Feb 18, 2009, 10:37 PM
Personal Sales Rating: ( 8)
Drives: 05 electric Blue Evo, 04 Blue R1, 95 Nissan pickup lowrider
Using failsafe for normal driving
I have a Labonte failsafe. I was wondering if I can wire in a switch to the failsafe to indicate a false failsafe. This way I can run low boost with no injection for times if other people drive it like valet drivers. Would this be safe to do? Can I cruise around like this and use this switch as a power switch for when I really need it? My thinking is it would kind of be like using 2 maps with the flip of a switch. Or is this to good to be true?
__________________
3" turbo back exhaust , Forge MBC, Walbro 255 fuel pump ,Helix lower I/C piping, Exhaust Manifold with o2 housing, Crushed Evo 9 BOV , huge I/C, 272 HKS cams, Head studs, Buschur Upper i/c pipe, Braille mini battery, Buschur intake pipe with cone filter, ported and polished intake manifold, 65MM Throttle body, Meth with 50/50 mix, 30psi custom tune by Chris Black at AMS
380WHP
392WTQ
JDM rear bumper
Offline
Feb 19, 2009, 01:55 AM
Personal Sales Rating: ( 2)
Drives: 06' TB IX SE
TephraMOD V5.10
This is the almighty Tephra Mod 5.10. It has everything you are trying to imagine in your quest for safety.
It has map switching, it has vallet mode and it has a CEL flash when your car knocks. It also has some other features like NLTS.
Solution provided, you're welcome
Offline
Feb 19, 2009, 06:49 PM
Not sure what that all means  . I dont have logging capabilites at this time which is what this looks like. In the mean time would my idea work for now?
__________________
380WHP
392WTQ
JDM rear bumper
Offline
Sep 8, 2009, 08:55 PM
Personal Sales Rating: ( 5)
2003 Mitsubishi Lancer Evolution
Drives: 2003 Evo 8
bump for info.. would be nice to run low boost just regular driving
__________________
HAHA!!
Quote:
Originally Posted by Mellon Tuning
btw, I like a good boost spike, it gives me some crazy torque that makes the local modded STI guy say... WTF JUST HAPPENED
FOR SALE
JVC 7" touchscreen double din
Apexi catback
Offline
Sep 9, 2009, 07:20 PM
Its simple. Just get a Labontes failsafe and depending on what nozzle you have just turn down the flow rating on the failsafe. It will think its not flowing enough an run wastegate psi. When you want to go all out turn the failsafe to the regular flow and it will work normally. Only drawback is it will still spray the meth which will make you run rich. I use this when I drop it off for valet parking or at the dealer. This way they cant get full power.
__________________
380WHP
392WTQ
JDM rear bumper
Offline
Sep 10, 2009, 12:58 PM
Personal Sales Rating: ( 6)
Drives: 05 Evo8 SSL
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
