Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 20, 2008, 02:22 PM   #1
Personal Sales Rating: (23)
rish197's Avatar
Drives: 05 EVO VIII MR
DDS3 & AEM pls help
Hi guys,
So I installed my DDS3 last night, and like the diagram shows, hooked my pump neg (-) as trigger. Just as a test, i set the WL as far CCW as possible, and the WH all the way CW as possible, so that should give me a nice open window.
My issue I think is with the trip adj range. When I start to spray and spool up, the flow meter starts, and I see the B light up, then the failsafe kicks in. I have tried various settings on the trip adj range, all the way CCW, CW and at noon, and various in between, 10 o 'clock, 2 o'clock. I'm not sure if there is a small sweet spot, or if I have something wrong.
Can anyone help me pls?
Thanks!
Jason
__________________
2005 White EVO VIII MR
Megan Racing Turbo-Back Exhaust
Forge FMIC
Forge WGA
HKS 272s
Fidanza Cam Gears
GM 3-Port BCS
AEM 50/50 Methanol Setup
363hp/336tq (before Meth)
Offline
Old Nov 20, 2008, 03:13 PM   #2
Silver Sponsor
Personal Sales Rating: (4)
Drives: Citreon Xsara
Quote:
Originally Posted by rish197 View Post
Hi guys,
Thanks!
Jason
How many bars is it showing?
Richard
__________________
richard@aquamist.co.uk
Offline
Old Nov 20, 2008, 03:19 PM   #3
rish197's Avatar
Ive tried the recommended settings (about 5), but I have also tried more and less. It seems to be almost always as soon as the unit turns on (the green LED on the board)
__________________
Forge FMIC
Forge WGA
HKS 272s
Fidanza Cam Gears
GM 3-Port BCS
Offline
Old Nov 20, 2008, 04:17 PM   #4
Silver Sponsor
I have two question to help me with your setting:
1. Which version of the DDS3 do you have?
2. Are you in the PWM mode? (jumper link)
__________________
Offline
Old Nov 20, 2008, 04:57 PM   #5
rish197's Avatar
Sorry, forgot to mention that...
v10 & yes, PWM mode. I also have the (-) wire from the pump to PWM IN (pin 17)
__________________
Forge FMIC
Forge WGA
HKS 272s
Fidanza Cam Gears
GM 3-Port BCS
Offline
Old Nov 20, 2008, 05:31 PM   #6
Silver Sponsor
Thank you for the extra info.
Can you tell me if the pump position is wired to the battery as the our DDS3/AEM diaghram shown?
Here is copy:
__________________
Offline
Old Nov 20, 2008, 06:00 PM   #7
rish197's Avatar
yes sir. That is the diagram I followed for my install. I have the (+) from the pump right to battery. The (-) from the pump to the orange wire from the AEM controller & to the DDS3.
__________________
Forge FMIC
Forge WGA
HKS 272s
Fidanza Cam Gears
GM 3-Port BCS
Offline
Old Nov 21, 2008, 01:45 AM   #8
Silver Sponsor
So far it seemed normal. A few more questions please.
1. When the system is not spraying, does the green led come on?
2. When the system is triggered, does the red led come on?
3. What is setting of the "trip-adj" based on the face of a clock.
__________________
Offline
Old Nov 21, 2008, 06:45 AM   #9
rish197's Avatar
I fixed the issue. There needs to be a "dumbass" light. Your product is rock solid and was working perfectly!!
When I installed the low level switch in the tank, I must have bumped the fluid line going to the pump as it was kinked. So there was in fact very little fluid going through the flow meter, and the failsafe was activated.. DUH!!!
Richard, thank you for all of your time and patience. I am sorry you wasted time on my stupidity. You and your product kick butt.
I owe you a cold one.
-Jason
__________________
Forge FMIC
Forge WGA
HKS 272s
Fidanza Cam Gears
GM 3-Port BCS
Offline
Old Nov 21, 2008, 09:13 AM   #10
Silver Sponsor
Giod to know the system is working. Thank you.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
