Nov 22, 2008, 08:42 AM
Personal Sales Rating: ( 5)
Drives: A Money Pit
Do you spary 100% meth right now or 50/50? It looks like corrosion (water and brass dont like eachother, oxidation) to me which may be from 50/50 or water in the washer fluid that you have used before....
__________________
////// www.4WSTuning.com ////// Labonte ////// AMS ////// Blitz ////// Brailleauto ////// Exedy ////// Fujita ////// Forge ////// Greddy ////// HKS ////// Innovate //////Injen ////// Invidia //////
Offline
Nov 24, 2008, 09:41 AM
Personal Sales Rating: ( 0)
Drives: evo 9, 4g Eclipse
I use 60/40% meth/water by volume
Offline
Nov 24, 2008, 10:51 AM
Personal Sales Rating: ( 4)
Drives: 2006 Evo MR
I ran 100% meth on my stock ic pipes and my aftermarkets for much longer and I have no signs of corrosion, there or in my pump for that matter.
__________________
"Tuning without a wideband is like screwing without a rubber, sooner or later you'll get something you can't fix!"
Hellcat
Offline
Nov 24, 2008, 02:57 PM
Drives: A Money Pit
Quote:
The water may be the issue as I said before if you are running it with water then you may have corossion on the brass nozzle because of the oxidation. Left over meth/water mixture may be pulled out of the line while at idle and turning the car off and just sitting there for a period of time...... Im not saying that I'm 100% right but it makes sense as a possability.....
__________________
Offline
Nov 24, 2008, 09:01 PM
Silver Sponsor
Personal Sales Rating: ( 9)
Drives: 3000GT VR-4
The coloring on the outside of the pipe looks like dye from washer fluid. Possible a very small amount is seeping past threads of nozzle and elbow and leaving a stain.
Inside of pipe looks like hard water deposits from minerals that might be in the fluid you used.
Are you taping your boost reference source before or after TP? If before, try moving controller boost reference to after TP. You will see faster off time of spray when TP closes. Else when TP closes you still have boost for a spit second before BOV opens which would explain the reverse flow you are describing.
Best regards,
Dan
Offline
Nov 24, 2008, 09:25 PM
Personal Sales Rating: ( 1)
Drives: no more Evo
The green stuff is called verdigris. Thats what happens when copper brass or bronze are exposed to water. It is nothing really. Use SS nozzles and it wont happen.
Offline
Nov 24, 2008, 09:29 PM
Personal Sales Rating: ( 7)
Drives: A blown IX
its mostly residue not corrosion
Offline
Nov 24, 2008, 09:37 PM
ya sucks that the labonte kit came with brass. I will order a stainless one. thanks everyone. Also will never use windshield cleaner fluid due to the quality of water they use and that dye. I use 100% distilled water and Methonal.
hope my thread helps others.
Offline
Nov 24, 2008, 09:42 PM
hey dan,my boost tap is after the TP. I used the Fuel pressure Regulator.
Do you sell Stainless nozzles, if so i would like to order 1.
Best regards,
Dan
Offline
Nov 25, 2008, 11:22 AM
Where exactly are you seeing corrosion, cause I don't see any......
Offline
Nov 26, 2008, 06:44 PM
Personal Sales Rating: ( 36)
Drives: EVO METH MACHINE
1. green stuff is from whatever fluid being used
2. your nozzle is leaking, pressure test and check for leaks
3. no way a 60/40 mix is going to cause corrosion after a few months. I've been using 100% for years and been through 1 pump that was corroded.
4. always mix meth/solution w/ distilled water
__________________
TEMEVO
"I'm addicted to 100% Methanol : ) "
MACHINES GONE WILD
FOR SALE: FORGE WASTGATE/PERRIN INTAKE CLICK ME
Offline
Nov 28, 2008, 10:11 PM
Silver Sponsor
Drives: 3000GT VR-4
The nozzles we now sell are nickle platted. Send me a PM is you want to order one.
Offline
Dec 24, 2008, 12:08 PM
Personal Sales Rating: ( 15)
Drives: 03 Apex Silver Evo
Best regards,
Dan
what does "TP" stand for? The only things I can think of are tail pipe, test pipe, throtte position sensor, and toilet paper...
Offline
Dec 24, 2008, 12:21 PM
Drives: 02 LancerOZ, 89 Turbo 5-speed minivan
"TP" = throttle plate
__________________
2002 Lancer
Offline
Apr 9, 2009, 09:07 PM
Drives: Evolution VI
is it true meth turns to jelly when exposed to air? If so how long before this happens?
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
