Go Back   evolutionm.net > Lancer Evolution 1-9 Forums > Evo Engine Management / Tuning Forums > Water/Alcohol Injection & NOS
Welcome to EvolutionM.net!
Welcome to EvolutionM.net.
Old Nov 16, 2008, 02:49 AM   #1
Silver Sponsor
Personal Sales Rating: (4)
Drives: Citreon Xsara
Big thanks to Dudical26 from Aquamist...
Without prompting, Dudical offed his own free time to help a fellow EVOM member to track down the fault of a problem HFS-5 install. I believe the system is now in full working order. Full details of the nature of problem may be reviewed on the following thread if the user wishes to disclose it.
More Problems with my HFS-5
I cannot thank Dudical26 enough for taking the matter to task. He has managed to bring the system to working order in a coupler of hours yesterday, compared to my effort for weeks to no avail.
__________________
richard@aquamist.co.uk
Offline
Old Nov 16, 2008, 06:41 AM   #2
Personal Sales Rating: (0)
leecavturbo's Avatar
Drives: 2003 evo8 gsr jdm
was expecting to read a reply from dudical on what he found the problem was
sure he'll add it later.
big up dudical
Offline
Old Nov 16, 2008, 02:52 PM   #3
Personal Sales Rating: (8)
EvoTio's Avatar
Drives: 2003 Evolution VIII, 1974 Chevy LUV/Small Block V-8, 1966 Chevy Nova SS
Way to go dudical26 . Also curious what the problem was.
Offline
Old Nov 16, 2008, 06:11 PM   #4
Personal Sales Rating: (17)
dudical26's Avatar
Drives: IX GSR
hey guys -
This weekend I got together with Import Junky to take a look at his HFS-5. He had been working with Richard to try to solve the problem but things can be a bit tricky when Richard is so far away. Anyone who has dealt with Richard knows how incredibly far out of his way he will go to help Aquamist customers. Having personally been helped many times by Richard I thought I could start to repay the favor by helping other Aquamist users.
Import Junky arrived with all of the wires ran, but not connected, for the new components that Richard sent him. I began wiring everything up testing things along the way. First we checked that the HSV worked by supplying 12v via a power supply, everything worked. Continued wiring up the rest of the system until everything was connected. As a note for everyone ALWAYS BE SURE TO INSTALL AN INLINE FUSE for the power supply to the DDS3. I then decided to test the system before connecting any of the extra components like the failsafe solenoid. The kit worked as expected so we took it for a drive around the block, again the kit triggered as expected.
We then connected the MAC valve used as a failsafe. Went for another test drive….hmmm not working. This systematic process of testing things along the way before connecting everything enabled us to know that something to do with the MAC valve was causing the problems. Starting looking over the system and we find that the fuse for the DDS3 was blown. This meant that the MAC valve was drawing too much power for the kit to handle. The only reasons this could be is either no resistor or a short in the MAC valve or wires. There was no inline resistor installed but I was skeptical this would have really blown the fuse. Pulled out the multimeter and checked for a short in the MAC valve wires….problem found. There was a short in the wires which was what blew two of Import Junky’s previous DDS3 kits.
By replacing these wires the problems will be eliminated.
Overall lessons learned that everyone should follow –
- Always install an inline fuse for the power supply; it protects the DDS3 from damage in many situations.
- If you have to run any wires either use multi-core cable with a protective shroud or run the wires through some sort of cable loom or sheath. Otherwise there is danger they will get snagged along the firewall and may get stripped and short out.
- Before connecting any external loads to the DDS3 check for a short and also check resistance. A multi-meter is worth its weight in gold when it comes to this kind of stuff.
- When installing and troubleshooting and Aquamist kit, do things one step at a time. Connect the bare minimum of wires needed for the kit to turn on. Then connect the next ground of wires, then the next, then the next, etc… By following this process you can quickly track down what component is causing the problems.
- Finally be neat and organized, it makes working on the kit in the future much easier.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Old Nov 16, 2008, 07:45 PM   #5
Vigman's Avatar
Drives: EVO IX MR
I am not surprised by Dudical26 behavior, he is a great guy!
Wish to be his neighbor sometime ;-)
C>
__________________
6000 miles of happiness so far...
Offline
Old Nov 17, 2008, 04:29 AM   #6
awesome write up dudical
Offline
Old Nov 17, 2008, 05:01 AM   #7
Personal Sales Rating: (9)
PeteyTurbo's Avatar
Drives: RX7 GSL-SE turbo, 05 MR Graphite Gray,02 GSXR-750, 88 supra turbo
Send a message via AIM to PeteyTurbo Send a message via Yahoo to PeteyTurbo
dudical is the man!
