Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Jan 6, 2009, 12:56 AM   #1
Personal Sales Rating: (0)
evo9ben's Avatar
Drives: evo 9 mr se
Meth failsafe ????????????
hi should i install a meth failsafe what do you guys think???? or do you think ill be fine if i keep meth in the tank and make sure it never runs out ?
Offline
Old Jan 6, 2009, 03:02 PM   #2
Personal Sales Rating: (24)
My Garage
SICK9's Avatar
Drives: 2006 EVO IX MR [GG], 1999 JEEP Wrangler SAHARA, 2008 Ford Escape Ltd.
A Failsafe is a must have if you are running meth.
If you do not install one, you are asking for big trouble.
The failsafe is for when the pump stops working.
It will cut the boost to WG pressure to save your engine.
I would also get a low level indicator for the fluid level.
That will tell you if it's low.
2 seperate things.
__________________
06 EVO IX MR [GG]
FP RED Turbo [P+C] / GSC S1 Cams / SNOW Alky Inj. / Buschur EM+IM+65mm TB / BC Racing "ER" Coilovers /AMS FMIC / Sparktech C.O.P. / ACT HD + SL FW /
+ Cusco/APR/ARC/DAMD/Rexpeed/Nisei/ XS-Eng./Blox/NRG/Hawk/ViS. etc. etc.
TUNED BY KREIONIC
SCR-SCCA (SM 69)
PICS
Offline
Old Jan 6, 2009, 06:04 PM   #3
Personal Sales Rating: (6)
aqmist's Avatar
Drives: SRT4
A good failsafe mechanism that can monitor flow and supply level and take action if necessary should basically be a requirement if you tune for the water/methanol being injected. If you are just injecting water/methanol on top of a safe or factory tune that's not dependent on the water/methanol then you should be OK..........but IMO thats a waste if whats being attempted to be done with the water/methanol injection is more then just cooling the intake air charge down.
There's a stickied thread in this section that helps to explain failsafes and why to use.........if tune for the W/A get a failsafe that you trust will do what you want it to do.
Offline
Old Jan 13, 2009, 04:31 AM   #4
Personal Sales Rating: (4)
SlowCar's Avatar
Drives: a drunken IX
Quote:
you should
things to look for in a failsafe
-trigger when underflow(clogged nozzle, kinked tubing, pump worn, leak pre flow sensor...)
-trigger when overflow(leak post flow sensor......nozzle popped off...)
-trigger when low level sensor in injectant tanks are activated
look for a failsafe system that will handle all the above - an excellent choice is the Aquamist DDS3
you know the saying - you want to play, you got to pay. pay now and pay less, ~$300 for a failsafe vs. a blown motor.
__________________
6 injectors, 3 fuel tanks and 2 fuel pumps
Aquamist HFS-6 install: ......:)
Aquamist HFS-1 install: http://forums.evolutionm.net/water-a...n-project.html
Aquamist 2D/DDS3 install: http://forums.evolutionm.net/water-a...tion-pics.html
Offline
Old Jan 13, 2009, 05:06 AM   #5
Personal Sales Rating: (122)
Ultimate CC's Avatar
Drives: 1983 Chevrolet K10 Stepside Pickup
Send a message via AIM to Ultimate CC
a failsafe is a cheap investment when you look at the big picture...
Offline
Old Jan 13, 2009, 10:59 AM   #6
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
What happened to Abner's post ---
Man this forum is squeaky clean, you can't even poke fun of someone.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jan 16, 2009, 02:20 PM   #7
Silver Sponsor
Personal Sales Rating: (9)
Labonte MotorSports's Avatar
Drives: 3000GT VR-4
Send a message via Yahoo to Labonte MotorSports
It all depends on how you are going to tune your engine with meth. A 50/50 mix will drop AFR from 11.5 to 11.0. You can lean back out to 11.5 and have a safe tune that will add some power. If you are going to lean out engine more then 11.5, then Yes a Fail Safe is a must.
Here is a link to our current fail safe product offerings.
http://www.labontemotorsports.com/st...onitoring.html
For Evos our IFS-30C works very well. Keeps you at WG boost until meth flow is above set point, no meth = no high boost. Also keeps you at WG if you blow a fuse or a wire comes loose on your meth system.
__________________
Labonte MotorSports
Performance Water-Meth Injection Systems since 2002
1-815-315-4823
sales@labontemotorsports.com
Offline
Old Feb 17, 2009, 04:11 PM   #8
Personal Sales Rating: (15)
spyderx's Avatar
Drives: VIII RS
anyone know if there's a failsafe system for SMC v2.0? recommendation?
Are there generic failsafe that I can add onto this?
thanks guys! my used VIII came w/ SMC but w/o any failsafe. I want this to kick in at certain boost level based on a single ECU flash and I can toggle between Hi/Lo boost settings...thx
Offline
Old Feb 18, 2009, 08:23 AM   #9
Personal Sales Rating: (2)
2005 Mitsubishi Lancer Evolution
gear head's Avatar
Drives: 05 evo
^DDS3 triggering Tephra Map switching or the wastegate solonoid will work just fine.
__________________
damn the man
Never underestimate the power of stupid people, they can accomplish many.....many stupid things.
Offline
Old Feb 18, 2009, 10:59 AM   #10
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
The DDS3 will work well. The gauge button will enable you to run high or low boost. Need to contact me to supply the -4AN fittings.
__________________
richard@aquamist.co.uk
Offline
Tags
evolutionm, fail, failsafe, injection, meth, methanol, safe
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
