View Poll Results: is it ok to use meth/water injection during winter
yes
12 |
100.00% |
no
0 |
0% |
Nov 11, 2008, 10:30 PM
Personal Sales Rating: ( 0)
Drives: evo 9, 4g Eclipse
winter use
how many of you dont use it during winter?
Offline
Nov 11, 2008, 10:33 PM
Personal Sales Rating: ( 16)
Drives: EVO VIII RS
This shouldn't be a poll, but an answer to a question that is probably overlooked for us "snowbirds." I would assume it would freeze being mixed with water?
__________________
__________________________________________________
--------------- Tuned by "ONRAILS" ---------------
__________________________________________________ _
Offline
Nov 13, 2008, 11:26 AM
come on its free im not charging a dime for this poll. so go out and vote its your responsibility as an american
Offline
Nov 13, 2008, 11:49 AM
Silver Sponsor
Personal Sales Rating: ( 89)
Drives: EVO 8|9|X, R35, 997TT, S2K, M3, C63 AMG,
In az I do still see the need for it removing it. I usually keep the same mix at 50/50 to keep the water from freezing. I just do a slight retune add more timing less fuel ect ect.
In other parts where its colder I can understand to reduce the jetting size.
Evan Smith
Offline
Nov 13, 2008, 12:19 PM
Personal Sales Rating: ( 17)
Drives: IX GSR
I have run it in freezing winter temps of -10*f
At that time I was running 100% meth though.
You can calculate the freezing point of any meth/water mixture. Just make sure that whatever mixture you use has a freezing point below any temps that you will see.
Offline
Nov 14, 2008, 10:39 AM
I dont think the freezing is the issue why you would turn it off in the winter. I think the issue affecting of the atomization and condensing so there is uneven distrubution. Since your temps will not be as high less heat transfere to take place so less of phase change from liguid to vapor of the methonal.
any thoughts on that?
Offline
Nov 27, 2008, 09:00 AM
Drives: WW Evo IX GSR
Bump. Want to know if meth is safe in the colder climates.
__________________
Intake, TBE, MBC, Walbro, Hotchkis Springs, Mccullough HIDs, Wingless
Offline
Nov 28, 2008, 09:54 PM
Drives: IX GSR
Quote:
read my post, about 2 posts up. I have used it in sub zero temps.
Offline
Nov 29, 2008, 08:39 PM
lemmonhead has a good point about condensation though.
__________________
Offline
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