Offline
Old Nov 17, 2008, 10:37 AM   #8
Silver Sponsor
Personal Sales Rating: (89)
VividRacing.com's Avatar
Drives: EVO 8, EVO X, R35, GTR, 997TT, Viper, S2000
Send a message via AIM to VividRacing.com
Great to hear Dudical!!! Glad to know its in good working order.
__________________
Jon G
jong@vividracing.com | 480-966-3040 ext:230 | AIM: vividjg
www.VIVIDRACING.com
We Finance!Click here!
Want more deals? Look HERE!!!
Offline
Old Nov 17, 2008, 01:05 PM   #9
Silver Sponsor
Without out Duducal's help. I would still be struggling with Imoported Junky for months to come.
I never suspected the lack of FUSE link. I just get the message "the replacemen board doesn't work". By the time I tried to help, it was already too late.
__________________
Offline
Old Nov 19, 2008, 07:24 AM   #10
Personal Sales Rating: (7)
Drives: Tarmac Black IX SE- Blown Transfer Case
Well, I feel like an ass for not posting sooner. I just have so much going on. My whole house is basically being remodeled and I have a baby on the way.
So anyways, I want to give a BIG THANKS to Dudical26. He was great to work with and very knowledgable. He definately has a very systematic approach to troubleshooting. I can't tell you how happy I was to finally figure out the problem. I feel like such an idiot after seeing such a simple fault. Obviously my biggest mistake was the lack of an Inline Fuse on the power supply. Atleast now I know this system really well. I should have much better luck troubleshooting in the future if I have any problems.
As for Richard L, I can't thank you enough. For a Vendor to help a guy that bought used parts from another member is just unheard of. I still can't believe the time and effort you put in as well not including the the parts you sent me several times. By the way, I still have to send you my other Gauge and DDS3. I kept to just in case Dudical26 needed it.
I haven't done anything with the MAC Valve wiring yet. I'm working on modifying my ROM with the MAP Sensor mod and the Ecu controlled boost mod. Obviously I'll be using the MAC Valve for boost control which will be connected via the stock boost control solenoid connector. Thanks again for everyone that helped including Evan from VividRacing. Hopefully I'll have some results with this setup soon.
Offline
Old Nov 20, 2008, 09:59 AM   #11
wesside's Avatar
Drives: WW 05 Evo VIII RS
Send a message via AIM to wesside Send a message via MSN to wesside
Mad Props Dudical26
I remember my kit didn't have the in line fuse so I rounded that stuff up locally, I'm sure I talked about it in my install thread. Best thing to do for anyone who is purchasing a kit is to go over everything & instructions to make sure nothing is missing and if your doing the install and come to a point where something is missing don't do any further work until whatever it is acquired
I'm still using the MBC and the Mac Valve for failsafe but you've got a few options I've still got the ecu map switching harness I got from Jack of Trades I've never hooked up, maybe one day when I go to ecu controlled boost
__________________
V/// RS
Pimp Mode / Jdm ix rear / pump & 720cc/ Aquamist
Invidia / Cusco / Whiteline / Buschur Racing / Exedy
Defi / Greddy / Vishnu / Hks 272 / Fp Green /Mustang Dyno #'s 398whp 405tq :)
www.cardomain.com/id/wesside
PARTS FOR SALE!!!!
My Vboy Evo photHo Sh00t 2
Vboy photHoSh00t n Vid
http://www.myspace.com/wesside514
Offline
Old Nov 20, 2008, 10:19 AM   #12
Personal Sales Rating: (3)
Drives: 06 evoIX SE
Dubical is a great guy, helped me out with some basic stuff, and also pointed me in the right direccion many times...
BTW: just out of curiosity, my HFS1 came with the fuse to hook up to teh wire, does the HFS5 come with it? i know Importjunkie bought his kit used...
__________________
mah EvoIx pix
Tuned by:
AWD Motorsports
4WD Tuning
Offline
Old Dec 4, 2008, 02:52 PM   #13
dudical26's Avatar
Drives: IX GSR
The HFS-5 does come with the fuse in the kit. Import's must still be with the old owner of the kit.
I tried to source a similar fuse holder so that I would have an extra just incase but I couldn't find anything as nice as what Richard uses. He really must spend a lot of time testing out little parts like this to find the best stuff out there.
__________________
Want To Buy
Stock Boost Lines
www.gsmfanatics.com
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are On
Refbacks are Off
