Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 14, 2009, 08:11 PM   #1
Personal Sales Rating: (3)
dtrackstar's Avatar
Drives: Evo 9 SSL
Send a message via AIM to dtrackstar
What fuel mods are needed to run meth?
I have a Evo IX. I am new and I have been researching, so if it has already been discussed, sorry. I plan on getting or already own the following: K&N Drop-in, walboro 255, tbe, licp, o2, ported mani, arp headstuds, tune. Do I need any other fuel mods or is the pump suffice? Any suggestions for other mods (non-fuel)? Thanks
Offline
Old Jan 14, 2009, 08:14 PM   #2
Personal Sales Rating: (40)
subrwho's Avatar
Drives: 2004 Dodge ram 2500, 2003 TB Evo 8(Sold), Acura Integra (DD), Yamaha R6 Raven edition
I would get bigger injectors, but you don't have to. And you'll definatly want a good boost gauge and wideband air/fuel gauge.
__________________
AMS 50 trim kit, AMS Down pipe, AMS fuel rail, Fic 850cc injectors, Hks cat back, Hks intake, BC 272's, Walbro 255fp, Quartermaster Twin Disc, Hallman Mbc, Forge dv, Injen Uicp, XS Fmic, 4WS tuned, Jdm rear, Evo IX front bumper with ralliart lip, Bronze Rota boosts, Jdm headlights, Evo 9 Uk tails, Defi boost and egt, Aem wideband, plus much more....
The evo is now SOLD :(
Offline
Old Jan 14, 2009, 08:14 PM   #3
Personal Sales Rating: (7)
2003 Mitsubishi Lancer Evolution
evo8fl's Avatar
Drives: stock VIII
zeitronix wideband for your failsafe
__________________
Jestr Tuned
93 + Meth Stock ECU
FP Red 565WHP & 523WTQ
Jestrtuning.com
Xtremeboost.com
Offline
Old Jan 15, 2009, 07:02 AM   #4
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
Meth will work on stock fuel system...meth is actually its own fuel system so it really augments the stock system.
If you run more boost you will need more fuel, so just use more meth and you won't need fuel from the stock system.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jan 15, 2009, 07:13 AM   #5
Personal Sales Rating: (11)
Ev0ikon's Avatar
Drives: Evo803Yello
Actually if you are gonna spray meth then it would reduce the requirement for more "regular" fuel.
__________________
He who said that there is no replacement for displacement didn't know pkZIP. :p
Online
Old Jan 15, 2009, 07:27 PM   #6
dtrackstar's Avatar
Drives: Evo 9 SSL
Thank you. What's your guys thoughts on daily driving it?
Offline
Old Jan 16, 2009, 02:58 PM   #7
Silver Sponsor
Personal Sales Rating: (9)
Labonte MotorSports's Avatar
Drives: 3000GT VR-4
Send a message via Yahoo to Labonte MotorSports
No problems with daily driving on meth. Most systems are now progressive of some type so only spray when under boost or when you need it. A 50/50 mix should drop AFR by 1/2pt, so like what Ev0ikon said, would reduce your regular fuel requrements some.
__________________
Labonte MotorSports
Performance Water-Meth Injection Systems since 2002
1-815-315-4823
www.labontemotorsports.com
sales@labontemotorsports.com
Offline
Old Jan 16, 2009, 04:08 PM   #8
Personal Sales Rating: (2)
CanadianEvo's Avatar
I think Methanol is A++ and I daily drive with it as well at over 400awhp on stock turbo. Here are my thoughts:
Let me be very blunt for a moment ... I would NEVER run meth without the Zeitronix Wideband with the ZAV-T Zeitronix Audio/Visual Alarm & Safeguard trigger. This setup allows you to run an aggressive tune with the methanol, and never worry about a pump quitting, a broken line, an empty tank, or staring at your AFR like your life depends on it ... (Well, your engines life does!)
You can set "filters" that allow you to put in maximums and minimums.
i.e. If the car goes leaner then 11.9, or egt's reach _____
You can also make it more complex
i.e. If at over 80% throttle, the car goes leaner then 11.9 etc etc etc ...
You will get a visual warning (a bright red light) and a loud beep. The car will hit fuel cut and save your Evo's heart! It's an awesome piece when you are running meth daily. Mine starts to spray over 8psi and was tuned for 28psi on the street I believe ... It definitely makes daily driving with meth more enjoyable and manageable so if you DO decide to run meth, order up this wideband with the failsafe system and enjoy the newfound power!
