Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 18, 2008, 10:14 AM   #1
Personal Sales Rating: (23)
rish197's Avatar
Drives: 05 EVO VIII MR
DDS3v10 & Tephra/Jack_of_Trades cable
Hi,
Has anyone wired this up yet? I just got the kit in, and am trying to figure this out. I noticed the v10 has a +5v out (pin 5).
Thanks in advance
-Jason
__________________
2005 White EVO VIII MR
Megan Racing Turbo-Back Exhaust
Forge FMIC
Forge WGA
HKS 272s
Fidanza Cam Gears
GM 3-Port BCS
AEM 50/50 Methanol Setup
363hp/336tq (before Meth)
Offline
Old Dec 4, 2008, 02:54 PM   #2
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
With the v10 kit you don't need the jack of trades harness.
I currently have the v10 kit with pin 5 wired directly into the ECU on the alt map pin.
The DDS3 v.10 outputs a steady 4.5v which works perfectly for switching maps.
The jack of trades harness outputs about 4.75 which also works fine.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Dec 7, 2008, 01:02 PM   #3
Silver Sponsor
Personal Sales Rating: (5)
Drives: Citreon Xsara
It is still necessary get the cable because Jamies uses the OE crimp pin to access the ECU. Unless you source the ECU pin yourself.
__________________
richard@aquamist.co.uk
Offline
Old Dec 8, 2008, 06:12 AM   #4
dudical26's Avatar
Drives: IX GSR
You can order just the crimp pins from Jamie(jack of trades). He sells them in packs of 5 on his website.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Jan 10, 2009, 05:49 PM   #5
Personal Sales Rating: (11)
daisaw1219's Avatar
Drives: gg evo ix ssl
Send a message via AIM to daisaw1219
so if the failsafe activates or you turn off the dds3 will it switch maps
__________________
Mods:
Monosodium Glutamate
or
M.S.G. (MAD STICK GAME)
Offline
Old Jan 11, 2009, 12:48 PM   #6
dudical26's Avatar
Drives: IX GSR
yes if either of those happen it goes to the base map.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Feb 15, 2009, 03:41 PM   #7
Personal Sales Rating: (21)
Drives: 05 element, 03 evo (mutating)
dudical26,
can I out put a signal from a dds3 through the Jack of Trades harness? I have the original dds3 from the "5" kit.
I was using a ground signal from the dds3 to trigger an ebc but now I am using the stock boost control and going to an alt map.
now I have a JOT alt map switch harness
I figure I can relay to the JOT switch going to 12v from the ground signal and then the JOT harness would fix the voltage to the ecu? Thus removing the switch out of the harness.
Is that clear? will it work?
__________________
now with led dome lights!!!!!
Online
Tags
aquamist, dds3v10, evo, harness, jack, jackoftrades, manual, tephra, trades
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
