII
this kits cost 600 and aqua mist 850 plus shipping... then is more money!!
and what happen with cooling mist?? i have one CM kit on my SRT and works excellent!!
Offline
Old Feb 28, 2009, 05:20 AM   #5
Silver Sponsor
Drives: Citreon Xsara
How did you arrive at those prices? Isn't it 699 and 750?
__________________
richard@aquamist.co.uk
Offline
Old Feb 28, 2009, 05:48 AM   #6
SlowCar's Avatar
Quote:
Originally Posted by Sideck View Post
.......and works excellent!!
could you elaborate a bit more by what you mean by "works excellent"
__________________
Offline
Old Feb 28, 2009, 05:49 AM   #7
SlowCar's Avatar
Quote:
oops $51
__________________
Offline
Old Feb 28, 2009, 11:09 AM   #8
Sideck's Avatar
Drives: Evo VIII
i see this price on the site:
1-9 ............ USD895 .......£590
but now i read is a group buy.. sorry!!
and one guy here giveme the Cooling mist kit for 600...
Offline
Old Mar 2, 2009, 09:49 AM   #9
Silver Sponsor
This is not a fair comparison, picking an un-mentioned off-list price ($600) and compared it with a highest Aquamist GB price. Anyway, I had a good look at the coolingmist "link" you kindly put up, it reads $699.96.
The system is not PWM controlled, but PPS. The flow sensor is just a off-the-shelf pressure switch, renamed as "status monitor".
For a mere $50.04, you get a dash gauge, a turbine flow sensor and an PWM controller valve. Hardly an exact performance comparison.
Anyway, the group buy is now over. We move on.
__________________
Offline
Old Mar 2, 2009, 10:07 AM   #10
Personal Sales Rating: (1)
Drives: 06 Elise. 09 BMW 135I
sidedk,
Yes I think we should not compare apples to oranges. comparing our highest price MSRP to a group buy kit that is not released is not fair. Lets compare our group buy.
I believe the other kit is $650 at group buy. Ours is $675 at group buy. Here is what you get:
CMGS gauge 52 MM. Displays flow and boost
Failsafe with true turbine flow sensor.
1.5 gallon integrated trunkmount tank.
PWM pump system
250 PSI pump.
low level float switch
fittings, hose, injectors and rest of kit.
So for roughly $25 more you get a 1.5 gallon custom tank, a failsafe that is far more flexible and capable of more conditions, a gauge that not only shows flow rate, but boost or dutycycle as well.
take care.
Offline
Old Mar 7, 2009, 08:25 PM   #11
SlowCar's Avatar
compare both systems:
full pressure PWM valve injection (Aquamist HFS-6 or HFS-5) Vs. PWM variable pump speed/pressure system others use...
__________________
Offline
Old Mar 7, 2009, 09:12 PM   #12
That is not our pump. Our system is using a high pressure 200 - 250 PSI by pass pump (no pulsing) . You are showing a pump that has a shut-off switch that pulses, you simply cannot compare this to our kit. Also our kit has a solenoid. Your video while entertaining does not address our kit.
Offline
Old Mar 7, 2009, 11:34 PM   #13
SlowCar's Avatar
Quote:
really? am i seeing things?
__________________
Offline
Old Mar 8, 2009, 07:50 AM   #14
That picture is not updated. All of our controller kits ship with the Aquatec pump. You can rip on it if you want but just about all manufacturers are using it now.
David
Offline
Old Mar 8, 2009, 08:54 PM   #15
SlowCar's Avatar
That picture is not updated……You can rip on it if you want but just about all manufacturers are using it now.
David
Me ripping on what??
Nice move from the pulsing shurflo on-demand pump…to the high pressure aquatec 5800 pump
So how does this highER pressure system react to negative transients – sudden/quick downward change in boost/maf/idc...? Seems to add more headache to the already flawed idea of a progressive speed/pressure/atomization/injection rate system…where does the excess pressure in the line go to reduce injection rate…….?
Paying $$$ for a progressive pump speed system that has worst injection performance and tuning nightmare compared to a predictable on/off full atomization system?
__________________
Offline
Tags
250, 5800, aquatec, cmgs, coolingmist, psi, pump
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
