Jan 18, 2009, 09:01 PM
Personal Sales Rating: ( 1)
Drives: 02 WRX(sold) 2006 GG EVO IX, NA6(8)C Miata, 2000 CBR600 F4
methanol consumption
guys how long does your meth last? I know it is about as subjective as what kind of MPG do you get? and all depends on how you drive the car, but what are you guys seeing? I went through a tank just tuning. so quite a bit WOT. I am running the Labonte Progressive Kit. Starts to spray at about 7 psi and is at full spray by about 17psi or so. thanks guys
__________________
06 Graphite Grey EVO IX.
Bushur Racing Cone Filter/TTP 02 Housing/Turbo XS TBE(race pipe)/Forge MBC, Walbro 255/ETS 3.5in FMIC/GSC S1 Cams/Defi Link II & BF series boost gauge/4WS Tuned
ROBISPEC///
TEIN Flex with Pillow Mounts & EDFC/Rear Trailing Arm Bushings/Rear Bump Steer Kit/Front Roll Center Kit/Rear Sway Bar
Offline
Jan 18, 2009, 09:12 PM
Personal Sales Rating: ( 4)
Drives: Evo VIII/SVO Mustang/BMW E30 M3
I have no idea of what size nozzle comes with that kit, but if you are using enough to make it work with any reasonable degree of effectiveness, it will go quickly.
If you are interested in making the most of the reservoir capacity, I might suggest not activating it until maybe 18-20 psi.
__________________
Ted B. Spec JAM Long Rod 2.0L - Headway Performance CNC Head & Valvetrain - DI Intake Manifold - 75mm Hypertune TB - HTA3582R Twin Scroll T4 - Machined 12mm lift Billet Cams - MPFab twinscroll T4 Manifold, TBE, UICP, LICP - MPFab Race FMIC - TiAl 44mm WG - Skunk2 Pro Cam Gears - FIC Bluemax 1250cc - FullBlown Dual 255lph - Synchronic BPV - Spark Tech COP Ignition - TRE Trans - Shep TC + LSD - SPEC Graphite Dual Disc
Offline
Jan 18, 2009, 09:31 PM
Personal Sales Rating: ( 36)
Drives: EVO METH MACHINE
My 3.6+qt stock 03-04 reservoir lasts about 1-2 gas tanks. If I'm in tuning mode it will be a guaranteed 1 tank. If I got my car where I want it and i'm just doing my occassional spirited run. I can get about 1.5-2 tanks out of a full reservoir. My kit is on off and starts at 10psi.
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
409WHP/395WTQ
Stock 8 Turbo + MeTH
Online
Jan 18, 2009, 10:44 PM
Personal Sales Rating: ( 8)
Drives: WW IX RS
Wrong section...
My 1 gallon lasted 2 weeks, or half a trackday. Just depends on how much your boosting and how big your tank is.
Evan Smith
Offline
Jan 19, 2009, 06:24 AM
thanks guys, sorry about the section...Updates, It is a 1 gallon tank, and I beleive m12 nozzle. I know it comes on the boost a bit early but its the most effective at that point. The upside to an early spray is that it is progresive, and sprays more as the boost goes up, spraying max at the final setting of about 17 psi. In a way I sort of thing it is better that way rather then on/off at 20psi. I hit 10 psi not even trying... A larger tank might be in order depending how long this 5 gallon can last me.
__________________
ROBISPEC///
Offline
Jan 19, 2009, 02:04 PM
Drives: Tarmac Black Evo VIII 04'
My 2 gallon of meth last about two gas tank fills. DD + spirited weekend driving.
Is that the spray setting your tuner recommended?
Starting to spray at 7 psi seems awefully low even for a progressive system. You might want to bump it up to start spraying min. at 12psi.
__________________
04' TB GSR EVO VIII
HKS 264's, 20G-9, Nisei IC, SMC 100% meth, Sparktech non-cdi, Helix O2/DP, Forge ix wga, ARP studs, RRE rally cat/RRE stealth cbe, AMS licp, Hallman Mbc, MR Bov, Walbro, Tein Flex, Whiteline, Enkei RC-T4 18x9.5, Rexpeed, Ecuflash.
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
