Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Feb 17, 2009, 08:16 AM   #61
Personal Sales Rating: (7)
fostytou's Avatar
Drives: Graphite Grey IX SE (88590015), '04 FZ1, Former: 35R Powered Eclipse GST, 6/4 TSi AWD, Bandit 600s
Send a message via AIM to fostytou
Quote:
Originally Posted by dudical26 View Post
Richard -
In working on the spreadsheet to help illustrate how all the settings change the flow curve I have run into a question.
I am trying to determine the equation to calculate volts from PSI assuming a 3 bar map sensor (like the JDM map sensor). I used data values from your DDS3 v.10 instructions to work backwards to get an equation for the line of the data points when graphed. However, this gives me Volts = PSI * .115385 + 1.661538 which means that 32.4 psi = 5.4 In reality it should equal 5 volts though, right? Do you have an equation that I can use to calculate volts from PSI or any tips on what I am doing wrong here.
Man I wish I paid more attention in high school math class.
Attached is what I have so far. Although the PSI to Volt equation is not right yet the spreadsheet still works pretty much. Take a look, it gives a nice visual to the settings. I am going to play with the spraedsheet more to make it easier to use and nicer to look at but the concept is there.
Can't you just use the voltages in the MAP Comp tables that you adjusted when installing it?
__________________
Corn Fed 365hp/360tq
  • AMS FMIC, AMS LICP+UICP, AMS Front lower motor mount, Megan O2, Megan DP, Perrin HFC, Fujitsubo RM01A Cat-back, Walbro 255, RC 1200cc Injectors, GSC S1 Cams, Ghetto 3" intake +AMSoil EA Filter
  • Tephra V6, JDM MAP, Direct boost ctl w/ AEM solenoid, AMS Tuned
  • Pioneer DEH-P9790BT, 40GB iPod, 10W6V2, Alpine PDX-1.1000, Passport 8500 x50 Hardwired, AEM Tru-Boost (Guage only), Auto-dimming mirror, 35% Tint
Offline
Old Feb 17, 2009, 09:26 AM   #62
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
Quote:
Those correlate voltage to a 0 to 255 scale that the ECU uses, not PSI, if I recall.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Feb 17, 2009, 09:28 AM   #63
dudical26's Avatar
Drives: IX GSR
Richard - Are you able to make an image with the Adjustment Pots in any position you like?
If so do you think you can send me a zip file with an image of a pot at 5%, 10%, 15% ... 100%
I am going to try and make the excel sheet so that once the user selects the value they would like to use to create their Meth curve, it will show them an image of how they should adjust the POTS to achieve their goal.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Feb 17, 2009, 09:32 AM   #64
Personal Sales Rating: (30)
Turbo Kyle's Avatar
Drives: 2006 EBP IX
Holy hell thats freakin saweeeet!
__________________
ALL OF MY SALES ARE SUBJECT TO MY 1st POST IN MY PART OUT THREAD (see below)
Evo IX part out here!!! http://forums.evolutionm.net/sale-pa...-get-some.html
Offline
Old Feb 17, 2009, 11:39 AM   #65
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
Richard -
Assumming a 3 bar (43.5psi) map sensor has full scale outout of 5V. 1 psi = 0.115 volt. Your calculation is fine.
Can you tell me what is 1.661538 representing?
- 1 bar = 0.9869 atmosphere bar = 14.5037 psi
- 1 atmosphere = 1.01325 bar = 14.695 psi
Richard
__________________
richard@aquamist.co.uk
Offline
Old Feb 17, 2009, 11:44 AM   #66
Silver Sponsor
Yes I can, what about 10%? You may have a problem here. The electrical rotation span is different on all makes and models of potentiometer. This is the reason why the HFS-6 works from mid-point. (12-clock).
__________________
Offline
Old Feb 17, 2009, 11:48 AM   #67
Silver Sponsor
Dudical,
I am unable to open the zip file. May be my winzip is too old. It is OK to post uncompressed file these days, download speed is no longer a problem.
__________________
Offline
Old Feb 17, 2009, 12:04 PM   #68
dudical26's Avatar
Drives: IX GSR
Richard
Thanks,
I adjusted the spreadsheet to reflect these changes.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Feb 17, 2009, 12:08 PM   #69
dudical26's Avatar
Drives: IX GSR
Speaking specifically of the POTS on the HFS-6. Is the rotation span not linear?
