Feb 25, 2009, 04:58 PM
Personal Sales Rating: ( 19)
Drives: 2003 evolution
Aquamist with bigger injector
with stock injectors, i see duty cycle upto 95%, if i upgrade injectors, my duty cycle will go down. i think this will affect the amount of methanol/water spray b/c controller detect duty cycle and control/adjust water spray?
what's the solution? should i just adjust the aquamist controller?
Offline
Feb 25, 2009, 09:17 PM
Personal Sales Rating: ( 6)
Drives: SRT4
You should have a couple of additional jets that you can use that came with the kit. You also can order more jets that more closely matches your new setup if the jets you have now are not going to cut it with the new setup..........if you used the jet adapters in your existing setup then swapping jets should not be a big issue if the jets are fairly easy to get access to.
Offline
Feb 26, 2009, 02:31 AM
Silver Sponsor
Personal Sales Rating: ( 4)
Drives: Citreon Xsara
Aternatively, you can double pulse the HFS-5 to increase the flow electronically. Evotio has done this and the works very well.
__________________
richard@aquamist.co.uk
Offline
Feb 26, 2009, 08:02 AM
Personal Sales Rating: ( 17)
Drives: IX GSR
Just use next jet size up. Its quick and easy.
TRIM ADJ on HFS6 will fix this, yippee.
Offline
Feb 26, 2009, 10:38 AM
Quote:
how do you double the pulse?
i am using 1.0mm and 0.7mm currently, so by adding more jet will flow more water? or is like kinda fixed amount of water from pump depending on duty cycle.
because if it is fixed amount, then more jet will cause low pressure in each jet/maybe poor atomization of spray???
Offline
Feb 26, 2009, 11:18 AM
Silver Sponsor
__________________
Offline
Feb 26, 2009, 11:45 AM
hmm...diagram looks a little more complicated than i anticipated...
so easier solution is to add more jet? will this affect flow/pressure at all?
i will come back and look at my install diagram.
Offline
Feb 26, 2009, 12:04 PM
Drives: IX GSR
I would just swap out the .7mm for a 1.0mm jet. It will not effect pressure or atomization. The pump can easily handle 2x 1mm jets. I know because that’s what I run.
Offline
Feb 27, 2009, 03:03 AM
Silver Sponsor
It is not that involved, just get two in 4007 diodes and splice them in and you are done.
__________________
Offline
Feb 27, 2009, 03:03 PM
looked more carefully and makes more sense now.
i checked my wiring(thanks go Abner!), my green wire is tapped to pin #2(no 3 injector) on evo8 ECU diagram. so, i need to split current green wire into 2 green, tap to both to no 1 and no 3 injector(pin #1 and 3), using 4007 diodes, correct?
so, stupid question, pin #'s 1,2,14,15 on ECU(injector 1,3,2,4, respectively) is negative, correct? i don't have to wire it from actual injectors.
Offline
Feb 27, 2009, 05:20 PM
Silver Sponsor
I think those are the pinouts, but check again. You can wire it from the ECU.
__________________
Offline
Feb 27, 2009, 09:50 PM
Personal Sales Rating: ( 8)
Drives: 2003 Evolution VIII, 1974 Chevy LUV/Small Block V-8, 1966 Chevy Nova SS
With my set up, I'm running 1000CC RC Engineering injectors anticipating to run E-85 someday. My IDC's are also about 49% at redline with my current tune with 91 octane and twin 1mm nozzles. I am running (2) 1N4007 diodes tapped into the injector wires exiting the ECU harness for injector #1 and #4. It works great.
Offline
Feb 28, 2009, 08:14 PM
i am sure there is no right answer but i don't know which one is better, adding another jet-right after IC pipe and cont with current 2 jets near throttle body OR do twin pulse trigger.
Offline
Mar 1, 2009, 07:37 AM
Silver Sponsor
There is a third way.
If you splice the second diode to the next injector, you will get 2x rate until they started to over lap and high RPM.
__________________
Offline
Mar 1, 2009, 07:38 AM
Silver Sponsor
If all else fails, get the HFS-6.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