I suggest the TTP Engineering Meth system and they are also a premium vendor of Zeitronix. When I did my homework with the methanol systems it seems as though TTP took the best of all of the current available parts and made a kit out of it. Highly suggested.
EDIT: I didn't even answer your original question LOL. I am running stock injectors with the 255 and have had no problems with fuel delivery on a TTP Tune with 400/430 on the last dyno appearance. Cheers.
Zach.
__________________
'06 Apex Silver Mitsubishi Evolution IX SE ::
| ETS Intake | ETS FMIC | ETS LICP | 3" Turboback | Forge mbc | TTP meth kit | Cosworth 272s | RCE Springs | Walbro 255 | 9:1 Custom JE Pistons | Manley Rods | ARP Head Studs & Rod Bolts | Supertech Intake & Exhaust Valves | Supertech Single Valve Springs & Titanium Retainers | Cosworth Bearings | Gates Timing Belt | Eagle Crank | Technafit Clutch line | Motul & Redline Fluids
Offline
Old Jan 18, 2009, 03:39 PM   #9
Personal Sales Rating: (0)
evo082006's Avatar
Drives: 2003 EVO 8
I initally stayed with the stock injectors, but got a little more with 880s. Also Labonte Meth is king..Dan will get you down the road fast...
__________________
2003 EVO 8
CUSTOM 3" EXHAUST/MEGAN RACING MUFFLER; WALBORO 255; INJEN HARD PIPE;AMS INTERCOOLER;AMS LICP; INJEN UICP; SHEP STG 2 TRANSFER; BUSHWACKER TRANS;LABONTE WATER/METH KIT; EXCEDY TWINDISK HD; BC 272/272; PTE 880cc; 10.5 HOTSIDE; FORGE WASTEGATE; EPM O2 DUMP
APPROX ?hp, ?tq on 93 pump
Self Tuned
Offline
Old Jan 18, 2009, 03:45 PM   #10
Drives: your sister to work in the morning after a long night at my house
if you wanna use the meth to the fullest you will want upgrade your injectors. All you need is a pump and injectors. Fuel presure regulators and fuel rails are for the big power guys.
Offline
Old Jan 18, 2009, 06:18 PM   #11
Personal Sales Rating: (8)
Drives: goggles and a speedo
Get injectors if you start running out of fuel as seen on the WB
Offline
Old Jan 18, 2009, 06:29 PM   #12
Personal Sales Rating: (122)
Ultimate CC's Avatar
Drives: 1983 Chevrolet K10 Stepside Pickup
Send a message via AIM to Ultimate CC
I agree with most of what everyone above says but I saw that you were thinking about arp headstuds, I would strongly suggest not doing them if you are doing the 1x1 method, most people end up creating an oil leak when doing so and I have yet to hear of a failure of stock head studs with your mods...just my .02
Offline
Old Jan 18, 2009, 09:30 PM   #13
dtrackstar's Avatar
Drives: Evo 9 SSL
thank you, didn't know that about the headstuds. good thing there not installed :-)
Offline
Old Jan 18, 2009, 10:30 PM   #14
esevo's Avatar
Drives: WW IX RS
Send a message via AIM to esevo
You really dont need to get upgraded injectors. (Unless you go big turbo)
Fuel pump yes... Depending on which system and what amount of meth your injecting, your duty cycle on your injectors should be below 90%.
I would also strongly suggest doing a 50/50 mixture. You "CAN" obtain more power and TQ with lower egt's and injector dutycycle than a 100% meth mixture. All depends on what kit and whos tuning.
Also for kit, dont go cheap get the best... Aquamist! You wouldnt buy a ebay rebuild motor from a unkown builder right? You would buy a Jackson, Buschur, AMS or any well know built motor proven to work. Aquamist has been doin this the longest had have the best kits bar none! There price proves to show its worth.
Good Luck
Evan Smith
__________________
Full build in the making!!!
MANY PARTS FOR SALE:
http://forums.evolutionm.net/sale-pa...ml#post6471348
Offline
Old Jan 20, 2009, 09:45 AM   #15
Just keep in consideration that more HP directly requires more fuel (with optimal tune). If pushing the tune for power using less than say 50% methanol/H2O then fuel supply might be a problem. You can either tune it for more concentrated methanol or tune it for an upgraded fuel system. The latter is more expensive and requires extensive mapping but may provide more solid results, even at higher methanol concentrations. But I don't know, I still use the stock injectors
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
