Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 27, 2008, 12:05 PM   #1
Personal Sales Rating: (0)
leecavturbo's Avatar
Drives: 2003 evo8 gsr jdm
estimated gains with meth on std 8?
how much would it make using meth with retune.
stock block* and head and inlet and turbo and 3" tbe decat and walbro.
but block has forged rods for safety.
if i have this right with meth i can run more boost due to detonation resistance but wont more boost on a std 8 turbo just make lots of hot compressed air?
Offline
Old Nov 28, 2008, 07:08 PM   #2
Huh?
Typically adding a methanol injection system will give you a 30-40whp increase for a stock turbo.
Offline
Old Nov 28, 2008, 07:10 PM   #3
Personal Sales Rating: (9)
wevo1985's Avatar
Drives: '03 white evo 8, '93 black eagle talon tsi awd (dd)
Send a message via AIM to wevo1985
meth also cools the air.
__________________
br hta37r, br stage 4 boltons, kelford 280 cams,jam lifters, supertech duel valve springs, ti retainers, nit valves, ported and polished runners by me, ported and polished intake and exhaust mani by me, br ported throttle body, , ross custom banodized pistons, manley i-beam rods, 100mm crank
568hp 460tq at 30psi on the stock ecu tuned by ivey!!!
Offline
Old Nov 28, 2008, 07:16 PM   #4
Drives: 2006 evo IX MR
i have a ix mr and when i did the aquamist kit i picked up 63whp and 112ftlbs with the stock turbo on the same dyno just by adding the meth kit. definitly the best bang for buck i ever did! call dynoflash. he'll hook u up!
__________________
Buscher ported/coated exhaust mani
works o2 housing
works 3" dp
works tbe
works test pipe
cosworth 272's
titanium valve springs and retainers
walbro fuel pump
works 65mm tb
forge mbc
ets licp(version 2)
ets uicp
ams frontmount
arp headstuds
precision 680cc
fp red/Buscher ported/coated hotside
shepherd 5speed conversion
Exedy triple disc
buscher intake
aquamist meth kit
Offline
Old Nov 29, 2008, 09:41 AM   #5
Quote:
with no ecu adjustments?
Offline
Old Nov 29, 2008, 09:47 AM   #6
Personal Sales Rating: (4)
gunhaha's Avatar
Drives: IX SE, 05 Outback, 99 Civic
Meth without ecu tuning is useless and would not get him hp/tq gain.
Meth allowed for better AFR, timing, and boost optimization thus the hp/tq gain.
__________________
gunhaha
Offline
Old Nov 29, 2008, 09:56 AM   #7
thought so just wanted confirmation
Offline
Old Nov 29, 2008, 09:58 AM   #8
evoxsi's Avatar
Drives: 03 Evo
o u need a retune with meth theres no way around that.
Offline
Old Dec 4, 2008, 02:38 PM   #9
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
Don't expect gains as big as "mr-derer2" got. It is likely that his pump gas tune was very conservative.
I switch back and forth between pump and meth pretty often and I will say that it makes a huge difference. No where near 63whp and 112ftlbs but enough that you REALLY REALLY feel it.
I used to run pump gas to only 22psi and then going to meth @32psi was an even bigger difference. But now I run 26psi on pump and I run it pretty damm lean up top nearly 12.0 on pump. So with a pump gas tune that aggressive meth won't make as big a difference.
It is safe to say that you will pick up at least 50tq I would say. Enough to make 2nd feel like 1st, and 3rd feel like 2nd, etc...
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