Meaning the 12-clock mark is 50% and the 7-clock mark is 0% and finally the 5-clock mark is 100%
For example referring to boost comp would 7-clock be 0 volts, 9-clock = 1 volt, 11-clock = 2 volt, .... 5-clock = 5 volts.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Feb 17, 2009, 12:11 PM   #70
Silver Sponsor
Forgot the voltage:
- 1 bar = 0.9869 atmosphere bar = 14.5037 psi = 1.668V
- 1 atmosphere = 1.01325 bar = 14.695 psi = 1.689V
0 psi boost (gage) = 1 atm = 1.689V.
__________________
Offline
Old Feb 17, 2009, 12:14 PM   #71
dudical26's Avatar
Drives: IX GSR
Dudical,
Hmm, I compressed the image as EvoM does not let me host .xls file.
I have attached 2 files. One is .zip with NO COMPRESSION and the other is a text file of the spreadsheet. In order to view the text file version you will need to simply rename the extension from .txt to .xls
Let me know if this works.
-------update-------
Files removed, new files will be uploaded later in the thread.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Feb 17, 2009, 12:41 PM   #72
Personal Sales Rating: (6)
scheides's Avatar
Drives: 05 Evo8 SSL
OMG I just saw this and cruised through the entire thread. WOOWOO! No more wiring nightmares! I am in LOVE with the new design, I think RJ45's are the way to go; the control unit is not going to be mounted anywhere that will see moisture or too much vibration anyways (well it shouldn't anyways).
Tons of questions!
-Can I help with an upgrade path from HFS-1 users? I would love to upgrade. I'm thinking it'd be easy to splice the existing harness wires into RJ45 plugs, or perhaps colored leads provided from aquamist? Then add the new unit to replace the flow sensor and on/off valve and we'd be in good shape.
-Where do the failsafe wires get wired to, and how are they defined? I'm thinking of my map-switching setup....if one of the leads to the ECU harness will have 0-5v output linked to the failsafe we'd be golden.
-What's the very rough ETA of bringing this kit to market?
Offline
Old Feb 17, 2009, 03:13 PM   #73
Silver Sponsor
My answers in Green...
Quote:
Tons of questions!
I need to give this a serious thought. At present, I am setting up the production tools for the HFS-6, I can do with more hours in a day. The existing wires will not go into the RJ45 connector, they are slightly too thick.
The v8/v9 gauge is modified for the v10, both elctricially and mechanically. You may need to return the guage to be modified - not too bad, but workable. We need to change the 8-core cable to a thinner type.
Adding the valve and flow sensor is quite straight forward.
The yellow connector (to ECU) contains the map switch wire as well as the relay outputs (3-wire).
We plan to ship by March 15th. Depending on the new Aquatec pump meeting the delivery date.
__________________
Offline
Old Feb 17, 2009, 03:27 PM   #74
Silver Sponsor
I didn't realise EVOM host files. They can show spread sheets?
It works, change .txt to xls. Very good work I froze the heading, it reads better.
__________________
Offline
Old Feb 17, 2009, 05:09 PM   #75
aqmist's Avatar
Drives: SRT4
This may not come across to everyone's liking, but and upgrade path may not be advisable.........it may put Richard at a disadvantage to make the 6 come out smothly.
IMO sell the HFS-5 and use the funds from the sale to help defer the cost of the purchase of the 6 OR keep the 5 as its already installed and good part of the benefit of the 6 is ease of install = this part of the 6 is made moot for the most everyone with the 5 already installed. This does not take into account some users looking for the adjustability that the 6 has over the 5. ................IMO owners of the 5 that need the functionality of the 6 are much fewer = these few could delay the 6 if Richard tries to get an upgraded path together for these few 5 owners.
The 6 is a big new release and like some software an upgrade is not going to cut it..........to have released the 6 without the Rj45 jacks so 5 users could swap junction boxes kills a natural progression that was needed.
If anyone were thinking about selling a 5 I would like to offer to help, in that SRT-4 owners are cheap bastards and some might be happy to get into a 5 as less then new retail. No promises and not looking for money but I can help to spread the word.
Not speaking on behalf of Aquamist....Richard is his own man, I'm just stating an opinion as an observation.
Offline
Tags
agua, aquamist, date, diagram, evolutionm, fia2, hfs, hfs5, hfs6, kit, list, mist, parts, release, wiring, wrx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
