Jan 14, 2009, 05:01 AM
Personal Sales Rating: ( 0)
Drives: Aeon GT3 Spyder
Photo Pre Install
I will try and keep upto date with this but this is the engine bay pre install HSF-5
Offline
Jan 14, 2009, 06:47 AM
Personal Sales Rating: ( 17)
Drives: IX GSR
VERY COOL, can't wait to see post install pics. Where are you going to put the nozzle(s). How many nozzles will you use?
Offline
Jan 14, 2009, 08:58 AM
Personal Sales Rating: ( 8)
Drives: WW IX RS
Wow more pics please! LOL What fuel will you be running? Which mixture of injection will you be running?
Thanks
Evan Smith
Offline
Jan 14, 2009, 09:31 AM
Quote:
2 nozzles
After a chat with richard i'm putting the 1st just after the compressor in the metal boost pipe and the 2nd just before the 90 degree silicone hose before the throttle body.
Offline
Jan 14, 2009, 09:34 AM
Quote:
Thanks
Evan Smith
98 Ron is the best we get here or did you mean afr's
Mixture i was thinking 60/40 or 75/25 open to ideas
Offline
Personal Sales Rating: ( 15)
Drives: 2003 Mitsubishi Evo VIII
Looks good. I would change the coupler on the intake manifold though. That kink doesnt look to good.
Chris
__________________
"Anybody can go fast. A good team can go fast consistently!"
Big Thanks To My Sponsors!
-Buschur Racing-
-GSC Motorsports-
-Magnus Motorsports-
-RPS Performance Clutches-
-Precision Turbo-
-Avid Racing-
-MitsubishiParts.net-
Offline
Jan 14, 2009, 09:37 AM
Quote:
Chris
Thats not a kink it's just the way the boost pipe has been made.
The intake length is super short so it does not really cause a problem.
Offline
Jan 14, 2009, 09:46 AM
Drives: WW IX RS
Cool cool!
60% water to 40% meth? or vice versa?
50/50 would seem perfect for that set up, due to the water to air IC you will need to be near full evaporation prior to getting to the IC. Too high of H20 mix will not evap as easy as a 50/50 mix, causing some pooling in the IC. The meth will help with atomizing/evap the water. Meth will also provide just a little higher Ron.
I look forward to seeing more pics, and info on this car! Very very cool!
Evan Smith
Offline
Drives: IX GSR
Do I understand you correctly, you are putting a nozzle before the heat exchanger?
I wonder if that is the best idea, it may reduce the effeciency of the heat exchanger.
Offline
Jan 14, 2009, 10:22 AM
Drives: WW IX RS
It wont be bad if he can get it to fully evaporate prior to the IC. Then it will only aid the cooling. BUT it has to be fully evaporated, a cold climate should not be a choice for this setup.
Use a small .4 jet and it should work...
OP what boost will you be running? Higher boost will aid evaporation as it causes higher charge temps.
Evan Smith
Offline
Jan 14, 2009, 03:35 PM
Evan Smith
I'll be running 28 psi there and there abouts...
Yes Richard recomened before the heat exchange
Offline
Jan 14, 2009, 10:19 PM
Personal Sales Rating: ( 2)
Drives: Evo 8
i see 034 motosports nice company there
__________________
Quote:
Say what...
Tell them to STFU.
Offline
Jan 15, 2009, 07:05 AM
Drives: IX GSR
Evan Smith
I don't totally agree. Check out a thread on the waterinjection.info board from a while back with charts showing the cooling effect of different jet locations.
Pre IC injectin, even with good evaporation.......the surface of the IC will cause the moist air to condense on the walls of the IC and reduce the effeciencey.
Offline
Jan 28, 2009, 08:05 PM
Drives: EVO IX MR
Where can I find this air/water intercooler?????
I want one!!!!
Good luck on your project, looks fun!
Cheers,
C>
__________________
6000 miles of happiness so far...
Offline
Jan 28, 2009, 08:09 PM
Drives: EVO IX MR
Quote:
Update:
I found it!!!!
It's Here.....so cool!
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
