I know it's not an evo, but the kit is the same and it WORKS! Thought I'd share my install with y'all...
I just finished up installing another Aquamist HFS-1 Alcohol/Water injection system in Mike Cooper's EPL Stage3 S4. The car previously put down 340whp/390wtq on a local *VERY* low reading Dyno Dynamics dyno on K04 turbos. Now it will be breaking 360whp/430wtq with ease. Here's some pics from the install:
Tapping the stock IC pipes:
Installed 2x injection mounts filled with 2x .7mm nozzles, one in each pipe for about 630cc's of total injection goodness:
And re-installed in the car:
Then back to the flow meter and on/off valve mounted under the ECU:
I kept all wiring and tubing runs as clean and tidy as possible:
'Fabbing' up the tank mount:
Pump is mounted under tank nice and sturdy, and wiring loom and 8mm tubing is run though some braided nylon tubing for extra protection:
What alcohol injection system officer?
2.5 gallon tank fits perfectly behind this little door, just love how clean this looks:
Mid install, all wires run to where they need to go, time to connect it all together:
Once everything is tidied up, looks a little more like this, with plenty of excess wire for gauge relocation in the future:
'Temp' mount that seems to last forever for most guys
It's 2am, Mike just left with a BIG smile on his face! Install went awesome, cut the sh1t out of my hand because these things are b1tches like that
WHy do you think they call them OWWDIES?
